Rear diff "wet"? 07 xk 46k miles.. - JeepForum.com
post #1 of 8 Old 04-29-2012, 02:32 PM Thread Starter
07commanderpa
So, I was bored today. Drove around some, found some dirt roads and some mud puddles.
Washed the jeep when I was done, waited until it was dry and I got down and was looking under it to see if I got all the mud/dirt washed away (I didn't).
Found out that my rear diff looks terrible..
That's bad, right? How bad on a scale of 1-10, 10 being that my xk might not run tomorrow.
I didn't hit anything, and I didn't hear anything break.. and it's not dripping, etc.
I don't know how long it has been like this, but I don't think it was like this a month ago but I'm not sure.
Could it just be the seal or something?
07commanderpa is offline
post #2 of 8 Old 04-29-2012, 02:38 PM
big0cheeto
2008 WK
make sure its topped off before you drive, does just look like that front seal is leaking.
big0cheeto is offline
post #3 of 8 Old 04-29-2012, 03:58 PM
colinzj
2006 WK
With a spray pattern like that, yeah, it's probably the pinion seal.
Cross-country road trips are probably a bad idea, but you can still drive it around town until you get it fixed. Keep an eye on the fluid level.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L — Dead, sold, and rolling again
colinzj is online now
post #4 of 8 Old 04-29-2012, 04:36 PM
Tango.
2008 WK
Gear oil looking like that is usally not leaking very fast.
Pack some gear oil (and a pump) and keep an eye on the level.
I have had trucks leak like that for years without any issues.
Top it off, then check it in a few days and see how much more it takes to top it off.
Then you have an idea ov how much it is leaking per week.
Since you just noticed it ... it is very important to top off the gear oil, and not how much it takes.
Tango. is offline
post #5 of 8 Old 04-29-2012, 05:52 PM
flexyxj
2009 XK Commander
Leaking pinion seal.As others have stated,top it off and it will be fine for a short time until you can get it fixed. It doesn't take much oil volume to make a mess like that. Make sure to replace it with a quality seal and you'll be set.
flexyxj is offline
post #6 of 8 Old 04-29-2012, 06:06 PM
flexyxj
2009 XK Commander
An '07 with 46K? Depending on what you have for a powertrain warranty,That might be covered.
flexyxj is offline
post #7 of 8 Old 05-01-2012, 10:37 AM
yzjwk
2005 WK
http://www.youtube.com/watch?v=GXCCU5GxsUs
Agree with above about the leak, but if you have the QD II system with the
ELSD's , i would fix it asap as you will be loosing the expensive friction modifier as well .Don't know how much you pay for fluids there , but here for the price of 1 bottle of friction modifier and 1 qt of syn lube ,I could prob. pay to have a garage change the seal . Just my .02
good luck
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #8 of 8 Old 05-01-2012, 12:19 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
I'm gonna agree it's a bad pinion seal. Being as you don't know for sure how long it's been like that I would first top off the diff fluid and then beat feet to get it fixed. You say you don't think it was like that a month ago but you aren't sure - your pumpkin could have been low for a while running hot and doing some premature wear on the gears inside.
Hopefully, and likely, all is well but I wouldn't drag my feet getting it taken care of.
Good luck.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is online now
Resetting info center "0 Miles to Service"? LargeFather ZJ Grand Cherokee Forum 14 05-14-2016 10:26 AM
"Rear lamp Failure" and "Coolant Sensor Bad" 2DoorXJ91 ZJ Grand Cherokee Forum 19 05-06-2012 03:23 PM
Other than "Rear Lamp Failure" and "Coolant Sensor Bad".... big_rudy101 ZJ Grand Cherokee Forum 7 03-17-2012 07:21 PM
rear diff "humms" nicktheknife813 ZJ Grand Cherokee Forum 8 05-28-2011 05:22 PM
2008 "Oil Change Required" twice in 1,600 miles??? brtt485 WK Grand Cherokee & XK Commander Forum 18 03-11-2011 05:34 PM
