Rear Bilstein 5100 install Q's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Rear Bilstein 5100 install Q's
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 08-18-2014, 09:37 PM   #1
LouC
2007 WK
OK WKers, going to install the rear 5100s on the WK soon. Got a few questions:
1) Boot up or down, I see that some have done it boot up, and the Bilstein logo is right side up with it that way. I recall there was a big debate about this when I installed the 4600s in my ZJ 12 years ago and most had it with the boot down.
2) Next, I have read in a few posts that it is necessary to use washers, to get optimal fit. Is this needed or not?
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline   Reply With Quote Quick reply to this message
Unread 08-18-2014, 11:22 PM   #2
dbozman
2010 WK
Just installed mine. Boot up, no washers.
dbozman is offline   Reply With Quote Quick reply to this message
Unread 08-18-2014, 11:39 PM   #3
LouC
2007 WK
thanks, any clunks or noises?
Unread 08-19-2014, 02:04 AM   #4
USN_BlackWK
FLY NAVY
USN_BlackWK's Avatar
Boot down and washers on the upper bolt with around 10k miles and NO issues! The stickers are right side up with boots down BTW
2001 Cherokee Anniversary 4.0L
1998 Cherokee Classic 4.0L Aug '15 COTM!
2014 Grand Cherokee SRT 6.4L
USN_BlackWK is offline   Reply With Quote Quick reply to this message
Unread 08-19-2014, 09:11 AM   #5
Fast55
2010 WK
This.
2010 WK Limited QDII
Hemi, Volant, SC 3872, SS Gibson, Bilstein 5100's, 265/70 AT 2's, LED's, etc.
Fast55 is offline   Reply With Quote Quick reply to this message
Unread 08-19-2014, 09:42 AM   #6
dbozman
2010 WK
Installed last weekend. Just drove an 8-hour road trip with 100 pounds of bikes/rack on the hitch, 200 in the hatch and 200 pounds of dogs in the back seat. Performed flawlessly.
Unread 08-19-2014, 10:10 AM   #7
CRCs_Reality
2005 WK
Same here, no problems at all (at least not from the rear...), major improvement in handling :-)
2005 WK Limited, 5.7, QDII , 2" BB, 255/70R18's on JK Alloys
Silver WK Club Member #116
CRCs_Reality is offline   Reply With Quote Quick reply to this message
Unread 08-19-2014, 03:26 PM   #8
lonnyda
What part number of Bilstein are you using? Do you have a lift and if so would these work on a non-lift WK?
Thanks!
lonnyda is offline   Reply With Quote Quick reply to this message
Unread 08-20-2014, 02:50 AM   #9
LouC
2007 WK
On the 5100 series, the rears will work with 0"-2" of lift. The fronts start out at .75" of lift and are adjustable by moving the spring perch. So you can use the rear 5100 on a none lifted vehicle but not the front. For the front you'd have to stick with the 4600 series.
Unread 08-20-2014, 08:48 AM   #10
DVB
2006 WK
Damn you were loaded.
2006 4.7 Limited QD II, Stock
DVB is offline   Reply With Quote Quick reply to this message
Unread 08-20-2014, 09:19 AM   #11
LouC
2007 WK
That's good because the OE springs and shocks are very soft.
Unread 08-20-2014, 03:55 PM   #12
Fast55
2010 WK
Thanks!
They're almost too long with no lift, but they will work and haven't bottomed out. Now if I can ever get my 5100 struts from Kolak we will see how they work as a set and a little lift................
Unread 08-24-2014, 11:51 AM   #13
LouC
2007 WK
Did mine today, each side took about 15 min literally. The way the metal bushing is sized on the 5100s you pretty much have to install em boots up. The metal bushing is 1 3/4 in wide on one and 1 9/16s in wide on the other....
Fit perfect. If only the front was that easy lol....
Major improvement in ride and control, and the OE ones were not bad at all really just too soft for my liking.
