Re-torquing w/threadlocker? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Re-torquing w/threadlocker?
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiPoison Spyder DeFenders™ - "Tubeless" Jeep FendeJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 08-20-2012, 02:31 PM   #1
MagJeep
2006 WK
Im about to put my spacers on, 1.5 rough country, with blue thread locker.
When i re-torque/check the tightness, will the thread locker get messed up?
Idk why I just thought about this, probably a silly question though.
Also, someone said to use Red (permanent), what do you guys use?
MagJeep is offline   Reply With Quote
Unread 08-20-2012, 02:53 PM   #2
Static83
2005 WK
Torque to 90/95 ft lbs, then when retorquing torque to 75/80. With thread locker they shouldnt move at all.
Use Blue.
2005 WK 4.7L, QTII, OME HD, Spidertrax 1.5" Spacers, 17" Moabs, 255/75/17 BF Goodrich KMs, Superchips 3875.
Static83 is offline   Reply With Quote
Unread 08-20-2012, 03:19 PM   #3
sk1er18
2007 XK Commander
If you properly torque them, they wont budge when you re-torque... which is really just a torque "check" to make sure they didn't loosen. Due to difference between static and kinetic friction, make sure the nut is moving at the time proper torque is reached. You can try re-torquing immediately and you'll see that it wont move because you'll need more torque to overcome static friction in the threads.
There's no reason to check the torque with a lower value. That defeats the purpose of checking it.
-Matt
Click here to see build
[FOX Resi Shocks][OME HD][JBA Strut Spacers][1" Custom Rear Spacers][275/65/18s][Custom low-pro roof rack mounts][Rola Rack][Skids & Sliders][Front shackles][much more...and more to come]
sk1er18 is offline   Reply With Quote
Unread 08-20-2012, 03:37 PM   #4
MagJeep
2006 WK
How do i keep the whole rotor from moving when tightening the spacers on? I'm just picturing it in my mind right now and i imagine them spinning as im trying to torque them in. i kmow the backs wont move b/c of the e brake.
Unread 08-20-2012, 03:44 PM   #5
sk1er18
2007 XK Commander
If 4x4 just do one wheel at a time. With the other 3 down the one wont spin. Otherwise put lug nuts on the studs to protect the threads and use a pry bar to stop it from rotating.
-Matt
Unread 08-20-2012, 03:49 PM   #6
MagJeep
2006 WK
ohhhhh, haha i knew that was a dumb question. Thanks.
Also, there looks to be some anti seize left on the original studs, should i scrape that off with a wire brush?
Unread 08-20-2012, 03:49 PM   #7
Static83
2005 WK
This would be true if torque wrenches were 100% accurate, but they are not, they can be off by +/-10 ft lbs depending on quality.
The second torque is taking this into account to be sure you dont break the thread lock when retorqueing.
These are also close to the directions that come with the spidertrax spacers.
Unread 08-20-2012, 03:51 PM   #8
Static83
2005 WK
You can also just have somebody press the brakes
Unread 08-20-2012, 03:53 PM   #9
MagJeep
2006 WK
Haha i thought about that too, but thought there had to be a better way.
Unread 08-20-2012, 04:06 PM   #10
MagJeep
2006 WK
I should scrape the anti seize off right?
Unread 08-20-2012, 04:10 PM   #11
trax95008
2006 XK Commander
My 8 year old girl has become quite accustomed to operating the brakes while I work on the XK. From just holding it to loosen or tighten lugs, all the way to pumping them for a brake fluid exchange!
trax95008 is offline   Reply With Quote
Unread 08-20-2012, 04:16 PM   #12
Luck06
2006 WK
I didn't use any thread locker on my spacers and they seem to be holding tight just fine. A couple of them loosened up a bit after about 300 miles, but after torquing them down the 2nd time they haven't budged. I just checked them last weekend during an oil change and they were still at 100 ft/lbs after 3k miles.
Silver '06 Laredo 3.7L
- 2" RC lift, 1.5" RC Spacers, 58643 MLL's, !Pinch Weld, Spyder Bull Bar, 130w KC Daylighters, Spyder LED Tails, Taillight Guards, Silverstar ZXE's, Interior LEDs, Hypertech Max Energy, Kenwood 6" DVD/NAV, 12" Audiobahn Sub
Luck06 is offline   Reply With Quote
Unread 08-20-2012, 04:17 PM   #13
Static83
2005 WK
Yes, I would.
Unread 08-20-2012, 04:18 PM   #14
MagJeep
2006 WK
Im sure they'd be fine without it, but it cant hurt, right? Plus its only medium strength. What do ppl even use the red for???
Unread 08-20-2012, 04:25 PM   #15
Static83
2005 WK
Fine without thread locker? I would say no, unless you want to constantly be checking the torque, not sure if I would trust wheelspacers without the locktight to be honest.
