RC lift questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > RC lift questions
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line~Artec JK 1 TON SWAP~Advance Adapters SYE Kits
Unread 10-19-2014, 04:58 PM   #1
GC10LTD
2010 WK
RC lift questions
SO I know many people have asked and I have too but I am only going to double check and make sure I have all my parts I need. Wanting the RC lift and 31's (265/70/17). I have 72,000 miles on her and havent replaced any of my suspension. Do I need to get new rear shocks with the lift? What about struts? If so, does anyone have part numbers for them? Will I need UCA's as well? I know I'll need wheel spacers. I'm looking to run either some NITTOS or TOYOS for tires. MAy go with a duratrac but not sure yet. Anyways, thanks for all the help yall.
2010 WK | 3.7L QT1 | K&N 77 Series Intake | ROLA Rack |....much more to come...
GC10LTD is offline   Reply With Quote Quick reply to this message
Unread 10-19-2014, 06:02 PM   #2
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
At 72K miles you'll want to swap in new struts and shocks. Brand and part #s tbd. However, when it comes to tires, skip the Duratracs and look at GY Authorities from Wallyworld. Load range C. You'll spend a LOT less money and believe me when I tell you you'll get virtually the same tire, at much less $$ and won't be disappointed.
As far as UCAs you don't need to replace them simply because you are swapping in a lift/leveling kit. Only necessary if the ball joints are shot and even at that with a RC leveling kit you could swap in new oem arms (look at Rockauto.com) and be fine.
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is online now   Reply With Quote Quick reply to this message
Unread 10-19-2014, 07:08 PM   #3
DCFD522
I did a RC lift and put 255/75/17 Duratrac's and love them. Ride is smoother than stock. I DO wish I had done shocks/struts mainly since you remove them anyway. Also have 75ish on my miles. Rocking 1.5" spacers with no weld mods and clear just fine at lock.
DCFD522 is offline   Reply With Quote Quick reply to this message
