raving in reverse or drive - JeepForum.com
post #1 of 8 Old 11-24-2013, 05:42 AM Thread Starter
94jeepman
2005 WK
When I start my jeep I'll put it in reverse or drive and it will act like it's in neutral for about 5 seconds and than start moving. It doesn't always do this its just kind of random I have an 05 4.7l. Could this be the transfer case acting up from the neutral shifting thing they sent the recall out for?
94jeepman is offline
post #2 of 8 Old 11-24-2013, 06:35 AM
caulk04
2008 WK
Transmission losing prime. Very common and only annoying, won't cause any problems so long as you wait for it to engage before setting off.
Try letting it run in neutral for a few seconds before shifting into gear, mostly when it's been sitting for a while. Not a bad idea to let it warm up and circulate briefly anyway. My rule is, start it first, then put your seatbelt on and get situated before leaving.
A change of the filters in the transmission will fix this problem so long as good filters are used and installed properly. WIX or OEM filters.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #3 of 8 Old 11-24-2013, 09:57 AM Thread Starter
94jeepman
2005 WK
Ok thanks for the info when it does that I usually let it sit for a few and I actually have a at filter sitting on the shelf in the garage just haven't had the time
post #4 of 8 Old 11-25-2013, 02:01 AM
05hemiyc
I had this issue. I changed the transmission oil and it never occurred again. Also, letting it warm up will do the trick as well.
05hemiyc is offline
post #5 of 8 Old 11-27-2013, 05:35 AM Thread Starter
94jeepman
2005 WK
Do our transmissions have 2 filters?
post #6 of 8 Old 11-27-2013, 06:24 AM
yzjwk
2005 WK
Yes the 545rfe has 2 filters . 1 spin on and 1 internal .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #7 of 8 Old 11-27-2013, 09:53 AM
caulk04
2008 WK
They are both internal. The spin on filter is for the cooler return line which runs on a separate fluid circuit from the primary trans functions.
caulk04 is offline
post #8 of 8 Old 11-27-2013, 11:59 AM
yzjwk
2005 WK
AH , your right , I forgot that stupid thing is inside the pan .
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
