Rak's Build - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Rak's Build
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 11-15-2011, 05:34 PM   #1
Rak187INF
2009 WK
Rak's Build
Well after a couple months of reading, learning, and modifying, I decided it was time to put together a build thread. So here goes. First, this is how she looked the day I brought her home-
First thing I did was get the front windows tinted to match the back. Next was to paint up the wheels. I washed them and scrubbed them real good. After they dried, I sanded them down with some fine grit sandpaper, and cleaned them again. One coat of etching primer, then 3 coats of rustoleum black wheel paint, then I opted for 2 coats of rustoleum clear coat.
It didn't take too long before I got bit by the lift bug. I ended up going with the RC 2 inch lift. Unfortunately I don't have any pictures because the install ended up being the longest day of my life. I guess the fact that I didn't know a damn thing about suspensions, it kinda took me a little longer to learn as I went, lol. But I do have the before and after-
Before-
After-
After a little while I decided to tint the tails. A couple coats of VHT Nightshade, and I was good to go. (Sidenote- Nightshade drys pretty dark. I ended up doing 4 coats and the end result was so dark you couldnt see my brake lights lol. After stripping them off and redoing them with 2 coats, I was good to go.)
I also ended up debadging and replacing the radio antenna with a shorty antenna. Shortly after the lift was done, I ordered the front skid plate from 4xGuard. Pretty simple and straight forward install. I ended up printing out Chirpz's thread because it was easier to use step by step than the manufacturers directions.
I also added some OEM foglights, but since I didn't want to pay $180 for the full kit and then have to take it to the dealer, Budasac threw his patented cubbyhole switches in for me and wired the fogs up to them.
Next up was a CB and antenna. I basically pulled the cubby out from the left side of the steering wheel.
I cut the back end off
and slid it over the cb and fit it into the cubby
I ended up just wiring it straight into the fuse panel
The antenna mount was fab'd up by Buda and installed
The picture is his also, lol
Finally it was time to put some bigger tires on. I ended up going with General Grabber AT2's in 265/70/17. I had a bit of rub at full lock, but nothing too bad.
After that it was time to start playing with Plasti-dip. I tried a few times to bake my headlights and get them open.... but that nut was too tough to crack so I gave up. I ended up plasti-dipping the side markers though
Black WK Member #28
2009 WK- 2 Inch RC lift, 265/70/17 General Grabber AT2
Rak187INF is offline   Reply With Quote Quick reply to this message
Unread 11-15-2011, 05:36 PM   #2
Rak187INF
2009 WK
After that came the rola rack
Finally I added some RC 1.5 inch wheel spacers to alleviate the rub at full lock. It did the trick, but now I need to do the pinch weld mod, so that'll be coming up soon.
A little while later, I got started on the gutter guard front grill. I ended up using some expanded metal I got at Home Depot. First I removed the entire grill assembly. I cut all the fins out of the grill and started laying in the mesh. Once I had everything lined up the way I wanted, I actually used lashing wire to secure the mesh to the pillars. While I had everything apart, and had some extra material, I made a piece to go in front of the radiator at the bottom where it's wide open to rocks and debris. This piece was just zip-tied in to make sure it wouldnt rattle. The assembly was re-assembled and remounted.
Finally, I got a Westin Brushguard from the GF for my B-Day. I def didn't waste any time throwing it on. I had to end up cutting holes into the mesh grill to allow the mounting brackets. But in the end it was a pretty straight forward install.
And this is how she sits today
Hopefully I'll be adding more posts to this as the build progresses.
Black WK Member #28
Unread 11-15-2011, 06:05 PM   #3
WKChris89
2006 WK
Looks sick man, bout time u made a build thread!! haha
Our trucks are growing up together, i really gotta get me a rack though i feel left out that u and buda have em.
WKChris89 is offline   Reply With Quote Quick reply to this message
Unread 11-15-2011, 06:12 PM   #4
Budasac
2005 WK
Looks good Kenny, the brush guard compliments the rack nicely.
Oh, and Happy Birthday!! (when is it?)
Budasac is offline   Reply With Quote Quick reply to this message
Unread 11-15-2011, 06:19 PM   #5
Rak187INF
2009 WK
Thursday, but the wierdest thing is.... I think I feel a "cold" coming on Thursday, not sure if I can make it to work that day, lol
Black WK Member #28
Unread 11-15-2011, 06:37 PM   #6
mattydipps
2006 WK
good looking truck rak, how do you like your rc lift ?
mattydipps is offline   Reply With Quote Quick reply to this message
Unread 11-15-2011, 07:22 PM   #7
Rak187INF
2009 WK
Lovin it, haven't really noticed too much of a difference in the ride
Black WK Member #28
Unread 11-15-2011, 07:48 PM   #8
Raucous
2006 WK
Nice job. Black was my first choice when I was looking for my GC, but it wasn't meant to be. I'm hoping to have a build thread of my own up around mid December.
(06 WK Overland 4x4) (5.7 Hemi) (4" SuperLift, XD Addict 17X9, 285/70/17 Duratracs) (Yakima LW Roof Rack) (WT Digifit floor mats) (LED Interior lights)
IN PROGRESS: FUTURE: (Superchips, 4Xguard rails/skidplates)
Raucous is offline   Reply With Quote Quick reply to this message
Unread 11-15-2011, 07:59 PM   #9
84foxgt
2007 WK
looks great. i've been going back and forth on getting a grill guard and your pics sealed the deal for me.
84foxgt is offline   Reply With Quote Quick reply to this message
Unread 11-15-2011, 08:03 PM   #10
daveWK42
2008 WK
this is a great build thread! & the brush guard looks great! you've done a lot of things that i've thought about doing to my own rig, so i'll be referring back to this & asking a LOT of questions...
edit: i like your cb placement, but where do you keep the mic when it's not in use?
Living well is the best revenge
hers: 2013 patriot sport
his: 2008 grand cherokee laredo
daveWK42 is offline   Reply With Quote Quick reply to this message
Unread 11-15-2011, 08:17 PM   #11
jager00
2005 WK
Good start! What else do you have planned? The brush guard wasnt on there the other day was it? And nice meeting you the other day! Hope you can make it out to RC in jan!
2007 JK Sahara- trying to figure this one out
2005 WK 9" lift on 37's with all the goodies- regretfully sold :(
jager00 is offline   Reply With Quote Quick reply to this message
Unread 11-15-2011, 08:37 PM   #12
Rak187INF
2009 WK
The brush guard just went on yesterday. Next I'm lookin to start adding lights and armor. Prob start doin the skids underneath. As long as nothin's goin on at home, I'll prob be in for RC
Black WK Member #28
Unread 11-16-2011, 06:05 AM   #13
AJeepZJ
2006 WK
haha, you stole my sticker setup! I'm just kid'n. Looks good. - Oh, and I added it to WK/XK Build Directory.
All Gear, No Skill.
AJeepZJ is offline   Reply With Quote Quick reply to this message
Unread 07-23-2012, 06:34 PM   #14
big0cheeto
2008 WK
looks good man, what CB is that? i have a 08 WK and i was looking around to find one that would fit in the cubby because i think the 08-10 cubby's are smaller.
big0cheeto is offline   Reply With Quote Quick reply to this message
Unread 07-28-2012, 02:40 PM   #15
fingaz
2009 WK
Rak187INF, the Jeep looks good! I see you have your front windows tinted. I know its illegal here in NJ and I was wondering if the cops have given you any problems because of it. What % tint is it, too?
2009 3.7L Laredo Black | Two-Toned Leather | RER Nav/DVD/BA System | Viper alarm | HID's in the lows and fogs | Westin Brush Guard | Tinted Tails | Custom Blue LED Interior/Rear Hatch Lights | Rough Country 1.5" Spacers | General Grabber 255/70r17 -- Island Beach State Park 4x4 Mobile Sportsfishing Permit In -- To Do: Install Uniden CB, Rock lights
fingaz is offline   Reply With Quote Quick reply to this message
