Radio options for steering wheel controls - JeepForum.com
post #1 of 7 Old 09-13-2013, 01:59 PM Thread Starter
EthanC23
2005 WK
So, I have an 05 WK limited with the factory stereo and steering wheel controls. I'm wondering who out there with a WK has steering wheel controls and what they do for their radio. Obviously, the factory radio kinda sucks and has no aux, no pre-outs, etc. I'm looking for something that I can use speaker amp/subs and a way that I can keep my factory steering wheel controls.
I have seen a module from PAC that apparently keeps your factory steering wheel controls with an aftermarket stereo and was wondering if anyone has experience with it?
However, I also kind of wanted to keep the factory look because I think its clean and its also a very cheap alternative to buying a $300 double-din, and aftermarket is definitely cheaper than the $900 factory touchscreen with the AUX in the front.
Any help or knowledge would be greatly appreciated.
EthanC23 is offline
post #2 of 7 Old 09-13-2013, 04:17 PM
Burnerman
Burnerman's Avatar
You can add a sub out to the factory REC radio and an iPod and AUX input. My wife's WK has a sub output that was install by a PO. I put in the iPod jack. A little research online should find all you need.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 7 Old 09-14-2013, 12:01 AM Thread Starter
EthanC23
2005 WK
Is it any good? If I were to add the AUX to my factory REC would I be happy with the quality, or does it seem like her system is a bit lacking, and that aftermarket would be better? I've seen the module from PAC to add AUX ports, but it seems like the AUX ports only turn on on a certain channel on the radio, which would not be what I want. What I'm looking for is a system I can add speaker amp/iPod AUX and have the speaker amp work for every channel, not just on the iPod AUX. Does your wifes system use the sub out on every channel and source?
EthanC23 is offline
post #4 of 7 Old 09-14-2013, 08:01 AM
RUGLAYR
I have a wk and originally just added a aux to listen to my phone and the sound quality was horrible. I ended up going with a Kenwood ddx770 and for the price am very happy. Has iPod aux and pretty much everything you'd want all while still keeping steering wheel controls. If your looking to add aux I would just go all the way and buy a aftermarket deck you'll be much happier
RUGLAYR is offline
post #5 of 7 Old 09-14-2013, 06:51 PM Thread Starter
EthanC23
2005 WK
How'd you go about keeping your steering wheel controls? Did you buy the PAC module for it?
EthanC23 is offline
post #6 of 7 Old 09-16-2013, 06:45 AM
RUGLAYR
Yes I used the PAC harness and add on steering wheel control piece and works flawless
RUGLAYR is offline
post #7 of 7 Old 09-18-2013, 11:55 PM Thread Starter
EthanC23
2005 WK
Alright, well it will be a bit of time before I get to doing my stereo, as I am more focused on my outside rather than my inside for now. But I will post back and let everyone know how it goes
EthanC23 is offline
