Radio install has me crying - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Radio install has me crying
WIN a set of Mammoth Boulder Wheels at ExtremeTerrain.com!Savvy Aluminum Gas Tank SkidTruck & Jeep Fest 2015 - Edmonton
Unread 04-20-2014, 07:43 PM   #1
lkrides
1996 FSJ Cherokee
Hi all, I am trying to replace the RAQ radio in my wife’s 2007 Commander. This vehicle has the Boston Acoustic speakers and does not have NAV.
I purchased a Kenwood BT758HD radio and XSVI-6502 harness from Best Buy. I realized after connecting everything and not getting any sound that I blew it because I did not know this vehicle has an amp when I bought this stuff. So I guess the XSVI-6502 is just the wrong harness.
Next goof is that I purchased a Schosce CR4000 from Walmart. It provided sound but the speakers buzzed when the head unit was turned off while the key was still on. Additionally the fade function would not work.
So now after researching it seems that a PAC C2R-CHY (I’ve seen this for $80 or so on Sonix) or Metra CHT0-013BB (don’t know where to buy this) is the correct harness. Can anyone please confirm this or advise me?
Thanks very much.
Lee
lkrides is offline   Reply With Quote Quick reply to this message
Unread 04-21-2014, 12:08 PM   #2
Just_Josh
PAC C2R-CHY4 is the one that worked for my 05 WK with factory amp. Got it on amazon for about $55 plus shipping. For the wiring, I had to wire front speakers on the HU to rear speakers on harness. It sounds fishy but it works and it sounds really good with the power of my Kenwood HU compared to factory HU. There was another harness that works but a person would have had to run it from amp in trunk area all the way to front dash.
Just_Josh is offline   Reply With Quote Quick reply to this message
Unread 04-21-2014, 01:06 PM   #3
XKAudioGuy
Use the pac or run all new speaker wire with new 4 channel amp. The stock speaker wire may be 20 gauge. I installed 8 inch mids in front doors with Orion HCCA silk tweeters on colums with 4 in Infinitys in dash. Sounds beautiful.
XKAudioGuy is offline   Reply With Quote Quick reply to this message
Unread 04-05-2015, 11:44 AM   #4
Samuell06WK
I am looking to install a new stereo amp subwoofer in my 06 WK. So with the PAC C2R-CHY4 will I be able to put in a sub and amp?
Samuell06WK is offline   Reply With Quote Quick reply to this message
Unread 04-08-2015, 03:12 PM   #5
Mattc123456
the aftermarket harness from the radio to the jeep should have a blue amp wire on both ends. connect them together. should work
Mattc123456 is offline   Reply With Quote Quick reply to this message
Unread 04-08-2015, 06:51 PM   #6
XKAudioGuy
If you are running new radio with no steering wheel controlls eliminate Pac and run new speaker wires to the speakers.
