Quick way to identify Quadra-Drive II - JeepForum.com
post #1 of 17 Old 03-02-2011, 10:36 AM Thread Starter
str8shot
Hi Everybody,
I'm in the market to sell my 99 GC with QD, and I definitely want to get a WK with QD2. It's just too good in the snow to go without.
Is there a quick and easy way to identify if an 05+ Limited has QD2? On the WJ's, there's an emblem on the lower left tailgate. I haven't seen anything like that on a WK.
So, is there a way to identify it's present, without talking to the owner? IE - browsing through cars.com and just looking at pictures.
Thanks!
str8shot is offline
post #2 of 17 Old 03-02-2011, 10:43 AM
Lt_JWS
2006 XK Commander
12 bolt rear diff cover= QDII
10 bolt " " " =QTII
2006 XK 4.7V8 | Quadra-Drive II | Daystar 2" Lift |K&N Filter | Port and Polished Throttle Body| Magnaflow# 12256 | IAT Mod | Leather, heated seats,Command View| Factory Tow hooks | Full factory skids | Rear D-Ring Shackle
Lt_JWS is offline
post #3 of 17 Old 03-02-2011, 12:02 PM Thread Starter
str8shot
OK, that helps when I check them out in person, but not really for narrowing things down online.
You don't see a lot of pics of diff covers...lol.
Any other tell tale signs?
str8shot is offline
post #4 of 17 Old 03-02-2011, 12:19 PM
NDSU_Bison
2014 WK
I'm pretty sure the only badging option is the "Trail Rated" badge that anyone can buy for $30 and that won't even tell you what 4WD system is installed.
NDSU_Bison is offline
post #5 of 17 Old 03-02-2011, 12:29 PM
criket
2005 WK
Try WKjeeps website. Lots of info on there. It may be there somewhere.
2005 | WK | Khaki | 3.7 | QT1 | OME HD Front Struts | Rusty's 2" lift in Rear w/ Monroe load levelers (F150 version) | 265/70 Nitto Terra Grapplers | 17" Moabs | 1.5" wheel spacers | Pinch weld mod Rear fender trim mod | 4xG Matrix w/ reciever hitch | 4xG Belly guard | SOLID Diff cover | Cobra CB radio | 4xG antenna mount | Rola roof
criket is offline
post #6 of 17 Old 03-02-2011, 12:41 PM
hoaxci5
1995 XJ Cherokee
There are only two ways to tell, count the bolts, or look at the badging under the t-handle for 4lo.. If it says QD-II then it most likely is, but the only way to truly verify is to count the bolts.
Unknown - 1995 XJ - 4.5 RC lift, drop brackets, 33" MT's, SYE, Custom Bumpers/Rockrails
Rambo - 2007 XK Limited 5.7 - OME HD - Monroe Load Levelers (F150) - Flashpaq - RRO SuperSliders - 4XGuard all over - SOLD
hoaxci5 is offline
post #7 of 17 Old 03-02-2011, 02:07 PM
Texas WJ
Texas WJ's Avatar
2005 WK
Agreed. Look for this:
265/70-17 BFGoodrich All-Terrain T/A KO, 2" lift, JK Wrangler Moab wheels, Spidertrax Spacers, Rola Roof Rack.
Texas WJ is offline
post #8 of 17 Old 03-02-2011, 02:11 PM
scotimus75
2005 WK
I could be wrong but I thought the limiteds only came with QDII. The Laredo is where it was an option.
Khaki WK Club Member #22
"Nothing sucks more than that moment during an argument when you realize you're wrong."
scotimus75 is offline
post #9 of 17 Old 03-02-2011, 02:17 PM
kentman
kentman's Avatar
2006 XK Commander
What hoaxci5 said. That is how I would go about it.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
post #10 of 17 Old 03-02-2011, 03:25 PM
Devilsmed98
First is the QDII badge below the shifter assembly, unfortunately any 3rd party or shady dealer could slap that on for marketing and increased profits. The only true way to tell is to count the differential bolts.
~Black WK Club Member #9~
2011 WKII Overland
2007 WK Limited[/COLOR]
1995 YJ Rio Grande
Devilsmed98 is offline
post #11 of 17 Old 03-02-2011, 03:43 PM
Marcus86GLHS
"...I could be wrong but I thought the limiteds only came with QDII. ..."
QDII was available on all three GC models, not the SRT8 of course.
also, WK's with QTII or QDII are both Trail Rated. so, if you see a Trail Rated badge, that does not mean it has QDII, could have QTII.
to be sure: count the bolts on the rear diffy.
2008 Hemi Grand Cherokee Limited 4 x 4, original owner, 29,000 miles
Marcus86GLHS is offline
post #12 of 17 Old 03-02-2011, 05:32 PM
ItalianJeeper77
2015 KL Cherokee
It says Quadradrive II by the gear shifter.
1996 ZJ *Sold | 2000 WJ *Sold | 2005 WK *Sold | 2008 WK *Sold
2015 KL
ItalianJeeper77 is offline
post #13 of 17 Old 03-02-2011, 05:52 PM
maxst2
2006 WK
QDII has electronic diffs as well.
2006 65th Anni. Grand Cherokee 4x4 in black w/ 4.7L V8
maxst2 is offline
post #14 of 17 Old 03-02-2011, 06:01 PM
maxst2
2006 WK
Also, Use a VIN number decoder:
http://www.compnine.com/vid.php
maxst2 is offline
post #15 of 17 Old 03-02-2011, 06:10 PM
hoaxci5
1995 XJ Cherokee
That did show in the report that my XK had QD-II (12 bolts and badge at shifter) so that would be another alternative to actually looking at the vehicle while shopping online.
hoaxci5 is offline
2010 Grand Cherokee LTD Quadra Drive II or Quadra Track II hobbie1 WK Grand Cherokee & XK Commander Forum 6 10-06-2010 04:04 PM
Need help Diffrence between Quadra Drive 2 and Quadra Trac wccf91 WK Grand Cherokee & XK Commander Forum 30 08-24-2010 09:05 AM
is quadra trac/quadra drive electronically controlled? dirtdad ZJ Grand Cherokee Forum 2 01-01-2010 04:45 PM
quadra drive II or quadra trac II 2008 ZJ ? bill.rivard WK Grand Cherokee & XK Commander Forum 3 11-01-2008 04:52 PM
Possible Quadra-drive/Quadra-trac II binding problems orbornhitorn ZJ Grand Cherokee Forum 3 06-06-2007 01:21 PM
