Quick need an answer - JeepForum.com
post #1 of 25 Old 12-29-2014, 10:39 PM Thread Starter
Jeff1119
2017 WK
Going to buy a brand new throttle body on eBay for my 09 jeep gc. I have a DBW throttle body. Would I need to have it programmed at the dealer upon installation? Last time I got a used one from an 07 commander and the engine light went on. I'm guessing because that one was already programmed?
Jeff1119 is offline
post #2 of 25 Old 12-29-2014, 11:14 PM
modernblueWK
Is there something wrong with your current throttle body?
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #3 of 25 Old 12-29-2014, 11:26 PM Thread Starter
Jeff1119
2017 WK
Maybe? I think? Idk. If you've been reading my posts I've been chasing down an idle surge issue for the past 3 months now and have replaced many parts with no success. The idle surge only happens when it rains. I sprayed the the throttle body down back in October with throttle body cleaner but it got all over the sides of it and I didn't do it the correct way. It works fine but I believe ever since I put it back after that the idle has been down a little since. I figure a new one for 65 bucks might help a little
Jeff1119 is offline
post #4 of 25 Old 12-30-2014, 07:32 AM
caulk04
2008 WK
They don't need any programming.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #5 of 25 Old 12-30-2014, 09:56 AM Thread Starter
Jeff1119
2017 WK
Your sure the engine light won't go on like it did when I put the used one in from the commander?
Jeff1119 is offline
post #6 of 25 Old 12-30-2014, 04:15 PM
Greever
2008 WK
quick question, did u change the throttle body gasket when u cleaned it? and tighten it down in a cross pattern?
Greever is offline
post #7 of 25 Old 12-30-2014, 04:23 PM Thread Starter
Jeff1119
2017 WK
Throttle body gasket is still original and yes I tightened it down in cross cross pattern
Jeff1119 is offline
post #8 of 25 Old 12-30-2014, 05:10 PM
DCFD522
I went with the 4.7L DBW TB...no codes andno programming required. Bolts all match, had to shave down the plastic nub on the intake, but that's it.
DCFD522 is offline
post #9 of 25 Old 12-30-2014, 05:55 PM
caulk04
2008 WK
The tb is not a computer. It does not need any programming.
If you got a cel, it's not because the pcm doesn't know what tb is on there.
caulk04 is offline
post #10 of 25 Old 12-30-2014, 06:01 PM Thread Starter
Jeff1119
2017 WK
ok cool thanks. So maybe the throttle body from the commander was originally bad, thats why the cel was thrown?
Jeff1119 is offline
post #11 of 25 Old 12-30-2014, 06:52 PM
luckyse7ens
2010 XK Commander
Did you ever pull the codes? Some sellers list 3.7L and 4.7L throttle bodies the same. The problem is that 4.7L Tb's are larger. Which do you have?
Black WK Club #152
luckyse7ens is offline
post #12 of 25 Old 12-30-2014, 06:57 PM Thread Starter
Jeff1119
2017 WK
i mean this was a month ago so i no longer have the throttle body with me but it was the 3.7 one. And i didn't bother too obtain the codes at the time since i assumed it had to be programmed. Came off an 07 commander. Was gonna order a new one off of eBay for 65 bucks
Jeff1119 is offline
post #13 of 25 Old 12-30-2014, 10:49 PM Thread Starter
Jeff1119
2017 WK
does anyone know how many pounds the 4 bolts on the throttle body should be torqued too?
Jeff1119 is offline
post #14 of 25 Old 12-31-2014, 06:29 AM
caulk04
2008 WK
I don't know, never saw a need to torque that bolt. Just watch the gasket compress and once it's all seated, just a tick past to keep it from coming loose...if that makes any sense.
caulk04 is offline
post #15 of 25 Old 12-31-2014, 06:34 AM
Craigyfm
2006 WK
I've just re read your post about spraying down the TB. If you go to WKjeeps maintenance schedule it mentions"not" to clean the part. This may have been your issue. Good luck.
Craigyfm is offline
