Question about tire pressure sensors - JeepForum.com
post #1 of 11 Old 08-09-2013, 02:16 PM Thread Starter
metalhead
2011 WK
I was wondering if anyone with an 08 grand cherokee has run into this problem. I work at a jeep dealership and replaced 4 tire pressure sensors on an 08 grand cherokee laredo. The computer would not recignize the sensors. Normally we would go into the witech scan tool and program the id numbers for the new sensors. When I pluged in the 08 grand cherokee there was no tab availiable to enter the id numbers for the new sensors. Yet the other day I replaced a sensor on an 07 grand cherokee and was able to program the new sensor id number. We have contacted chrysler about it and they had to get engineers involved. I was curious if anyone has run into this and if it was able to get fixed.
Thanks
metalhead is online now
post #2 of 11 Old 08-10-2013, 10:27 AM
jediknight
2008 WK
Try to go in the wcm ecu there you'll be able to access the tpms id. I think you can also set the threashold presure in there.
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #3 of 11 Old 08-10-2013, 02:23 PM Thread Starter
metalhead
2011 WK
Thats what I did and there was nothing to click on to program the new sensors. On the 07 grand cherokee I worked on several days ago you were able to go into the wcm and program the new sensors. Me and another tech worked on it most of the day and could not figure it out.
post #4 of 11 Old 08-10-2013, 04:22 PM
1dzlwk
2007 WK
Program the new sensors? According to VDO (the OEM sensor manufacturer for my '07), all you have to do is drive around for awhile and the system will figure out the new sensors all on it's own. Is this not correct?
____
Bob
1dzlwk is offline
post #5 of 11 Old 08-10-2013, 04:55 PM Thread Starter
metalhead
2011 WK
Well on the 08 I worked on I put almost 20 miles on it and it would not figure out the new sensors. I know I installed the right sensors because the parts department checked the part numbers with Chrysler. Some of the techs I work with say its the rubber sensors that cause the problem but I installed the metal sensors and the problem was still there. When you look at the data stream in the scan tool the original sensor id numbers are still there. To be honest Chryslers help center is not that great. That's why I started this thread. I have gotten some good info from forums. I wanted to see if anyone on here has a similar issue with a dealership installing new sensors and if they were able to fix the problem.
post #6 of 11 Old 08-10-2013, 05:10 PM
jediknight
2008 WK
Maybe the wcm ecu doesn't have the earliest update and needs a re-flash.... I think it was made bu Simens. Usualy its in wcm ecu miscelanius / other routine and there u can program sensor id. Check also on the home page for vehicle preparation.
post #7 of 11 Old 08-11-2013, 07:18 AM Thread Starter
metalhead
2011 WK
We did all that and still no luck.
post #8 of 11 Old 08-11-2013, 08:59 AM
GeeEssFore
We use a scanner called a bartech and have zero issues with all years.
06 Commander
GeeEssFore is offline
post #9 of 11 Old 08-12-2013, 08:23 AM
Ditchd
2009 WK
My experience exactly on an 09.
After a puncture and change around a couple of sensors wouldn't play. Drove a while and one comeback , pretty hacked off parked up overnight and in the morning after a mile or so driving the spare stopped reporting problems.
Are they ran by Microsoft or something
Ditchd is offline
post #10 of 11 Old 08-12-2013, 11:02 AM
jediknight
2008 WK
Here's another reference : http://www.jeepforum.com/forum/f67/tpms-1559298/
post #11 of 11 Old 08-24-2013, 09:28 AM Thread Starter
metalhead
2011 WK
Would you believe after 2 weeks after replacing the tire sensors the customer said the tpms light finally went out. I hate tire sensors. This one stumped me and chryslers tech support.
