Quadradrive II or Quadrtrac II? - JeepForum.com
post #1 of 21 Old 03-24-2009, 07:39 PM Thread Starter
pauld
2009 JK Wrangler
I looked at some 2009 GC's today at the dealer. I'm looking for a Hemi with QuadrdriveII. The 3 (2 LTD's & 1 Overland)I looked at all had the Quadradrive II badge by the shifter but said Quadratrac II on the sticker. What gives? Does anyone know? I really don't trust the dealer to tell me which is right.
pauld is offline
post #2 of 21 Old 03-24-2009, 07:54 PM
Texas WJ
Texas WJ's Avatar
2005 WK
Ouch. That's a mess. The Overland should be Quadra-Drive since I think they all are but as to the others if you can't trust the badge, or the dealer, I can't think of another way of sniffing the correct system out.
Texas WJ is offline
post #3 of 21 Old 03-24-2009, 08:16 PM
LJS8510
LJS8510's Avatar
2015 WK
Did you check the entire sticker?
The sticker may show both.
First what is standard, QuadraTrac II
and then
It may list QuadraDrive II as an option?
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #4 of 21 Old 03-24-2009, 09:22 PM
CanDieselJeep
2008 WK
Our Diesel spec sheet on the unit we just bought had Quadtrac 2 as standard eqipment and Quaddrive 2 as part of the options list further down on the build sheet.
CanDieselJeep is offline
post #5 of 21 Old 03-24-2009, 09:39 PM
Funtuzzi
2008 WK
Mine was exactly the same on the build sheet. I phoned Chrysler Canada, and asked them the same question. The response I got was, Quadra trac II is standard on your model, and was optioned out with Quadra drive II. Also mentioned that all Quadra drive II equiped Jeeps have the plague on the center console by the shifter.
I agree, Chrysler should have made this less confusing
Funtuzzi is offline
post #6 of 21 Old 03-25-2009, 01:21 PM Thread Starter
pauld
2009 JK Wrangler
and then
Yes I checked the whole sticker and so did the salesman. That is what was confusing.
pauld is offline
post #7 of 21 Old 03-25-2009, 01:29 PM
JMorash
2005 WK
If it says Quadradrive by the shifter bezel its gotta be quadra drive.
Most limited hemi models have QD2.
Standard on the Overland hemi.
Optioned on the Limited's with the 4.7 and the 5.7.
In most cases if a hemi wk says Quadradrive on the shifter bezel it is Quadradrive.
2005 WK 5.7L Hemi
HEMI Club Member #28
3.5 Rock crawler lift.265/65R17 Toyo AT SuperChips Flashpaq MDS delete
JMorash is offline
post #8 of 21 Old 03-25-2009, 01:52 PM
LJS8510
LJS8510's Avatar
2015 WK
I'd say that is confusing, but I agree with JMorash
"If it says Quadradrive by the shifter bezel its gotta be quadra drive."
LJS8510 is offline
post #9 of 21 Old 03-28-2009, 02:52 PM
Jerry Falletta
2009 WK
Ditto. The Overland has QuadraDrive II, as do most (if not almost all) Limiteds. Been looking at upgrading to a new Overland, so I checked this out.
Now... if I can find one in the color I want (Red Rock or Modern Blue)... definitely URI Green.
Jerry Falletta is offline
post #10 of 21 Old 03-29-2009, 07:48 PM
onlyone
onlyone's Avatar
2014 JK Wrangler
The QDII will show under optional equipment.
Thank you Jesus
2014 Wrangler Sport 1.5" spacers in front .75 rear, 1" BL 255/80/17 BFG KM2
onlyone is offline
post #11 of 21 Old 03-30-2009, 04:45 AM
DarrylFlynn
2006 WK
I do hope not!!!!!
DarrylFlynn is offline
post #12 of 21 Old 06-14-2009, 10:55 PM
jeeperjk
2009 JK Wrangler
Can someone post up a pic of where this identifying plaque is? I'm in the market for an '06-'09 WK and I want to make sure I get the QDII.
jeeperjk is offline
post #13 of 21 Old 06-14-2009, 11:00 PM
colinzj
2006 WK
Here you go: http://www.wkjeeps.com/photos/2005_wk_24c.jpg
You can see it at the bottom of the shifter bezel.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #14 of 21 Old 06-14-2009, 11:08 PM
Texas WJ
Texas WJ's Avatar
2005 WK
Sometimes dealers take decent enough interior photos where you can tell right away, other times not so much.
Texas WJ is offline
post #15 of 21 Old 06-14-2009, 11:30 PM
jeeperjk
2009 JK Wrangler
Thanks, that was quick!
So, it needs to have that badge (unless someone debadged it) to have the QDII, right? Thus far, I've been scoutin' for the little 4LO T handle. If I understand correctly, though, it could be QTII and have the 4LO, too, though, right?
jeeperjk is offline
do i have quadradrive or not? ronsaun ZJ Grand Cherokee Forum 2 10-01-2009 09:49 PM
Do i really want quadradrive? KWAG ZJ Grand Cherokee Forum 32 07-05-2009 08:41 PM
05 4.7 with quadradrive 20004x4TJ WK Grand Cherokee & XK Commander Forum 3 03-25-2008 04:34 PM
WJ Quadradrive with no FWD Lockport XJ ZJ Grand Cherokee Forum 10 09-11-2005 10:11 PM
Need help with QuadraDrive holyundrwr ZJ Grand Cherokee Forum 2 11-04-2004 07:28 AM
