Quadra-Trac I Questions - JeepForum.com
post #1 of 8 Old 04-12-2007, 09:31 AM Thread Starter
gsxr150
Last night we had a little snow, and I was playing around a bit with my rental. Here's a couple of questions for you guys.
1) With traction control on or off, I hear some noises like griding as the different wheels are trying to spin. Obviously that's normal, but what is going on?
2) Will the rear diff ever lock, or is it one wheel wonder...per say.
3) With traction control off, could a guy kick the tail end out? Not saying I want to beat my jeep just wondering if you can play without the brakes automatically kicking in.
Thanks
gsxr150 is offline
post #2 of 8 Old 04-12-2007, 10:08 AM
drewman141
Gas Guzzler
drewman141's Avatar
1994 ZJ
1 - Probably the ABS doing the Brake Assisted Traction Control
2 - Never, it is wide open. QD-II has the electronic LSD.
3 - Probably never on dry pavement but on an extremely slippery surface it is possible. With QD-II and ESP turned off I had to work extremely hard to get it to kick out. However I am trained on vehicle control and would not recommend doing these kinds of things in any SUV.
[SIZE="1"]2008 WK Overland HEMI - Modern Blue Pearlcoat
Fully loaded with slush mats of course.
MUST GO! 1994 Limited ZJ 5.2L V8 - Light Driftwood Satin Glow
It's a 94 5.2L Limited - trxus 33's on 15x7 steelies, 4.56s w/ front OX and rear trutrac, NP242 swap, novak shift kit, Kevin's ultimate 4.5" lift + ACOS, ARB front bumper w/warn M8000, rear tomkin machine bumper w/ tire carrier, kevin's hardore railz, kevin's ultimate tc skid, kevin's trackbar conversion, rusty's gas skid, flexalite efan, Kolak's performance ignition and brake upgrades. ViAir OBA, custom storage/sub box and I'm sure there's a bunch of other things I'm missing. Everything is a little over 3 years old with less than 10K miles. Looking to get around $4k.
drewman141 is offline
post #3 of 8 Old 04-12-2007, 11:58 AM
anerbe
I agree with drewman - in my QDII 5.7, you can slide it out on a wet surface, and even dry if the road is smooth enough, but with the 4wd, and the roll center, the vehicle reactions can be very twitchy and abrupt. i only recommend it in snow/ice conditions. the slight bias to the rear (few %) helps kick out the rear when the ground is slippery.
02 M3 - Sold
06 WK Ltd 5.7
anerbe is offline
post #4 of 8 Old 04-12-2007, 12:46 PM
goose1
to fully turn off the ESP you have to hold button for like 10 seconds. if you just tap the button it only turns off a portion of the ESP.
2006 Jeep Grand Cherokee Laredo (WK) 28E
4.7 V8, Quadra-Trac II, Black Exterior, Light Khaki Interior
Upgraded: Mopar Sport Utility Crossbars
2008 Jeep Patriot Sporkt (MK) 26E
2.4L, CVVTII, 2WD, Black Exterior, Dark Gray Interior
goose1 is offline
post #5 of 8 Old 04-12-2007, 12:49 PM
goose1
1 - 2 - Never, it is wide open. QD-II has the electronic LSD.
Really, QT-II has an LSD? i'm not complaining because that is my system, but i thought it just had BCTS like the QT-I. I'm real happy if that is true.
goose1 is offline
post #6 of 8 Old 04-12-2007, 03:16 PM Thread Starter
gsxr150
Ahh, that's what I was looking for...turning everything off.
Thanks for the replies...that was very helpfull.
gsxr150 is offline
post #7 of 8 Old 04-12-2007, 04:58 PM
drewman141
Gas Guzzler
drewman141's Avatar
1994 ZJ
My bad that was QD-I with the mechanical LSD. You are correct BTCS is what you have. I retract my original statement.
post #8 of 8 Old 04-13-2007, 05:53 AM
goose1
damn...i got all excited for nothing.
goose1 is offline
Quadra-Trac II Questions/Problems.. BigMikeWJ ZJ Grand Cherokee Forum 33 08-25-2010 07:13 PM
is quadra trac/quadra drive electronically controlled? dirtdad ZJ Grand Cherokee Forum 2 01-01-2010 04:45 PM
quadra drive II or quadra trac II 2008 WK ? bill.rivard WK Grand Cherokee & XK Commander Forum 12 06-16-2009 07:14 AM
quadra drive II or quadra trac II 2008 ZJ ? bill.rivard WK Grand Cherokee & XK Commander Forum 3 11-01-2008 04:52 PM
Possible Quadra-drive/Quadra-trac II binding problems orbornhitorn ZJ Grand Cherokee Forum 3 06-06-2007 01:21 PM
