Quadra-Trac I - JeepForum.com
post #1 of 11 Old 05-05-2007, 10:14 PM Thread Starter
code4code5
2006 WK
Quadra-Trac I
I've done a bit of wheeling in my day, but I recently sold the 91 "billy goat" Wrangler and got a 06 Grand with Quarda-Trac I. I was thinking that I wouldn't do much wheeling at this point in my life, but now I'm really curious as to what kind of capability I can expect from the system.
I'm looking for a little experience... has anyone done any wheeling with this system, and how did it work for you? Can I trust it on a trail rated "moderate," or should I stick to "easy?" Any input would be appreciated!
code4code5 is offline
post #2 of 11 Old 05-05-2007, 11:26 PM
T-Rated
T-Rated's Avatar
Which engine do you have? I have a 4.7 and have done "moderate" trails without going into low gear, but the QuadraDrive system I have does do a bit more for power transfer.
Regardless on the difficulty of the trail, though, you shouldn't be out alone. So with a buddy and a tow strap, give the moderate trails a try.
Jeep: 2006 Midnight Blue Grand Cherokee Limited 4.7L Bells Whistles
Mods: Tow Hooks Mopar & 4xGuard Skid Plates & Rock Rails Flowmaster 70 255/65R17 REVO's
T-Rated is offline
post #3 of 11 Old 05-06-2007, 09:34 PM
tednelson83
its ok with the 3.7, but i wanted to do more wheeling, so i screwed up when i bought it. i really wish i either had lower gearing or a lo range, but i have neither. i find i get stopped easily when running rougher obstacles at lower speeds, and i need to go faster than i would normally want to. i cant crawl stuff. personally i hate it. it works ok for light moderate stuff, and hill climes, and any thing a 2wd can do, but for the more rocky stuff it sucks. ... but thats my opinion, i just think it's the wrong vehicle for me.
Sacramento Alumni. ASE A6, A8, and L1 Certified. CA Smog License.
1993 Jeep Grand Cherokee Limited 5.2 4x4, IRO 3.5" lift, Spidertrax adapters, 32" BFG M/T's on 17" cragar soft 8's, Flowmaster muffler.
1987 Pontiac Fiero GT 2.8
Liberalism stems from the notion that it's entirely possible to pick up a turd by the clean end.
tednelson83 is offline
post #4 of 11 Old 05-15-2007, 09:37 PM Thread Starter
code4code5
2006 WK
Thanks for the input. I do have the 3.7 and we're planning an excursion for late July (when most of the snow should be melted off the trails in the Rockies west of Denver.) Nothing heavy, just a nice family trail. I'm looking forward to putting it through some paces and see what happens. I just hope I'm not too embarassed by the two TJ's that are coming! I can't wait to get a good Jeep nature pic, as is tradition with the five other Jeeps that have been in the family.
post #5 of 11 Old 05-16-2007, 01:08 AM
tednelson83
i went out last weekend on a higher-end moderate trail, and kept up just fine with my stock GC. i went over some stuff that surprised the hell out of me when i found i was able to make it over it! i had no idea it was capable of doing that. did some mild rock climbing, some articulation obstacles, some V-notch stuff, mild hill climbs. i am still only running the H/T street tires that my used WK came with, set the pressure at 16 front/20 rear(went too low on the first front tire by mistake, so we went with it) and even than the BTCS was working alot, but i can say that it works beautifully. i have had the thing since February, but this was my first club run with it, and i was floored by how well it did. i cant wait to see how well it does once i figure out how to change out the single speed transfer-case with a better one. one more thing, if you care about cosmetics, i suggest you be careful, and also armor the thing, i don't yet have rock rails, and came down hard on a rock and bent the fender really good. good thing i don't consider this thing to be the luxury car my dad thinks it to be.
post #6 of 11 Old 05-16-2007, 01:10 AM
tednelson83
oops, double post
i will add that i was able to keep up pretty well with the heavily modded Jeeps that were there, i even lead them at one point, and had an easier time with some stuff than they did, LOL!
post #7 of 11 Old 05-17-2007, 03:18 PM
Dabitz
2015 WK
I have the XK with the QT1, I am very impressed with what it can do. I knew from the beginning that the QT1 system is not a rock climber, but I am indeed very impressed on what it can do on deep snow, steep lose dirt hills, etc. For hardcore offroading you will need at least QT2.
QT1 will allow for the axles to travel at different speeds, so if your front axles slips, the rear kicks in with the torque. It is not a simple AWD system as most people might think where your only benefit is to have additional traction, it is more complex than that.
Dabitz is offline
post #8 of 11 Old 05-17-2007, 08:27 PM
tednelson83
yea, but it still sucks!
post #9 of 11 Old 05-18-2007, 10:20 PM
gornoman
2006 WK
If the trails are rated "Easy/Moderate/Difficult", as they are in some guidebooks, then the "Moderate" trails will require 4-Low for climbing. But different scales could have different requirements.
'06 Grand Cherokee Laredo 4X4 (26E), Steel Blue Metallic. 3.7, QTII Trail Rated, Factory Skids, Tow Package, RRO Rock Rails, 245-65-17 Bridgestone REVOS
Ipod, CB, Leather Steering Wheel, Fog Lights. Black Bear Road Alumni, Elephant Hill Alumni.
Blue WK Club Member #15
My other passion -
gornoman is offline
post #10 of 11 Old 05-19-2007, 07:59 AM Thread Starter
code4code5
2006 WK
Thanks, guys. Looking back on wheeling with my Wrangler, the main thing I got out of 4LO was speed control. With all the electronic TC gadgets in the GC, I'm really looking forward to being suprised of the capibility.
post #11 of 11 Old 05-19-2007, 11:59 PM
YB Normyl
YB Normyl's Avatar
2016 JK Wrangler
Weren't you looking into getting a QTII?
YB Normyl is offline
is quadra trac/quadra drive electronically controlled? dirtdad ZJ Grand Cherokee Forum 2 01-01-2010 04:45 PM
quadra drive II or quadra trac II 2008 WK ? bill.rivard WK Grand Cherokee & XK Commander Forum 12 06-16-2009 07:14 AM
quadra drive II or quadra trac II 2008 ZJ ? bill.rivard WK Grand Cherokee & XK Commander Forum 3 11-01-2008 04:52 PM
Possible Quadra-drive/Quadra-trac II binding problems orbornhitorn ZJ Grand Cherokee Forum 3 06-06-2007 01:21 PM
Difference between quadra trac and quadra trac II? loudog3114 ZJ Grand Cherokee Forum 1 10-10-2005 12:07 PM
