quadra drive II or quadra trac II 2008 WK ? - JeepForum.com
post #1 of 13 Old 11-01-2008, 04:54 PM Thread Starter
bill.rivard
Great deal on 2008 WK Limited but it has Quadra Trac II not Quadra Dive II. Colorado roads including lots of mountain snow but very little hard core off-road. Does it matter? Reliability? Thanks!
bill.rivard is offline
post #2 of 13 Old 11-01-2008, 05:48 PM
insmanblue
As long as it is a 4x4 the QTII should work fine. I would buy a set of good A/T tires though. I am going to buy the Goodyear Triple Treads within the next month as these received the number one all around rated tire at Tire Rack.
2008 Grand Cherokee Limited | Light Greystone Pearl | 4.7 | MyGig | HID | Silverstar | Tow Package | Body Color Grill | LED Tail Lights | 1.25" Wheel Spacers | Goodyear Fortura Triple Tread |
insmanblue is offline
post #3 of 13 Old 11-02-2008, 02:31 AM
Marcus86GLHS
+1.
tires, more than locking differentials, make the most difference thru unplowed snow. the 2008 stock tires are not the best snow tire available so a quick swap of a better snow tire in that QTII WK and you'll be fine.
2008 Hemi Grand Cherokee Limited 4 x 4, original owner, 29,000 miles
Marcus86GLHS is offline
post #4 of 13 Old 11-02-2008, 01:22 PM
onlyone
onlyone's Avatar
2014 JK Wrangler
I have the QTII and it is great. But keep in mind the QTII has 4 wheel traction control and works very well. Kinda like limited slips in the front and rear.
Thank you Jesus
2014 Wrangler Sport 1.5" spacers in front .75 rear, 1" BL 255/80/17 BFG KM2
onlyone is offline
post #5 of 13 Old 11-03-2008, 07:03 AM
Hangloose
2006 WK
Tyres make a big difference so if you will be using the GC in snow then good winter tyres or deeper tread A/T's would improve things.
QT2 utilises the electronic traction control which brakes the individual slipping wheel sending power back to the opposite wheel etc.... this system still has low ratio which locks the centre diff if needed so its very capable.
QD2 is better but you would need some really slippery terrain to prove it.....
Hangloose is offline
post #6 of 13 Old 11-10-2008, 11:35 PM
dsljeep
2008 WK
QT vs. GDII
I have a 1996 Grand w/QT1 and have driven in snow deep enough to push with the bumper wearing 30" studded open lug tread. It just keeps going. I once got in an icy situation on a slop with other vehicles while wearing my studs and walked out of what they slid into, the ditch and each other. One time I was off roading with a Chevy Blazer (80's) who was wearing 35" tires and he got stuck where I just plowed out of...using my Grand's open tread tires. I also have a 2008 Hemi Grand with GDII because I wanted the tops and paid for it too by a higher sticker price than I could have gotten one with QT. So far on pavement they both act the same. I believe QT is better but my other w/QT1 never failed to make me smile with confidece. With QDII you need to shut off the ESP system to enable deep snow driving because it will slow you down in snow (I'm told). QDII has 3 high range settings and one low range setting plus hill descent control (only while down hill driving). In low, the center diff is locked, each axel can fully lock as needed by the system, but you can't lock the front or rear yourself, they do the work for you. Hope this helps.
dsljeep is offline
post #7 of 13 Old 11-12-2008, 11:14 AM
Spotz
2008 WK
I live just north of Denver, and I have the QTII also. If you don't do any heavy-duty off-road driving then you'll be fine with a good set of A/T tires. Just be careful around the icy spots.
Spotz is offline
post #8 of 13 Old 11-12-2008, 11:31 AM
johnniebravo
2008 WK
QTII and a good set of tires will serve you fine. While the lockers may help in hard core off road situations, you will rarely be in a situation where you actually need them.
One disclaimer-in older Jeep models you could apply the poorman's locker by applying a little brake to ensure a slipping wheel actually got power. but with the WK's, the power is cut when you apply brake. However if the QTII system actually works properly, it will automatically apply brake power and give you an artificial light "limited slip" effect.
After selling my wrangler, I know my WK won't ever be off road (real trails, not fire roads) so I have no need for QDII. I will invest in a great set of tires instead.
2008 CRD GC
johnniebravo is offline
post #9 of 13 Old 11-12-2008, 12:11 PM
tbm5690
I'm in Monument and the QTII system not only funcrtions well but makes it FUN to whip around the icy turns with loads of traction. x2 on having a set of good tires.
2001 Grand Cherokee Laredo S/A package 4.7L V8
K&N high-flow filter, Airaid MIT, Flowmaster 50 catback
tbm5690 is offline
post #10 of 13 Old 11-13-2008, 01:31 PM
sabre364
2007 WK
QTII is fine for your uses. If you are doing little 'off road' driving and limiting it to gravel, dirt, unplowed 'seasonal use highways' - now that's an optimistic name, forest service trails, etc I would definitely recommend proper SNOW tires not A/Ts. Once you grind down your stockers, replace them with a good set of A/Ts (or even highway tires for your use) for the warmer months.
sabre364 is offline
post #11 of 13 Old 06-15-2009, 08:57 PM Thread Starter
bill.rivard
can't find it
Three questions:
1) Why can I not figure out how to start a thread with a new question on this site ???? I must be blind...
2) 2008 GC mygig might need nav update - dealer is clueless. I cannot find a recent (2009) discussion anywhere. Is this a dealer-installed update, a download from Harmon Becker, a purchased CD, what?? Seems it should not be that hard to find out! Mine is 9.713
3) What's the latest on overriding the in-motion lockout for address entry on the Nav? I see a hack out there but looks sketchy?
Sorry but 2 hrs of web and JF research yields almost nothing.
Any help appreciated!
B in CO
post #12 of 13 Old 06-15-2009, 10:21 PM
Texas WJ
Texas WJ's Avatar
2005 WK
At the bottom of the main WK/XK technical section page there's a blue "new thread" button:
I don't know much about MyGig, but it looks like they're on version 9.807.
Texas WJ is offline
post #13 of 13 Old 06-16-2009, 07:14 AM Thread Starter
bill.rivard
Thanks for the help!
Quadra Drive or Quadra Trac ?? TheTwins ZJ Grand Cherokee Forum 14 07-27-2014 09:04 PM
is quadra trac/quadra drive electronically controlled? dirtdad ZJ Grand Cherokee Forum 2 01-01-2010 04:45 PM
quadra drive II or quadra trac II 2008 ZJ ? bill.rivard WK Grand Cherokee & XK Commander Forum 3 11-01-2008 04:52 PM
Possible Quadra-drive/Quadra-trac II binding problems orbornhitorn ZJ Grand Cherokee Forum 3 06-06-2007 01:21 PM
Quadra-drive vs Quadra-trac II ///BHRpowered ZJ Grand Cherokee Forum 46 07-24-2006 12:05 AM
