Putting on the OME HD lift... couple questions - JeepForum.com
post #1 of 6 Old 12-24-2013, 10:02 AM Thread Starter
kiloniner
2006 WK
Hey guys. I'm in the process of putting on the OME HD springs and some rear shocks and have a few questions.
1. Does the bolt that goes through the strut fork that holds it to the strut have a nut on the other side? Or is it just the bolt? It looks like there should be a nut there, but I've put everything on the front back together and I don't see a nut for either side.
2. I know I'm supposed to do final torquing while the Jeep is on the ground, but does mean every single bolt, or just some bolts in particular like the struts and such?
3. Does anyone have a list of torque specs for each bolt that gets removed in the process of installing the lift? The instructions only have torque specs for the rear shock bolts. In particular for the front:
  • Sway bar bolt
  • bolt that goes through the strut fork and attaches it to the strut
  • Bolt that goes through the strut fork and holds ball joint in place
  • Nut that connects A arm to the hub
  • 4 bolts on top of the strut in the engine compartment
Sorry I don't know the correct names of everything. I would appreciate any corrections. Thanks
kiloniner is offline
post #2 of 6 Old 12-24-2013, 10:27 AM
fredkiller
2008 WK
1. The strut to clevis (fork) bolt doesn't have a separate nut, the clevis is threaded on one side for the bolt.
2. This is mostly for the bolts going through a bushing, but won't hurt for the rest. I found it was easier to do with some long extensions (especially for the clevis to control arm bolt)
3. see the pictures attached, top is for the front, bottom is for the rear, from the Factory Service Manual
2008 Jeep Grand Cherokee Overland Modern Blue, 3.0L CRD
Current mods: ARB Winch Bumper, TABOR 9K Winch, OME HD, Bilstein 5100 front and back, AEV JK Pintlers w/P265/70/17 GY Wrangler Silent Armor
Pending upgrades: pinch weld?
fredkiller is offline
post #3 of 6 Old 12-24-2013, 11:42 AM Thread Starter
kiloniner
2006 WK
Thanks fredkiller.
Anyone have a torque spec for the pictured nut?
post #4 of 6 Old 12-24-2013, 08:07 PM Thread Starter
kiloniner
2006 WK
Well I figured everything out. Except when I went to torque the rear right bottom shock bolt, it snapped. Now I'm stuck with no vehicle until the 26th.
Anyone have a part number for that bolt? Rear shock bolt with the partial shoulder.
Thanks
post #5 of 6 Old 12-24-2013, 08:34 PM
fredkiller
2008 WK
06506147AA or generically M12x1.75x80 (bolt size/thread pitch/length in mm)
post #6 of 6 Old 12-26-2013, 05:18 PM Thread Starter
kiloniner
2006 WK
Got everything together. Thanks again fredkiller
