Provent 200 catch can on CRD's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Provent 200 catch can on CRD's
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 11-09-2012, 12:02 PM   #1
bavmike
2008 WK
Has anybody ever used one of these in very cold weather like -20 to -50? I'm about to install one and my jeep spends quite a bit of time at those temps in the winter. I'm worried about it freezing up and blasting oil out of the dipstick or blowing seals.
2008.5 WK 3.0 CRD "S" Limited- Nov 2008 Build, JBA Fox racing front coil overs, JBA UCA's, ARB HD rear springs, Bilstein 7100 rear shocks, Level 8 Strike 5 wheels, 32" Cooper Discoverer STT tires, Liquimoly and Fuchs full synthetic in Diff's and tranny.
bavmike is offline   Reply With Quote Quick reply to this message
Unread 11-09-2012, 01:50 PM   #2
Radcrd
2007 WK
Not sure about the Provent but have witnessed several TDI's with Elephant hose mods and catch cans freezing up and blowing Turbo seals. I have owned 5 diesels (all modded) and personally say stay away from these things in cold climates. A bit of oil in your intake is not harmful. Just make sure your seals are not leaking above the Swirl Motor.
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline   Reply With Quote Quick reply to this message
Unread 11-09-2012, 02:08 PM   #3
bavmike
2008 WK
Thanks for the advice. I should of asked before ordering 1 I guess. Maybe I'll mod it to do a straight bypass in cold weather or something.
Unread 11-09-2012, 03:14 PM   #4
Radcrd
2007 WK
Or stay stock for winter and use it during summer only.
3 VW TDI's (sold)
Unread 11-10-2012, 02:20 AM   #5
DieselDevotion
2007 WK
I'd stay stock all the time with the updated seal of coarse and egr delete tuning and spray water/meth to keep everything clean.
But for you no water/meth in the winter
07 Grand Cherokee Limited 3.0L CRD QDII
89 5.9 Cummins powered F350
98 TDI Jetta
DieselDevotion is offline   Reply With Quote Quick reply to this message
Unread 11-10-2012, 05:50 PM   #6
MC_wk
2007 WK
Can you elaborate on water/methanol cleaning? I'm a CRD noob, I just bought mine.
07 WK CRD | QD2 | GDE ECO - DPF | OME HD | Moabs & Duratracs
98 XJ | FbG | Moabs & Duratracs
96 XJ
MC_wk is offline   Reply With Quote Quick reply to this message
Unread 11-10-2012, 09:40 PM   #7
torqrise
2007 WK
The CRD produces alot of underhood heat. I'd be surprised if you could freeze up the lines in a cold soak - unless you had alot of condensation in them. I've been running the Provent 200 for over 2 years now during some fairly low temps without any issues. My hoses are at minimum short run lenghts with the filter itself fairly close to the engine.
One thing about the Provent I would like to know - is the filter serviceable/cleanable? I've just been soaking out all the oil with paper towels and then sticking it back in the canister.
torqrise is offline   Reply With Quote Quick reply to this message
Unread 11-10-2012, 11:54 PM   #8
DieselDevotion
2007 WK
It's injecting a water and or water and methonal mix into the intake tract. It's a performance mod used mainly to lower egts (exhaust gas temps) and add power depending on the methanol concentration. But an added benefit is it keeps everything very clean in your motor, almost like pressure washing it. Another member on this forum (tnadanzig) is the only one I know of with a system like this on their Crd. He goes into his system briefly on a thread called "om642 performance mods" you'll have to search for it, sorry I can't link it I'm on my phone.
It's not for everyone as their is a small amount of customizing since there are only genaric kits. You need to find a place to mount the tank, plumb everything in, including tapping the nozzle somewhere into your intake, and wiring the controller. Again not for everyone but its what I would do!
98 TDI Jetta
Unread 11-11-2012, 04:24 PM   #9
bavmike
2008 WK
The filter is supposed to be replaced when clogged I think. I think I'm going to install a 3 way electronic valve that bypasses the provent when cold, then opens to divert flow through the provent once the temp warms up to say 20C. Sounds elaborate but it's fairly simple.
