Problems with liftgate glass - JeepForum.com
post #1 of 17 Old 05-04-2011, 01:11 PM Thread Starter
justinmiller930
2011 WK
I have been having problems with the liftgate's glass popping open on it's own. The dealership I purchased my 05 Limited from replaced the entire flipper module. After replacing it, the glass continued to come open on it's own. They then found that there was a problem with the wiring. After fixing the wiring, the glass is still popping open. Has anyone had this problem? If so, how do I fix it. The problem has been "corrected" as I disconnected all of the wires. I'd really like for it to work, especially since this vehicle is only a month old (to me). Any help would be appreciated.
justinmiller930 is offline
post #2 of 17 Old 05-04-2011, 01:31 PM
Budasac
2005 WK
Sounds like you may have an exposed or loose wire leading to the module that's grounding out when you're driving. I'm guessing it only happens when you're driving? But not if the Jeep is parked and running, or key on.
What about the push button on the lift gate? Was that also replaced or at least removed and inspected?
Budasac is online now
post #3 of 17 Old 05-04-2011, 01:57 PM Thread Starter
justinmiller930
2011 WK
It does it while in park and while driving. They replaced the entire module and then found a wire that was bad. They replaced it and it still opens up on it's own. I have it disconnected and hasn't done it since.
post #4 of 17 Old 05-04-2011, 02:14 PM
Budasac
2005 WK
That's pretty random. If you said "only when driving", I would definately think it's a wire that's moving around when you hit bumps. Does it ever open when it's parked with the keys removed? (liftgate glass still has power when the key is off.)
post #5 of 17 Old 05-04-2011, 02:17 PM Thread Starter
justinmiller930
2011 WK
Yes it does. It does it when it's parked and when I'm driving it. It's been a recurring problem that the dealership can't seem to get right.
post #6 of 17 Old 05-04-2011, 02:50 PM
jeffjs
Not sure why, but I immediately thought of "stuck key fob button".
jeffjs is offline
post #7 of 17 Old 05-04-2011, 02:50 PM Thread Starter
justinmiller930
2011 WK
Nope that's def. not the case!
post #8 of 17 Old 05-04-2011, 03:03 PM
Budasac
2005 WK
I'm still hovering around the "window" button on the tailgate. I was thinking something wacky w/ the relay that's controlled by the fob. But that get's disabled when the ignition is on.
However, the lift glass can be opened from outside in any situation, (driving, parked, key on/off). The "button" and the glass latch are two seperate parts. Did they also change the button? If not, that's where I would look. If they did, I would still look there. Check all the wires to and from the button and the latch mod for any sign of damage. It's the only thing that's active in all situations.
post #9 of 17 Old 05-04-2011, 03:06 PM Thread Starter
justinmiller930
2011 WK
Thanks a lot. I did try to push the button, and it wouldn't push in. Perhaps there's something wrong with the window button. I'll have to connect it all back up and see if that button works. Might be something they'll have to replace. Thanks for all of your help.
post #10 of 17 Old 05-04-2011, 03:30 PM
Budasac
2005 WK
No problem. That's why we're all here. Let us know how it turns out.
And welcome to the forum!
post #11 of 17 Old 05-04-2011, 05:05 PM Thread Starter
justinmiller930
2011 WK
Thank you very much! Nice to be here! I'll keep you updated.
post #12 of 17 Old 06-10-2011, 05:07 AM Thread Starter
justinmiller930
2011 WK
Finally, after 3 months, the problem has been fixed. The dealership I've been dealing with finally figured out that the push button for the window located on the liftgate itself was bad. The button was stuck and wouldn't come out. Glad it's finally fixed.
post #13 of 17 Old 12-30-2013, 09:51 AM
daxlw
2005 WK
Did you need to replace the button or anything? Or did you just have to clean around it to prevent it from sticking?
daxlw is offline
post #14 of 17 Old 01-02-2014, 01:18 PM
jbarrett
Was waiting to hijack and will now that OP had his issue resolved. I'm having a problem with my rear glass... it squeaks ALL the time. I can't stand it. It's like the glass isn't secure or something. Just driving down the road makes it squeak and I can't handle that annoying squeaking anymore. Anyone have any tips? I've messed around with the glass, doesn't seem to be loose or anything. I've tried to shim the glass to keep it from squeaking, but it still does. I'm going crazy - this WK has more noises than my TJ - I don't know how that's possible. Thanks.
jbarrett is offline
post #15 of 17 Old 03-08-2016, 05:21 AM
cybil7
2005 XJ Cherokee
liftgate window popping open
We just bought our 05 Cherokee Laredo yesterday and the damn window keeps popping open and sometimes when we aren't in it draining the battery. I googled it and some other Cherokee years had a recall for the same problem, it said that the switch on the outside door gets wet and shorts out or something. I haven't seen yet how people are resolving the issue but hope to find out very soon!!! real pain.
cybil7 is offline
Rear Lift Glass problems bizkit497 WJ Grand Cherokee Forum 15 01-14-2013 02:56 PM
96 liftgate stuck and various problems GatorDeve86 ZJ Grand Cherokee Forum 7 09-14-2010 06:56 PM
WJ Liftgate Glass Won't Open CrazyWalnut13 ZJ Grand Cherokee Forum 3 03-22-2009 12:48 AM
Simple question about glass on liftgate... whatpavment? ZJ Grand Cherokee Forum 9 07-21-2008 09:25 PM
liftgate and glass dont lock GRDCHRKE555 ZJ Grand Cherokee Forum 1 10-11-2006 05:04 PM
