11-28-2008, 03:13 PM
#1
Problem with joystick on REC navigation radio
This may sound silly, but I'm having trouble with not being able to use the joystick for the navigation system. This is the controller on the right side, about 4 from the top, underneath it says "zoom". When I push up on it, for example, nothing happens; what should happen is that the cursor either moves up, or the view moves up. Same whatever direction I go. No ability to zoom in or out either. It becomes a problem because I can't even change options for navigation, rendering it virtually useless. I'm not covered under factory warranty anymore. Any ideas how to fix this? Is this something someone at the dealership can fix? Do I have to buy a whole new unit? Maybe it just needs cleaned? Thanks in advance
11-28-2008, 03:43 PM
#2
Found answer
Found the answer, here is a good writeup for anyone with a similar problem:
http://www.300cforums.com/forums/tec...tml#post744703
Haven't tried the fix yet, getting ready to go out of town for holiday weekend
Cheers!
02-13-2009, 09:08 AM
#3
GPS Joystick faulty
I have a Grand Cherokee Limited w/Alpine GPS. The joystick has broken twice. the first time it was covered under warranty and they replaced the unit. Now it's not covered under warranty and 2 dealers have said I need to replace the whole unit for $2400! just because the joystick is bad? I've tried to go directly to Alpine, buut they said I need to go through a dealer. DOES ANYONE HAVE ANY IDEAS?
I really like this car but this is really frustrating!
02-13-2009, 11:06 AM
#4
might be a silly suggestion but if you have the steering wheel controls for this unit you can operate all of the Nav functions from the steering wheel.
press and hold both buttons on the wheel and the unit switches to steering wheel control
02-13-2009, 12:06 PM
#5
there is a write up somewhere on how to get a new one, it may be the link above but it looks like it's been moved.
found it...
http://www.lxforums.com/board/showthread.php?t=71415
same thing is happening to mine, try pushing in then moving the joystick. it's my temporary fix.
GET DIRTY!!
2007 Overland - Volant CAI, Firestone Destination A/T 245/70/17
HEMI CLUB MEMBER #18
02-22-2009, 01:03 PM
#6
Thanks guys. I'll give it a try.
02-23-2009, 08:32 PM
#7
i never knew you could use the steering wheel controls!!! I hate leaning forward to navigate the navi.
and my life just got a bit more lazy.... haha
-Mike
2008WK Overland | QDII | Stock... for now.
"The proper water entry and travel speed is 5mph"
BLACK JEEP SOCIETY MEMBER
11-02-2009, 02:41 PM
#8
Thanks....had it three years and the joystick just went out this summer; went to change the clock and got frustrated. I now have "renewed" likeness for the NAV system...thanks so much for the info!
11-02-2009, 08:02 PM
#9
I just got my '06 GCO about a month ago and the joystick is starting to go out on it. I just ordered and received both types (4 way and 8 way) and will be changing it in the next week or so. As said above the instructions are on the 300C Forum. I got my joysticks from OnLine Components. This link will list both the standard and the alternate. Doesn't look like too much work. I've already had the Nav. Unit out to check model and serial numbers. Mine apparently was built about a month before they starting installing the new "improved" joysticks. Bummer!! Why didn't they use touch screen like Garmin??
ALPS ELECTRIC RKJXT1E12001 is in stock! | Buy RKJXT1E12001 | RKJXT1E12001 | Onlinecomponents.com
12-31-2009, 07:38 AM
#10
I recently did this to my REC. It took a bit of time but worth it. Go slow. The hardest part was de-soldering to get the old one loose. If you have any questions feel free to email me daxlw@hotmail.com
01-15-2010, 08:05 AM
#11
Get the 8-way joystick. With the 4-way you loose the possibility to scroll in the map. Anyone who knows which leds are used for the buttons?
WH 2010 CRD. Bilstein shocks, Rustys 2" BB front, OME HD springs rear. 265/70x17
04-16-2010, 10:20 AM
#12
You are freaking awasome, i bought my jeepp 1 year ago and i lost the joystick, went and visit all dealers in NE, IA and WI, i can't believe no one of them has told me about the control in the wheel, i was just about to buy the whole unit, spent a lot of time trying to figure out how to fix it and even replace. MUchas gracias amigo.
#13
06-09-2010, 12:41 AM
#14
I just came in to thank drysuitdiver as well. Just bought a jeep with nav, and joystick not functioning - the steering wheel trick works great. Very much appreciated!
06-09-2010, 09:55 AM
#15
Since my earlier post back in November, I've replaced the joystick on my REC unit. If you have a little electrical and soldering ability it's not too tough. The hardest part is getting the old one off the circuit board. Once that's done, installing the new one is cake. Whole job took me about an hour and a half, from removal to reinstallation, and total cost was under $50. I masked off the joystick area on the board to avoid getting splashed solder on other parts. Also, be sure to remove all CD's before removing the unit. Any questions, let me know.
