Problem with C/T button - JeepForum.com
post #1 of 9 Old 04-18-2014, 09:21 PM Thread Starter
borderpatrol420
2005 WK
Hey everyone,
I recently purchased a 2005 Jeep Grand Cherokee Limited and I've been messing with some of the buttons. I was changing a few of the settings like turning off the horn when I press the lock button and so on, but I noticed when I push the C/T button, nothing happens. I know this is supposed to cycle options between my compass, thermometer and such, but it's not working. Any suggestions? Should I just take the console apart and see if there's a loose wire or is there another spot I should check first? The button also doesn't feel like the others when I push it. There's a little resistance from the other buttons, but there seems to be a bit more when I push my C/T button. Any thoughts are greatly appreciated. Thanks.
borderpatrol420 is offline
post #2 of 9 Old 04-18-2014, 09:36 PM
joshmantesso13
2007 XK Commander
you mentioned that the button feels different, your best bet would be to take the switch panel apart to get a look inside.
possibly the rubber dome under the button is worn out? it has a small contact inside it and when depressed it contacts the circuit board, which should bring up the compass/temp.
thats just my guess
joshmantesso13 is offline
post #3 of 9 Old 04-18-2014, 10:19 PM
Pyroman_28
2006 WK
I'd lean towards the button as well seeing as the screen will display all the other information without issue.
'06 WK 4.7 Limited - OME, Bilsteins, AFE, Magnaflow, Superchips, 32's
Pyroman_28 is offline
post #4 of 9 Old 04-18-2014, 10:26 PM
Jtav2012
2005 WK
Originally Posted by borderpatrol420 View Post
I know this is supposed to cycle options between my compass, thermometer and such.
Just throwing this out there, when I press my C/T button (in my 2005) it JUST goes back to the Compass/Temp display. I can hit it all I want, it won't do anything else. It doesn't cycle through anything.
Jtav2012 is offline
post #5 of 9 Old 04-18-2014, 10:57 PM
zeds_dead
2005 WK
Originally Posted by jtav2012 View Post
just throwing this out there, when i press my c/t button (in my 2005) it just goes back to the compass/temp display. I can hit it all i want, it won't do anything else. It doesn't cycle through anything.
x2
Everyday, something new you want to do. Disease of Jeeps.
zeds_dead is offline
post #6 of 9 Old 04-18-2014, 11:06 PM
Mitkch
2007 WK
x3
Black WK Club #138
Mitkch is offline
post #7 of 9 Old 04-19-2014, 07:40 AM
Shafer57
2006 WK
x3.5
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline
post #8 of 9 Old 04-19-2014, 11:20 AM
colinzj
2006 WK
x4.25. C/T does one thing: displays the Compass and Temperature screen.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #9 of 9 Old 04-19-2014, 04:59 PM
CavallinoRed
2006 WK
x5
If you are in the "Step" or "Menu" mode, the C/T button will change display to Compass and Temp. If you are already in CT mode..it does nothing. That is unless you are in park and hold for 5 seconds, then will put you in Compass calibration mode. This is used to correct the difference between magnetic north and geographic north.
CavallinoRed is offline
