Por-15 - JeepForum.com
post #1 of 10 Old 04-15-2014, 09:58 AM Thread Starter
DarthJeep
2005 WK
Por-15
I'm starting to get some rust on the undercarriage of my Wk and thinking about painting it. I've been hearing about this POR-15 product and heard great reviews. Anybody here have any experience with it on their Wk/Xk?
Build Thread -
Black Wk Club 166
DarthJeep is offline
post #2 of 10 Old 04-15-2014, 12:17 PM
tnadanzig
tnadanzig's Avatar
2007 WK
I coated most of the undercarriage on my 2008 WK with POR-15. I cleaned it really well. Used the metal prep on actual rust areas with a wire wheel and brush. Be careful because the metal prep will ruin paint. Applied several coats of the Por-15 and when the last coat was tacky I covered all it with nice 3M rubberized underbody coating. That has lasted for the last couple years with keeping it rust free. I plan on touching it up and reapplying every three years or so. In Iowa they go crazy with the salt applications so its nice knowing my Jeep won't totally rust out on me. Plus the Jeep is a daily driver and doesn't get washed as much as it should in the winter.
CB Engineering
CB-engineer.com
2014 WK2 EcoDiesel - CBE Parts
2008 3.0L CRD WK LTD - GDE Tune 3.07 gears
2007 3.0L CRD WK LTD - Go Fast Parts
2005 KJ CRD - GDE Tune
tnadanzig is offline
post #3 of 10 Old 04-15-2014, 12:36 PM Thread Starter
DarthJeep
2005 WK
So after I apply the POR-15, do I paint over it with something like Rustoleum?, not a fan of rubber coating.
Build Thread -
Black Wk Club 166
post #4 of 10 Old 04-15-2014, 01:43 PM
caddydaddy
2007 WK
POR-15 works fine by itself. I've used it on other cars. Great stuff!
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
200,000+ miles!
caddydaddy is offline
post #5 of 10 Old 04-16-2014, 11:00 AM
tom19511
2014 WK
Mine has rust inside the fender on both sides, behind the foam insert and the wheel well. This summer I want to clean and use POR-15 inside. I also used it on my Cherokee Country about 6 years ago on the floorpans..It worked great.
Tom
tom19511 is offline
post #6 of 10 Old 04-18-2014, 09:16 AM Thread Starter
DarthJeep
2005 WK
Can I just paint over bolts with this stuff like normal paint? Like the rear dif bolts and drain cap?
Build Thread -
Black Wk Club 166
post #7 of 10 Old 04-18-2014, 11:38 PM
caddydaddy
2007 WK
Yes, I've done that.
2" RC lift
200,000+ miles!
post #8 of 10 Old 04-19-2014, 07:35 PM
suzieque
2008 WK
I did my suspension and rear differential with por15. Holding up quite well after a winter of sand and salt. I didn't top coat it with anything. The thing about por15 is that it doesn't have any UV protection so any parts in direct sunlight will change from gloss black to flat black. That is why you have to top coat parts exposed to sun.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #9 of 10 Old 04-20-2014, 08:47 AM Thread Starter
DarthJeep
2005 WK
I just wasn't sure if painting over dif bolts would give me a hard time removing them. This stuff seems pretty tough!
Build Thread -
Black Wk Club 166
post #10 of 10 Old 03-10-2015, 10:42 PM
ggrassmid
2008 WK
I know this thread is a year old. But wondered how everyone product is holding up this past year so far.
My plan is to wire brush mine, the use the POR15 cleaner and metal prep, the to use Chassis Saver on top of it. The chassis saver is suppose to stop rust, seal it, and leave a flexible coating that isn't supposed to crack chip or peel. I also figured after that I would try and 3M Bedline or similar spray areas that look like would get beaten and rubbed more often than any other place.
ggrassmid is offline
