Popping sound.... - JeepForum.com
post #1 of 15 Old 01-27-2013, 11:40 AM Thread Starter
talkboxier
2006 WK
Popping sound....
So my 2006 grand cherokee laredo is making a popping sound. It only pops once and it happens when I start rolling in 1st gear upon every start. When the car stays on it doesn't pop at all and runs fine. Does anyone have this problem as well? I am a little concerned.
talkboxier is offline
post #2 of 15 Old 01-27-2013, 12:38 PM
mykdee311
2005 WK
is the pop coming from the front or rear, either side?
05 WK Limited, QDII, Hemi, Superchip, OME HD Lift, JBA UCA & disconnects, 4xGuard (Belly, Sliders, Rear Sliders, Diff), 255/75R17 on Moab's w/ 1.5" Spacer, Thule M.O.A.B. Basket
03 3500 Cummins, 79 Mustang 2.5T Stroker, 63 F250 428 4x4
mykdee311 is offline
post #3 of 15 Old 01-27-2013, 01:16 PM Thread Starter
talkboxier
2006 WK
it sounds like it is coming from the front right side to me.
post #4 of 15 Old 01-27-2013, 01:50 PM
trax95008
2006 XK Commander
Have you noticed if it happens when the wheels are straight or only when turned and starting off?
trax95008 is offline
post #5 of 15 Old 01-27-2013, 01:55 PM Thread Starter
talkboxier
2006 WK
from what I have see so far it happens when it is straight or turned. it usually pops on a cold start and at around 5-10 mph.
post #6 of 15 Old 01-27-2013, 02:20 PM
trax95008
2006 XK Commander
Does it sound like a mechanical pop like something is loose, or an ignition pop from the motor?
post #7 of 15 Old 01-27-2013, 11:23 PM Thread Starter
talkboxier
2006 WK
like a mechanical pop like something loose. Idk but it sounds like somewhere near the tires or possibly one of the supports for the front diff. but I cant see any damage anywhere tho :/ is there any specific areas I should look?
post #8 of 15 Old 01-28-2013, 08:21 AM
trax95008
2006 XK Commander
Here is a thread that I was involved in and fixed my problem. Read it and see if it describes your problem
http://www.jeepforum.com/forum/f67/t...d-pop-1421373/
post #9 of 15 Old 01-28-2013, 11:14 PM Thread Starter
talkboxier
2006 WK
thanks. I will try this out. ill post if i still have problems.
post #10 of 15 Old 01-31-2013, 11:46 PM Thread Starter
talkboxier
2006 WK
well I tightened it but it didn't stop the popping. I got a little stiffer steering which I don't like. I went to set it back and the bolt stripped on me. Where can I find a replacement bolt?
post #11 of 15 Old 02-01-2013, 09:03 AM
trax95008
2006 XK Commander
Did you use a e-torx socket or a 12 point?
post #12 of 15 Old 02-01-2013, 10:38 AM Thread Starter
talkboxier
2006 WK
I used a 15mm 12 point, and the sucker got rounded.
post #13 of 15 Old 02-01-2013, 12:10 PM
tfranzone
2008 WK
usually sway bar end link bushings.. cheap replacement. they should take the knock/pop away.
2008 4.7L V8 WK --- BLACK, 2" Daystar Lift, 1.5" Spidertrax Spacers
Cooper Discoverer AT3 265/70/17, Pinch Weld Mod, Black Shorty Antenna
25% tint, PD's Wheels & Emblems, Fogs, Weathertech Digital Liners,
Drop in K&N
tfranzone is offline
post #14 of 15 Old 02-02-2013, 04:55 PM
cherokeenc
They were the cause of my issues, only happened when turning or starting off from a dead stop.
ಠ_ರೃ
"No self respecting man in North Carolina goes anywhere without beer."
2002 Jeep Wrangler, 3.5inch RC, 33x12.50 Duratracs, Warn X8000i, other fun stuff
1993 Chevrolet K5 Blazer, 263k miles, lots of noises, manifold leak, clearly a Jeep in disguise
Originally Posted by SunDevilJeeper View Post
Does it count if I wave my weiner instead, or is that no bueno? Cause I like to air it out sometimes and ya know... yeah...
cherokeenc is offline
post #15 of 15 Old 02-02-2013, 11:14 PM
trax95008
2006 XK Commander
Get your hands on the proper tool. You read through the thread I linked you to right?
1st , laredo , noise , pop , start
