po700 and p0841 - JeepForum.com
post #1 of 8 Old 08-20-2014, 09:50 PM Thread Starter
94jeepman
2005 WK
po700 and p0841
hey guys im getting these two codes when I hooke the obd2 reader to it the p0700 transmission control system (malfunction indicator light request) and p0841 LR pressure switch rationality. and it also goes into 3rd gear when I put it in drive. the jeep does not move at all in any gears. did some research on the p0841 sounds seems like it can be multiple things. any help would be nice right now.
94jeepman is offline
post #2 of 8 Old 08-20-2014, 09:56 PM Thread Starter
94jeepman
2005 WK
from the research I did and what I can understand the vehicles that can still move are usually filter problems causing lack of pressure.
post #3 of 8 Old 08-21-2014, 10:00 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
from the 2005 WK factory service manual-
P0841-LR PRESSURE SWITCH RATIONALITY
•When Monitored:
Continuously with the ignition on and engine running.
•Set Condition:
The DTC will set if the LR Pressure Switch reads open or closed at the wrong time in a given gear.
Possible Causes
LOSS OF PRIME AND/OR TRANSMISSION CONTROL RELAY DTC PRESENT
LOW FLUID LEVEL
LOW LINE PRESSURE
REVERSE CARRIER SNAP RING DISLODGED
CRACKED OR MISINSTALLED PRIMARY OIL FILTER OR FILTER SEAL
STICKING MAIN REGULATOR VALVE IN PUMP VALVE BODY
NO. 1 CHECK BALL CUT OR DAMAGED
WIRING AND CONNECTORS
(T50) LR PRESSURE SWITCH SENSE CIRCUIT OPEN
(T50) LR PRESSURE SWITCH SENSE CIRCUIT SHORT TO GROUND
(T50) LR PRESSURE SWITCH SENSE CIRCUIT SHORT TO VOLTAGE
TRANSMISSION SOLENOID/TRS ASSEMBLY
POWERTRAIN CONTROL MODULE
JeepCares is offline
post #4 of 8 Old 08-21-2014, 10:22 AM
Tcolin2351
2006 WK
I had the filter issue, it was cracked. Pretty simple fix
06 LJ - Stock for now
Tcolin2351 is offline
post #5 of 8 Old 08-21-2014, 10:18 PM Thread Starter
94jeepman
2005 WK
what did your jeep do when it was cracked?
post #6 of 8 Old 08-21-2014, 11:07 PM
Tcolin2351
2006 WK
Could move shifter from park to drive but would engage in drive or reverse. Like it was in neutral
post #7 of 8 Old 08-22-2014, 05:04 AM
caulk04
2008 WK
It's in limp mode.
You'll need to either start digging and look for a problem or buy/borrow/steal a better scanner that can pull the trans specific codes to diagnose further.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #8 of 8 Old 08-23-2014, 07:06 PM Thread Starter
94jeepman
2005 WK
•When Monitored:
•Set Condition:
Possible Causes
LOW FLUID LEVEL
LOW LINE PRESSURE
where did you find this info? or do you know what this part means
