Please tell me I'm not crazy! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Please tell me I'm not crazy!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 01-21-2013, 04:05 PM   #1
caiati
2006 WK
Hey guys... First of all let me start by saying that I've had my WK since June and I haven't even put 5,000 miles on it. I have a company vehicle so fortunately my personal vehicle only gets used on the weekends. I meet one of my co-workers every morning at a halfway point so he doesn't have to waste gas money. I always take his vehicle home and give him the company truck to help compensate for gas. With that said, he has a 2001 WJ with the 4.7. It is NOT an H.O. motor but it seems like it has more power than mine. He has 178,000 miles on his and has had it for over 10 years. Still the original motor. He put a flowmaster muffler on it and a K&N CAI years ago. He also did a teraflex 2" coil over lift with 265's. I did a RC 2" lift with 265's. Virtually its the same drivetrain besides the transmission. The only thing he has different is the CAI. I can't see the CAI making that much improvement. My problem is that my transmission is constantly searching through gears. It seems like I have to make it downshift to have sufficient power. I know it's a different transmission with somewhat of a "seamless" shift, but it is quite aggravating. I'm not a teenager looking to drag race by any means but it is quite depressing when my 2006 seems like it has less power than the 2001. My question is this: What can I do to see an increase in power/throttle response and a more responsive transmission?
Will spark plugs make any difference? I know about doing the tuner etc... but my goal isn't to have MORE power than his, but figure out why mine seems to have less power. What about flashing the PCM? Any suggestions?
2006 Jeep Grand Cherokee, 4.7L V8, QTII, 2" Rough Country Lift, 265/70/17 Nitto Terra Grapplers, Magnaflow muffler w/ resonated tip
caiati is offline   Reply With Quote Quick reply to this message
Unread 01-21-2013, 04:15 PM   #2
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
You need a tuner to recalibrate for the bigger tires.
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 01-21-2013, 04:32 PM   #3
caiati
2006 WK
That's it? I'm not doubting that a tuner will help but I know that the 2001 wasn't tuned at all so why would it feel like it has more power? His 2001 has the same size tires as mine. What tuner do you suggest?........ Also, when I have it in tow/haul mode, it seems to react much better and the tranny doesn't feel as mushy...
Unread 01-21-2013, 04:55 PM   #4
caiati
2006 WK
Instead of buying a tuner, can I have the dealership reprogram for bigger tires?
Unread 01-21-2013, 05:03 PM   #5
trax95008
2006 XK Commander
This does not address the OP's issue. Recalibrating for larger tires will not gain you more power. I'm pretty sure a dealer will NOT recalibrate for larger tires for you. Have you compared the weight of the two vehicles? Your WK may be a little heavier than the WJ
trax95008 is offline   Reply With Quote Quick reply to this message
Unread 01-21-2013, 05:09 PM   #6
sk1er18
2007 XK Commander
The WK is heavier and has a lot more "nannies" due to the new computer controlled systems (throttle by wire). So although the engines/trans/gearing specs are very similar, the reduction in performance due to larger tires is more noticeable on the newer vehicles.
-Matt
sk1er18 is offline   Reply With Quote Quick reply to this message
Unread 01-21-2013, 05:15 PM   #7
caiati
2006 WK
That makes perfect sense. I guess I have to drop $300 on a tuner, although from what I've read there hasn't been any true power gains.
Unread 01-21-2013, 05:22 PM   #8
sk1er18
2007 XK Commander
Getting the shifting back to normal, correcting the speedometer, reading DTCs and turning off the annoying TPMS warning chime for airing down offroad are worth the $300 (flashpaq)... any minimal power gains are sort of an "added bonus" IMO.
-Matt
Unread 01-21-2013, 05:31 PM   #9
caiati
2006 WK
I'm assuming we are talking about the superchips 3875 flashpaq. If so, which tune on the flashpaq do you recommend? Meaning what octane etc...
Unread 01-21-2013, 05:40 PM   #10
sk1er18
2007 XK Commander
I did quite an extensive test with the different tunes and honestly found that my engine ran the best with the stock tune modified for tire size. Keep in mind that I have the Hemi that is already tuned from the factory for 89 octane. With the 91 octane performance tune the engine actually felt less responsive and I got worse gas mileage.
I'd do the same with the 4.7L.... try the stock tune modified for the tire size to give you a "baseline". Try to use the same gas station consistently and see how your performance/efficiency are for a good month or two, then step up to the 87 performance tune and see if anything changes, then repeat with the 91 performance tune. See what works best and then stick with it.
-Matt
Unread 01-21-2013, 05:42 PM   #11
caiati
2006 WK
Will do. Thanks for the advice. It may be a little while before I can actually buy the tuner but ill get there.
Unread 01-21-2013, 06:41 PM   #12
JeepN4KC
JeepN4KC's Avatar
Really? I believe he stated:
I didn't say the tuner would give him more power. It would reset the tire size so his speedo/odo/trip were calibrated right and his tranny would know what is supposed to be happening. His tranny is shifty because the Jeep thinks it has stock sized tires that are rotating slower.
~Mike~
Build Thread WK
Unread 01-21-2013, 11:55 PM   #13
trax95008
2006 XK Commander
I guess that's possible, however I went from the factory 29" tires to 32" tires for about 3 weeks before I had a chance to recalibrate and my tranny acted perfectly normal
Unread 01-22-2013, 09:29 AM   #14
Pac Man
You need to recalibrate for your tires.
The real issue is your jeep is 700-800 pounds heavier than his... So it will feel like you have 70-80 LESS horsepower than he does.
2007 Black Grand Cherokee
Hemi - QDII - OME - S4XC Hidden Winch Mount -Talon 9.5SR - Full Matrix - 265/70/17 Duratrac's - Pintlers- Superchips - Magnaflow - Airaid - 5000k HIDs - Lightforce HID's - 4xG Front Guard - 4XG Diff Cover
Pac Man is offline   Reply With Quote Quick reply to this message
Unread 01-22-2013, 07:22 PM   #15
caiati
2006 WK
Do you have the 4.7? Don't get me wrong, it doesn't feel totally gutless but I live in a very hilly/mountain environment so I have to make it downshift for the power needed to climb the hills.
