PLEASE HELP! 05 WK 3.7L Mystery sound! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > PLEASE HELP! 05 WK 3.7L Mystery sound!
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!
Unread 08-14-2014, 02:42 PM   #1
IamAMilli
Hey everyone. First post on the forum. I have a 2005 Grand Cherokee Laredo and today I noticed a sound in the front end (it's been really quiet running this far). When I let off the gas around 15 mph I hear a clunking/moaning sound coming from the front end. When it slows down further it turns into a sticky/squeaking sound. I've noticed it coming from the passenger side while passing cars in a parking lot when the sound bounces off of them. It's at 99,000 miles now. No suspension/transmission mods. Has anyone else had this problem?!
- Cucci
IamAMilli is offline   Reply With Quote Quick reply to this message
Unread 08-14-2014, 02:44 PM   #2
IamAMilli
Also it has a Quadra-Trac I I think (4wd all the time)
Unread 08-14-2014, 02:56 PM   #3
luckyse7ens
2010 XK Commander
Brakes?
Wheel bearing?
Ball joints?
CV?
Black WK Club #152
luckyse7ens is offline   Reply With Quote Quick reply to this message
Unread 08-14-2014, 03:06 PM   #4
IamAMilli
Thanks for your quick response! I'll check those things this weekend when I'm off. But what is a CV?
Unread 08-14-2014, 03:08 PM   #5
robpp
front diff mounts. there are 3 of them IIRC.
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline   Reply With Quote Quick reply to this message
Unread 08-14-2014, 03:15 PM   #6
IamAMilli
Is that what you think? Have you had this issue?
2005 Murdered Out WK 👍
Unread 08-14-2014, 03:58 PM   #7
luckyse7ens
2010 XK Commander
http://www.ehow.com/facts_7546522_cv-axle.html
Signs of Failure
Signs of failure for CV joints and axles including a metallic, clicking noise that is heard whenever the vehicle is turning or accelerating. This usually indicates that dirt and grime have gotten inside the CV joint bearings, which have leaked the lubrication fluid used in the joint. It is important to regularly check the CV boots for signs of decay and wear.
Read more : http://www.ehow.com/facts_7546522_cv-axle.html
I'd start with those things. Get it up in the air and move the tire around and see if you can get the noise to happen.
If the boot or torn or grease is visible around the CV joints thats likely your culprit.
WOrn bushings can cause squeaking also. PBlaster will make them swell and may help in the short term. Blast all your bushings with that and see if that fixes it.
Shocks wear out and squeak, my truck sounded terrible before replacing those.
Black WK Club #152
grand cherokee , noise , transmission , wk
