Platinum Plugs were the problem 5.7L Hemi Stall. - JeepForum.com
post #1 of 111 Old 02-27-2009, 12:19 PM Thread Starter
gsr181
I have a 07 Commander Limited with the 5.7L Hemi. I installed the Champion 3570 Platinum Plugs(that i bought at PEP Boys)and the car started to stall. I took the Jeep the the dealership explained to them what I had done and 30 days later and 3 different modules(PCM,FCM,WIN) replaced they blamed it on the spark plugs. They explained to me that the Hemi engine will not run properly with the Platinum Spark plugs only the original copper plugs. I am a ASE certified mechanic of 10 years and I have never heard of anything like this. All the mechanics at the dealership also have never heard of anything like this. It took an engineer form Detroit that they flew out to figure it out. Do any of you guys run Platinum Plugs? Have any of you heard of something like this.
Thanks for your guys Help
gsr181 is offline
post #2 of 111 Old 02-27-2009, 02:22 PM
Acidcold
2005 WK
That is the most ridiculous think i have heard, car related! I don't understand how a "Platinum" plug would stall the engine... i know a coil will but not a plug. good luck.
Acidcold is offline
post #3 of 111 Old 02-27-2009, 02:44 PM
LTrainGC
2005 WK
Sounds a bit far fetched, but I used the coppers when I did mine....
-Frank the Tank-
-2005 Jeep Grand Cherokee Limited-
- 5.7L HEMI/QDII/Superchips/AEM Brute Force/MBRP/RRO/Bilsteins/32s -
LTrainGC is offline
post #4 of 111 Old 02-27-2009, 03:39 PM
DarrylFlynn
2006 WK
SO Did putting Standard Original Copper Plugs back in sort this out, You didn't tell us?
Regards Darryl
DarrylFlynn is offline
post #5 of 111 Old 02-27-2009, 03:59 PM
Texas WJ
Texas WJ's Avatar
2005 WK
I've actually heard this before, that the Hemi sometimes doesn't like the platinum plugs. Can't tell you why, but if it came from the factory with copper then that's what I'm sticking with.
Texas WJ is offline
post #6 of 111 Old 02-27-2009, 04:18 PM
robpp
so is having a vehicle where you cant check trans fluids...
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline
post #7 of 111 Old 02-27-2009, 04:19 PM
robpp
PLUGS from WKJEEPS- what a mess
3.7 V8
Mopar (NGK) p/n SPZFR6F11G
(0.042 gap, 8 plugs, tighten to 20 ft. lbs.)
4.7 V8 (2005-2007)
Mopar (Champion) p/n SPRC12MCC4
(0.40 gap, 8 plugs, tighten to 20 ft. lbs.)
(NOTE: The 4.7L V8 engine is equipped with copper core ground electrode spark plugs. They must be replaced with the same type/number spark plug as the original. If another spark plug is substituted, preignition will result.)
4.7 V8 (2008-2010)
Mopar (Bosch Nickel Yttrium) p/n 5149050AB (intake side)
Mopar (Bosch Iridium) p/n 5149888AA (exhaust side)
(0.50 gap, 8 plugs, tighten to 20 ft. lbs.)
CAUTION: This engine uses TWO DIFFERENT types of spark plugs. A total of 16 plugs is used. The plugs are mounted in two rows (banks). The upper row is used on the intake valve side of the cylinder head. The lower row is used on the exhaust valve side of the cylinder head. The upper row uses Bosch Nickel Yttrium plugs. The lower row uses Bosch Iridium plugs. DO NOT INTERCHANGE THESE PLUGS.
5.7 V8 Hemi (2005-2008)
Mopar (Champion) p/n SPRE14MCC4
(0.045 gap, 16 plugs, tighten to 13 ft. lbs.*)
(*NOTE: The 5.7L V-8 is equipped with torque critical tapered design spark plugs. Do not exceed 15 ft. lbs. torque.)
5.7 V8 Hemi (2009-2010)
Mopar (Champion ?) p/n SLZFR5C11G
(0.043 gap, 16 plugs, tighten to 13 ft. lbs.*)
6.1 V8 Hemi
Mopar (NGK) p/n SPLZTR5A13
(0.50 gap, 16 plugs, tighten to 13 ft. lbs.*)
(*NOTE: The 6.1L V-8 is equipped with torque critical tapered design spark plugs. Do not exceed 15 ft. lbs. torque.)
robpp is offline
post #8 of 111 Old 02-27-2009, 05:50 PM Thread Starter
gsr181
Yea after installing the original copper plugs it fixed the problem but they stated tha the vehicle still might have issues with the WIN and PCM module.
gsr181 is offline
post #9 of 111 Old 02-27-2009, 06:04 PM
jeepsterjc
jeepsterjc's Avatar
1977 CJ8
Engineered obsolescence. Only original copper plugs? Well I get those'll soon cost as must as platinum/iridium/gold/jems/tritium and uranium now.
I have a 94 ZJ, 318 and I changed my platinums after almost 60000 miles... Yeah, yeah... but I did get my money's worth out of it!!
Did the cap rotor and wires at the same same. Runs like new.
The New Hybrid Scrambler Build :-)
The old '87 YJ LT1 350 Build
jeepsterjc is offline
post #10 of 111 Old 02-27-2009, 06:43 PM
Bavaqua
2005 WK
I used champion plats in my 03 hemi and never had issues
That sure is weird though...
Silver 2005 Grand Cherokee Limited with 5.7 Hemi loaded to the gills, Brute Force CAI, and Cherry Bomb Vortex muffler
Bavaqua is offline
post #11 of 111 Old 02-27-2009, 07:33 PM
Acidcold
2005 WK
What vehicle is that? my 4.7 has it.
Acidcold is offline
post #12 of 111 Old 02-27-2009, 10:14 PM
icecreamman
2005 WK
I have experience with this on another vehicle. On bimmerforums.com the concensus (which I have personally tested) is that my e36 bmw m3 only runs it's best with copper plugs. People that own them for a while end up back at copper plugs eventually.
It's possible. I will be putting factory material plugs in when I replace them in my 05 HEMI.
icecreamman is offline
post #13 of 111 Old 02-28-2009, 07:34 PM
danniboi
2006 WK
3.7 V8
Aren't the 3.7's a V6 not a V8 and require 6 not 8 plugs?
danniboi is offline
post #14 of 111 Old 03-01-2009, 05:56 AM
kentman
kentman's Avatar
2006 XK Commander
I don't buy it. Until someone explains to me based upon chemistry or some other sort of deterministic basis, I cannot buy that a different metal does not work. It is just electricity jumping the gap from a metal substance.
I will be installing platinum plugs in the Hemi very soon, and we will see if I have a spark issue or not. I have never had a problem with platinum plugs on anything else in the past. If I do have an issue, I will surely try to swap back to copper. I just do not believe that I will have an issue.
There must be something else happening in your situation. I would be worried about the gap size, the carbon build up in the chamber, and fuel injector spray pattern more so than copper versus platinum.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
post #15 of 111 Old 03-01-2009, 10:42 AM
Bavaqua
2005 WK
Kent, I went to plat. Champions in my 03 Ram with around
60 thousand miles on the stock copper Champs. I checked the
Gaps on the originals and they were all around .058-.064.
The plats worked great in my truck. Only thing I ever heard
People having issues with in the Hemis is using exotic multi-prong
Plugs.
Bavaqua is offline
champion platinum plugs? Dillonzj ZJ Grand Cherokee Forum 18 12-28-2007 02:58 PM
Copper, Platinum or Dbl Platinum Champion Spark Plugs?!? Jmila1901 ZJ Grand Cherokee Forum 3 12-03-2007 02:20 PM
NGK Plugs - V-Power or Platinum? FPKites ZJ Grand Cherokee Forum 1 05-07-2005 01:07 PM
Platinum Plugs and seafoam 01grander ZJ Grand Cherokee Forum 2 02-13-2005 10:16 PM
