Pinch weld mod question - JeepForum.com
post #1 of 5 Old 08-30-2013, 12:35 PM Thread Starter
Jeepforthewin
2010 JK Wrangler
I searched the other threads about this and havnt found an answer. What size rivets do I need to reinstall the fender liner? And also do we have to use the poly rivets of will steel or aluminum work to? I have looked at harbor freight and they were completely out and all the other store only carry certain sizes.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #2 of 5 Old 08-30-2013, 12:56 PM
Anon155
2005 WK
Almost every body panel is held on by those plastic rivets on most newer cars anymore. I wouldn't worry about using steel/aluminum if they used the plastic from the factory. Plastic is cheaper and easier to replace. I bought them in bulk online. They're a 1/4" in size. The ones you bought with the plastic rivet gun kit will work just fine. I believe they were the largest sized set in the pack. That's what I used when I first did the pinch weld mod. I'll post a link to the ones I bought later on, they come in packs of 25. I bought several packs along with the push retainers (used on the grill).
Rivets:
http://www.clipsandfasteners.com/1_4...p_p/a13750.htm
Push Retainers:
http://www.clipsandfasteners.com/Pus...pas1860-25.htm
05 Jeep Grand Cherokee: ORT 4X4; Khaki #55
Too many mod's to list...
Anon155 is offline
post #3 of 5 Old 08-30-2013, 01:05 PM Thread Starter
Jeepforthewin
2010 JK Wrangler
Thanks for the links! I ran out if time today to start and finish the project but I will check the sizes of the ones I currently have.
post #4 of 5 Old 08-30-2013, 03:20 PM
trax95008
2006 XK Commander
A metal rivet will NOT work at all! They don't expand enough. The plastic rivets function differently than a metal rivet. They expand about 4 times larger
trax95008 is offline
post #5 of 5 Old 08-30-2013, 07:52 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Use poly rivets - it's the right tool for the job.
6.3mm x 25.2mm
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
