PCV Valve? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > PCV Valve?
Alloy usa heavy duty ball joint kitsSPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!FS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 12-29-2011, 09:03 AM   #1
Briceronii
2006 WK
PCV Valve?
I have an 06 GC HEMI....do i have a PCV valve?
Thank you for you help!
Briceronii is offline   Reply With Quote Quick reply to this message
Unread 12-29-2011, 09:18 AM   #2
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Yes.
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 12-29-2011, 04:12 PM   #3
90grandoneer
2006 WK
Yes, it's located on a little black can on the passenger of the engine in the rear. Turn counterclockwise to remove and replace it. If you just bought it, no telling if it's ever been changed. Many folks don't do it. Also, take the intake tube off the throttle body and, with the engine off, manually open the throttle body butterfly and examine the backside of it. If it's as bad as most of them are, clean it (do a search for a "how to") and consider getting a catch can to preclude that from happening again.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline   Reply With Quote Quick reply to this message
