PCV Valve of 05 3.7L WK with Picture DIY - JeepForum.com
post #1 of 10 Old 02-20-2011, 10:13 PM Thread Starter
Macguba798
2005 WK
Did some extensive search and cannot find a good picture of 05 WK 3.7L PCV valve with DIY for beginner like me, so here it is.
Here is the parts number from the box.
Here is what it looks like.
New compared to old...the old one still have some clicks into it but it's slower because it is full of crud from years of passing crank case gasses.
PCV valve location...squigely red circle is where I disconnected it with flat tip screw driver, you can also disconnect it closer by the red arrow.
Once disconnected, turn PCV valve counter clockwise to the direction of the arrow. You have to move the AC hose out of the way to turn it.
When the end of the PCV valve is pointing downward, pull it out.
To install...allign the tab to the right push it in until you hear a CLICK.
Once clicked in you can now turn it clockwise and it will lock with bottom end facing rear of car.
Now install the short hose.
And your done.
I did mind with intake pipe off because I changed the spark plugs. Changed the oil also and the TC fluid.
I apologize if picture of ---- box is not allowed.
Macguba798 is offline
post #2 of 10 Old 03-08-2014, 04:04 PM
lowrider_34
2010 WK
What was the cost and where did you get it? I have a 2010 w/3.7. I had called dealership about another issue and asked for prices on plugs, PVC, serp belt and they came back with $25. AZ had 1 for somewhere under $5. Differences??
lowrider_34 is offline
post #3 of 10 Old 03-10-2014, 12:00 PM
JRLT
2010 WK
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #4 of 10 Old 03-10-2014, 01:46 PM
tom19511
2014 WK
Must of changed somewhere down the line. My 06 WK 3.7 looks like Macguba798's
Tom
tom19511 is online now
post #5 of 10 Old 11-11-2015, 10:06 AM
DHayes
2009 WK
Changed from 2008-2010 WK 3.7L
PVC Valve location changed from on the neck of the oil filler tube all the way to the other side of the engine toward the firewall. JRLT's Picture is what it looks like. My HAYNES manual lied and had me staring at the oil fill tube neck for like 5 minutes before realizing nothing was there. I have a 2009 WK 3.7L and my PCV valve looks just like JRLT's pic.
DHayes is offline
post #6 of 10 Old 07-22-2016, 07:19 AM
Billbo1970
2009 WK
DHayes, do you have a picture of where the PCV valve is? I also have an '09 3.7 v6 and can't find it! I also can't find the EGR valve, as I'd like to clean it
Bill
Regards,
Bill
www.frchobby.com
Billbo1970 is offline
post #7 of 10 Old 07-22-2016, 07:36 AM
JRLT
2010 WK
Battery side, toward the firewall.
JRLT is offline
post #8 of 10 Old 07-22-2016, 11:13 AM
Billbo1970
2009 WK
Thanks JRLT! Now, do you know where that darned EGR Valve is? I can't find it! lol
Regards,
Bill
www.frchobby.com
post #9 of 10 Old 07-22-2016, 01:02 PM
JRLT
2010 WK
Oh... crap... isn't it around the underside of the oil fill? Somewhere in that area... check Youtube, thought someone posted a vid.
JRLT is offline
post #10 of 10 Old 07-23-2016, 12:21 PM
Billbo1970
2009 WK
YouTube was the 1st place I checked, LOL. I see vids for the CRD, the 4.7, the hemi... nobody with a latter-half WK v6 though :/
Regards,
Bill
www.frchobby.com
PCV Valve on Valve Cover? Krayzie949 ZJ Grand Cherokee Forum 22 08-14-2011 06:08 PM
PCV Valve, tope of valve cover... random155 ZJ Grand Cherokee Forum 9 01-07-2009 11:15 PM
picture alivenkickin28 ZJ Grand Cherokee Forum 17 04-17-2007 07:50 PM
The picture says it all... slick2570 ZJ Grand Cherokee Forum 50 11-22-2006 02:35 AM
Picture help please justjeepin ZJ Grand Cherokee Forum 2 03-21-2005 11:34 AM
