Passenger side brakes sqeeking - JeepForum.com
post #1 of 11 Old 05-08-2012, 10:58 PM Thread Starter
Jhigz
2006 WK
Only while rolling (not while brakes are applied).. Goes away sometimes but it's really annoying, think there's just something in there or is it time to replace something?
Figured I should ask here before I make a move. Appreciate the feedback!
06 WK
Jhigz is offline
post #2 of 11 Old 05-08-2012, 11:03 PM
06WKHEMI
2006 WK
Check your pads usually the squeaking is a wear indicator or it could simply be a rock stuck in there
2006 Black wk overland HEMI QDII. OME HD bilstein struts with 58643 monroe load levelers RRO uca, afe cold air intake,hella 500FF behind grille, RC 1.5 wheel spacers s4xc cb antenna mount with 5ft firestik and midland 1001wx CB,265/70-17 falken rockymountain ats, pinch weld mod, door lock mod, Rola basket with 2 Hella 500 FF`s.
06WKHEMI is offline
post #3 of 11 Old 05-08-2012, 11:13 PM
JRLT
2010 WK
06? Time for new pads?
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #4 of 11 Old 05-09-2012, 12:54 AM Thread Starter
Jhigz
2006 WK
Yeah 06 but I personally have only had it a year (not sure if they've been replaced at all). Is there an easy way to tell if it's wear indicator or should I just get new pads and see if it quiets them down?
Anyone have recommendations on pad types?
Jhigz is offline
post #5 of 11 Old 05-09-2012, 12:55 AM Thread Starter
Jhigz
2006 WK
^ I guess no harm in checking if there is something in there this weekend, if nothing's found guess I'll just try new pads (?)
Jhigz is offline
post #6 of 11 Old 05-09-2012, 01:03 AM
JRLT
2010 WK
Just pull the tire and check before you get anything new.
JRLT is offline
post #7 of 11 Old 05-09-2012, 08:56 AM
OhFiveHemi
2005 WK
if you're squeeking while rolling w/o brakes, you may have a frozen caliper and may need to be replaced. and depending on how long its been doing this for you may have to replace a rotor too. but yeah, take the wheels off and see how much "meat" you have on those pads first
Blue WK Club Member #41
... | `05 WK - HEMI - QDII - Mods | ... | `07 XK - 3.7L - Stock | ...
OhFiveHemi is offline
post #8 of 11 Old 05-09-2012, 11:06 AM
croth
2005 WK
I was going to say wheel bearing, but theyusually growl when they start to go.
Craig
croth is offline
post #9 of 11 Old 05-10-2012, 03:09 PM Thread Starter
Jhigz
2006 WK
Thanks for the input guys I'll be taking the wheels off this weekend to have a closer look ~
Jhigz is offline
post #10 of 11 Old 05-10-2012, 03:47 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Is it front and rear passenger or just one of them? Not uncommon for something to get wedged between the front rotor shield and the rotor.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #11 of 11 Old 05-10-2012, 08:07 PM Thread Starter
Jhigz
2006 WK
From what I can tell it's just the front and kind of intermittent, I'll let you guys know if I find something in there ~ thanks!
Jhigz is offline
brakes , wk
97 zj 4.0 passenger side brakes locking up shrek317 ZJ Grand Cherokee Forum 3 11-25-2011 07:39 AM
Driver side 1 inch higher than passenger side Joe-Joe ZJ Grand Cherokee Forum 1 06-04-2010 11:19 AM
99 Grand Cherokee Ltd Heat on passenger side cold on Drivers side. WHATS WRONG?? nosguy ZJ Grand Cherokee Forum 9 12-30-2007 09:15 AM
No Passenger Side Heat TJTony ZJ Grand Cherokee Forum 4 11-20-2007 02:13 PM
brakes sqeeking phins13 ZJ Grand Cherokee Forum 1 11-26-2005 07:29 PM
