Passenger/Rear vents are only blowing hot air... - JeepForum.com
post #1 of 3 Old 09-22-2012, 07:15 AM Thread Starter
toycam
Hey guys, I tried searching forums but wasn't really able to find much help regarding this help, though I'm sure I may have missed some. I just bought an 05 last week and it seems that the passenger seat and rear seating vents will only blow hot air (or whatever ambient temp air is, which is hot in Florida) when the AC is on. The driver seat still blows AC, albeit not as cool as I would like it. Anyone have this problem or know of a fix that doesn't involve emptying my wallet? I'm PCSing to alaska in a couple months, but I'd like to have cool air until then.
Edit- forgot to mention that I don't have the dual-zone climate control. Just the basic unit.
toycam is offline
post #2 of 3 Old 09-22-2012, 12:56 PM
imthehink
imthehink's Avatar
Some will say the blend doors, but after tons of searching, I found a couple people with the same problem and they said they added refrigerant and fixed the problem. I obviously tried that first seeing it would eliminate the possibility. Sure enough, I added 12 0z of refrigerant and problem fixed. The ac system shuts off cold air to the pass/rear when it is low. Seems odd, but you might try that first. Before you add, check the refrigerant level.
imthehink is offline
post #3 of 3 Old 09-23-2012, 08:04 AM Thread Starter
toycam
I picked up a gauge and bottle of refrigerant at my local parts store and sure enough, the pressure was low. I added the whole bottle and it seemed to help out quite a bit. Hopefully it will stay working, or at least till I can make it to alaska and will no longer need AC
toycam is offline
no air blowing out vents red95GC ZJ Grand Cherokee Forum 26 09-07-2013 12:43 PM
problems with air blowing only through my defrost vents joshhuwa ZJ Grand Cherokee Forum 1 07-19-2008 08:45 PM
Air not Blowing from vents? 93' Grand Cherokee stylezprodukz ZJ Grand Cherokee Forum 1 11-22-2007 10:50 AM
Defrost not working, blowing out vents instead mattadams ZJ Grand Cherokee Forum 8 11-27-2006 12:52 PM
A/C Vents Blowing Water? cajunc4 ZJ Grand Cherokee Forum 2 08-06-2003 11:29 AM
