Parts for GC WK 3.0 CRD?! - JeepForum.com
 1Likes
  • 1 Post By narratones
post #1 of 14 Old 03-02-2017, 02:18 AM Thread Starter
narratones
Hi All,
I've got a mechanic currently doing the dreaded Oil cooler leak, but I need some parts... as Mercedes can't just take my Reg No.
The one I'm stuck on is the 2 x Exhaust Gasket for Turbo to Exhaust Manifolds - the only part I can find is Exhaust Manifold to Exhaust Collector Gasket L/s & R/S and also 3 bolt hole gaskets - I can't find these anywhere.
UPDATE: 3 Bolt hole gasket = Turbocharger Gasket! 2 to go!
Any one got any clues?
Cheers!
narratones is offline
post #2 of 14 Old 03-02-2017, 08:45 AM
jhtopilko
2008 WK
http://www.peachparts.com/shopforum/...er-leak-2.html
5100s at .75". Tire 265/6018
on fuelly jhtmpg
jhtopilko is offline
post #3 of 14 Old 03-02-2017, 09:20 AM
caddydaddy
2007 WK
I'm currently doing the oil cooler seal repair myself. I bought a kit that has all the needed parts. The collector gasket numbers are 6421423180 for the left and 6421423280 for the right side.
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
196,000+ miles!
caddydaddy is online now
post #4 of 14 Old 03-07-2017, 04:15 PM Thread Starter
narratones
I didnt actually reply, but this was a life saver - peach parts and the part nos Caddy!
Spot on
caddydaddy likes this.
post #5 of 14 Old 03-09-2017, 06:00 PM
Tango.
2008 WK
Which kit did you get?
Life is hard-John Wayne
Tango. is offline
post #6 of 14 Old 03-09-2017, 06:30 PM
caddydaddy
2007 WK
This one:
http://www.idparts.com/oil-cooler-se...42-p-5146.html
2" RC lift
196,000+ miles!
post #7 of 14 Old 03-10-2017, 03:27 AM Thread Starter
narratones
If you're in the UK - ring up Newcastle Mercedes, they have an eBay shop where they sell literally everything for the OM642, so they'll be able to help you out.
post #8 of 14 Old 03-12-2017, 07:25 PM
Tango.
2008 WK
Thanks !!
I really hope I don't have to do this. My friend fixed a couple MB's with the same engine and same issue and it was a lot of work!!
Tango. is offline
post #9 of 14 Old 03-12-2017, 07:56 PM
caddydaddy
2007 WK
Thanks !!
I'm currently putting my CRD back together after replacing those damned orange oil seals! Your friend is right, it IS a lot of work!
But with my case, it gave me a change to do some upgrades, like swirl valve removal, gasket matching the intake manifold ports and installing a rebuilt turbo.
Oh, and cleaning out the intake manifolds! I could not believe the amount of thick oily sludge that had accumulated inside them! I'll probably gain 2 MPG just because it can breathe better now!
2" RC lift
196,000+ miles!
post #10 of 14 Old 03-17-2017, 09:45 PM
ggrassmid
2008 WK
I had all of this done on mine already.
ggrassmid is offline
post #11 of 14 Old 03-19-2017, 05:34 PM Thread Starter
narratones
Did you guys get any issues after? I've had a few - but it's time to change the alternator. I'll get the splash guard that's in the TSB.
post #12 of 14 Old 04-03-2017, 11:16 AM
ggrassmid
2008 WK
No issues with the EGR or Swirl full deletes. I am tuned with GDE, so that was already gone anyways. I did get the simulator plugs from CBE just in case anyways.
The splash guard is for the sloppy people missing the oil fill hole when pouring the oil. Use a nice sized funnel and no issues with oiling the alternator then.
post #13 of 14 Old 04-05-2017, 01:25 AM Thread Starter
narratones
I'm thinking of maybe doing a remap - what do you guys think?
The Alternator got oil in from the filler cap being upside down.......... And probably a sloppy oil change.
- 2006 GC WK 3.0 CRD
post #14 of 14 Old 04-05-2017, 09:21 AM
caddydaddy
2007 WK
Does it have the stock tune now? You can't go wrong with the Green Diesel Engineering tunes.
I just swapped out my alternator and added the shield. It's way to easy to make a mistake or have the cap gasket leak and drip onto the alternator, to not have that shield be worth the install!
2" RC lift
196,000+ miles!
