Parking Sensor - Page 2 - JeepForum.com
post #16 of 18 Old 09-12-2007, 03:54 PM
merlinTec
merlinTec's Avatar
Originally Posted by Weissbrewer
Took the wifes truck to pick up Pizza for the Pats game yesterday, 3 times the park assist goes to red and solid beep in the middle of the parking lot, my driveway & the other lot I was in. The problem is inconsistent & sporadic. It was raining at the time. Very anoying I am going to check for a tsb.
Hi
If itís the red lights on but not the amber then it has picked up a fault and the parking sensors are disabled. You will need it plugged in.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #17 of 18 Old 07-01-2015, 10:41 AM
cmafia
issue on parking sensor
hello, i have a jeep grand cherokee model 2007 and i think someone befor me unplug the frond parking sensor in the dashboard. but i dont know where to plug id again.they change audio device on it and put a pioneer instead. even the raer sensor dows not works. its keeps it off.
can you help me?
cmafia is offline
post #18 of 18 Old 07-02-2015, 06:47 AM
nighowl2000
2014 JK Wrangler
i am guessing that either there is a cable you will need to splice into the new radio or its built into the CANBus computer system in which case you would need to get a mopar radio.
mine: 2014 jku sport S
her's: 2010 commander sport 3.7L 4x4
nighowl2000 is offline
hogh voltage 02 sensor/bad cool sensor Jh24k ZJ Grand Cherokee Forum 0 01-24-2010 11:33 AM
Sensor Reads Throttle/Pedal Position Sensor/Switch A Circuit Low Input Vincent2for2 ZJ Grand Cherokee Forum 3 11-01-2009 01:01 AM
Towing hitch parking sensor EZ1 ZJ Grand Cherokee Forum 0 01-27-2008 08:22 AM
solar sensor and in vehicle temp sensor Bekim ZJ Grand Cherokee Forum 10 10-08-2007 10:04 AM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 04:52 PM
