Parking brakes just wrecked my day.. - Page 3 - JeepForum.com
post #31 of 39 Old 08-23-2014, 11:26 PM
cumminsguy95
That's an absolutely astronomical price for an axle. I just replaced my rear right one for 58 dollars.
cumminsguy95 is offline
post #32 of 39 Old 10-18-2014, 12:16 AM
ChrisWK
2005 WK
Well I got a parking brake shoe problem too. I just replaced my rear rotors and I got pieces of brake shoe inside the old rotor, I did not know what it was at the time of puting on the new rotors.So it looks like I will be doing parking brake shoe replacement . Can I buy a set at autozone or should I get OEM set?
Thanks
Limited HEMI Dark Khaki Pearl SRT8 Full Body Kit, Roof Rails,SRT8 Engine Strut Bar, Lund Rear Spoiler, MYGIG INSTALLED with LOCKPICK, Kenwood Sub,AFE Intake, Taylor Spark Plug Wires,G2 Silver Painted Brake Calipers, Billet Tech Catch Can, Addco Sway Bars Front and Rear, Eibach Lowering Springs,Xenon Volt HID Lows 6k,Chrome SRT Reps
ChrisWK is offline
post #33 of 39 Old 10-19-2014, 06:33 PM
Tekn0logy
2006 WK
adding another "me too" post to this thread. :
good God, I thought my 4Runner's brakes were maddening. Pulled the passenger's side rotor and found that the weird noise I heard a week ago was the parking brake pad disintegrating. Almost done and I go to slap in the new pads and I found the caliper piston was cracked. Damn you phenolic piston! Thank goodness Advance Auto had a new $50 off $100 promo. Driver's side rotor took a couple of hours to remove. Sunday burnt all to hell. Not one football game watched.
Tekn0logy is offline
post #34 of 39 Old 10-19-2014, 09:42 PM
ChrisWK
2005 WK
Is it easy to change the parking brake shoe? How do you adjust the shoe correctly, I do not want to eat the new set up. I have done the rotors and pads before.
Thanks
ChrisWK is offline
post #35 of 39 Old 10-24-2014, 09:02 AM
Nejeep
Here is a decent Youtube video for the WK brakes, front, rear and parking. The parking brake starts at the 15 minute mark on the video if you want to jump ahead. As the video shows one of the parking brake springs is a pain to reinstall with the axle in place. Some mechanics recommend pulling the axles to provide more work space. I expect the time spent pulling the axles is about the same as fighting the brake springs.
https://www.youtube.com/watch?v=9u4hAOv145I
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #36 of 39 Old 10-25-2014, 10:08 AM
ChrisWK
2005 WK
I used that video to change all rotors and pads great video, I got all the springs and brake shoes on 2 hours longer than it took me to change the rotors and pads. Well all back together I pulled the parking brake handle it will not hold the jeep. I am having trouble adjusting star to brake shoes.
ChrisWK is offline
post #37 of 39 Old 10-27-2014, 05:37 AM
Tekn0logy
2006 WK
One of the things that I found during the replacement of the parking brakes is that on the 06, there is no adjustment under the rear seat, only a "equalizer". When one spring was detached, the "equalizer" would be cocked to one side, pulling on the cable that did not have a return spring attached. It took me a while to figure this as the actuator was difficult to get hooked back onto the brake cable. If one actuator is detached, I don't think you could get enough force applied to the other side to apply the bake. It would be 1000 times easier to pull the back seat off and see if the equalizer is cocked to one side or if both cables are snug up against the equalizer.
post #38 of 39 Old 10-28-2014, 10:38 AM
ChrisWK
2005 WK
I just finish moving the adjuster star and still no luck, when I did the shoe install the driver side I kept the actuator together and pulled the shoes off, then when on the pass side the actuator fell out could not get it to hook on the wire so got all the shoes and springs back on like the other side thought it would catch the wire,once I made the adjustments, I guess that is why the adjustment are not working right. Well I am done with this **** taking it to mechanic. This is the hardest thing I have had to work on my jeep .Thanks for the help.
ChrisWK is offline
post #39 of 39 Old 10-29-2014, 04:56 PM
ChrisWK
2005 WK
Well I took it to a mechanic and he is still working on it keeping jeep over night. Harder than he thought it was going to be I guess.
ChrisWK is offline
Rebuilding parking brakes slate210 ZJ Grand Cherokee Forum 9 07-10-2008 04:23 PM
A/C and Wrecked ZJ Ds4x4 ZJ Grand Cherokee Forum 3 09-26-2006 07:33 AM
Rear brakes & Parking Brake - Hot Wheel! BostonETC97 ZJ Grand Cherokee Forum 1 09-25-2006 10:35 PM
Help me get rid of my wrecked ZJ gregmondro ZJ Grand Cherokee Forum 12 03-09-2006 07:38 PM
Parking Brakes Joseph Humphrey ZJ Grand Cherokee Forum 7 01-11-2004 04:36 PM
