P2264 - Water in Fuel Sensor Circuit - JeepForum.com
post #1 of 9 Old 08-22-2014, 10:06 AM Thread Starter
sshaughn
2008 WK
P2264 - P2264 - Water in Fuel Sensor Circuit in Fuel Sensor Circuit. Can anyone help me with I should do next. Not sure what would have caused this.
2008 WK Overland 4WD CRD 3.0L, QD2, Green Diesel Engineering Hot-Tune, MBRP Exhaust, CB Engineering Turbo Resonator Delete Pipe, Kolak Addco Rear Sway Bar, K&N Air Filter, Propel Fuels B20 Biodiesel
sshaughn is offline
post #2 of 9 Old 08-22-2014, 11:12 AM
SSF556
2008 WK
Maybe change out the fuel filter....could have gotten a bad tank of diesel....
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #3 of 9 Old 08-22-2014, 12:58 PM Thread Starter
sshaughn
2008 WK
Hmm, I'll check it out...just changed it about 2500 miles ago. I am thinking it could be linked to why my jeep is having issues starting. It all started when I plugged something into the rear power outlet?
sshaughn is offline
post #4 of 9 Old 08-22-2014, 07:25 PM
Chirpz
Chirpz's Avatar
2007 WK
You have probably already checked the plug that plugs into the Water sensor that is located on top of the fuel filter. If not, that would be something to check.
I use my rear power regularly...can't imagine it causing a problem like this.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #5 of 9 Old 08-22-2014, 07:32 PM
Tango.
2008 WK
water in fuel .. or fuel filter is over due for replacement, ... has nothing to do with an inverter.
water in fuel can be from water in the tank and you running it low, or water in fuel from where you purchased the fuel. when the fuel station runs the tanks low you can get water that way also.
Tango. is offline
post #6 of 9 Old 08-22-2014, 07:53 PM
Chirpz
Chirpz's Avatar
2007 WK
I get the "Water in Fuel" message on the dash every winter...now and then and only in the mornings. I used to immediately purge the filter using the bleeder that is built into it on the top....but then next morning the message would return. Never checked for codes. Starting last winter I bought a can of diesel fuel water remover and add it to the fuel every fill up... one can treats 128 gallons so don't just dump in the whole can. Seemed to cure the problem for me.
I suppose you could have a faulty sensor or damaged wiring.
Chirpz
Chirpz is offline
post #7 of 9 Old 08-22-2014, 10:04 PM
Tango.
2008 WK
It's 75 in Roseville, CA .. likely not condesation today.... though it could be a bad senor.
Tango. is offline
post #8 of 9 Old 08-22-2014, 11:26 PM Thread Starter
sshaughn
2008 WK
I'll check out the sensor and probably replace the filter as well. After I cleared that code then I got the service 4x4. I cleared that code as well. The jeep is now starting up as normal half the time and the other half it either cuts off as soon as turn the key to the on position or struggles to start? Thanks guys for the input.
sshaughn is offline
post #9 of 9 Old 08-23-2014, 01:06 PM Thread Starter
sshaughn
2008 WK
Now I am getting the service parking brake, and service 4x4 on the dash?
sshaughn is offline
