P0301 on my 06' 4.7 - JeepForum.com
post #1 of 13 Old 10-06-2013, 02:08 PM Thread Starter
DVB
2006 WK
P0301 on my 06' 4.7
I first had P0300 and P301. So I changed all the plugs since I bought it used (just hit 100k mi). After I was done and started her up no CEL. So I was happy with that. I went and filled up the tank about a half mile down, cel went back on. This time only P0301. Any suggestions for my next move? I definitely feel less power on the xpressway.
DVB is offline
post #2 of 13 Old 10-06-2013, 04:19 PM
JRLT
2010 WK
Swap a couple of coils around and see if the code changes to a different cylinder.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #3 of 13 Old 10-07-2013, 07:31 AM Thread Starter
DVB
2006 WK
Makes sense, I'll try that when I get home. Thanks.
DVB is offline
post #4 of 13 Old 10-07-2013, 04:02 PM Thread Starter
DVB
2006 WK
Just swapped coils 1 (bad one) to #2. Cel is off. I haven't drove it yet to see how soon the cel comes back, but how likely is it that it's a bad coil?
2006 4.7 Limited QD II, Stock
DVB is offline
post #5 of 13 Old 10-08-2013, 06:43 AM Thread Starter
DVB
2006 WK
After switching the coils yesterday, I drove to work this morning (about 15mi) the CEL did not come on?? I guess I'll see what happens on the way home.
DVB is offline
post #6 of 13 Old 10-08-2013, 09:56 AM
JRLT
2010 WK
Might take a day or so, mine did.
JRLT is offline
post #7 of 13 Old 10-09-2013, 08:22 AM Thread Starter
DVB
2006 WK
No CEL yet..
DVB is offline
post #8 of 13 Old 10-10-2013, 08:43 AM Thread Starter
DVB
2006 WK
Yup, you were right, CEL came back this morning, same code P0301.
DVB is offline
post #9 of 13 Old 11-18-2013, 08:32 AM Thread Starter
DVB
2006 WK
Just an update. I finally checked the #1 injector. It had a crack around the green plastic trim. I'm hoping that will solve my misfire problem but I really don't feel any improvement yet. Still seems a little sluggish on acceleration.
DVB is offline
post #10 of 13 Old 11-18-2013, 03:56 PM
paroxysym
2007 WK
you try seafoaming it yet? i had that same misfire and i seafoamed it twice and it went away after replacing the plug and swapping the coil packs
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #11 of 13 Old 11-19-2013, 01:11 PM Thread Starter
DVB
2006 WK
The first thing I did when I got the CEL was replaced all the plugs, swapped the #1 coil (after the CEL came back). So this injector thing was my recent thing on the check off list.
I haven't tried seafoam, I don't know too much about it. I heard a lot about it and it seems like you can use it for everything, how would I apply it to my situation?
DVB is offline
post #12 of 13 Old 11-19-2013, 03:34 PM
paroxysym
2007 WK
run a can through your brake booster to clean out any carbon build up. run a 1/3rd of a can in the gas tank... run it for a week and then use the remainder of the the an you put in the tank through the brake booster again and call it a day.
cleared my misfire up and shes been running fine since
OEM+
post #13 of 13 Old 11-26-2013, 12:57 PM Thread Starter
DVB
2006 WK
This is what was causing my p0301. I waited almost 2 weeks to be sure the CEL didn't come back. So far so good.
DVB is offline
