P0300 and P0339; Crankshaft position sensor? - JeepForum.com
post #1 of 7 Old 04-20-2011, 03:29 PM Thread Starter
I8AHUMR
Got some misfiring and DTC throws P0300 and P0339. Anyone have this problem in the past? I'm assuming a new CPS is in order since P0339 is something about an intermittent CPS? Anyone know where this is located? Thanks in advance.
I installed a Billet catch can about 2 weeks ago and a new EGR valve about 3 weeks ago. I seriously doubt it's related but any thoughts on any connection?
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #2 of 7 Old 04-20-2011, 03:44 PM Thread Starter
I8AHUMR
Ok, found the cps in the service manual. It's on page 8i-19. Is that (right next to)/underneath the alternator? Looks simple from what I can tell. One connector and one bolt it looks like? 9 ft/lbs on the Hemi from what I can tell.
I8AHUMR is offline
post #3 of 7 Old 04-20-2011, 04:26 PM
WK-916
I had this Problem!
The CKP ensor is about $45 from the Dealer
Located on the botton of the block, on pass side, infront of the Starter; held on by 1 10mm bolt and obviously an electrical connector. Took me about 10 mins to fix, hardest part is getting under vehicle....
Hope this helps...
The one under the Alternator is the 4.7L
WK-916 is offline
post #4 of 7 Old 04-20-2011, 04:27 PM
WK-916
Correction: "CKP ensor" = Sensor
WK-916 is offline
post #5 of 7 Old 04-20-2011, 05:08 PM Thread Starter
I8AHUMR
Gotcha... Good to know someone had the same issue and that's it's an easy fix like I thought. Thanks for the information. It wouldn't surprise me if the pictures are swapped in the SM??? I'll crawl under there and find it.
I8AHUMR is offline
post #6 of 7 Old 04-20-2011, 05:23 PM
Walt
2008 WK
Crankshaft position sensor is RHS rear, by flywheel. Camshaft position sensor is RHS front, by alternator.
Look in Section 14 of the FSM.
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #7 of 7 Old 04-20-2011, 10:56 PM
mailforjon
mailforjon's Avatar
2005 WK
had same code p0339 on my hemi. took 10 min max to replace the sensor. very easy job.
-2005 WK 5.7 Limited [DD]
-1999 WJ 4.7 Limited [SOLD]
-1998 ZJ 5.9 Limited [SOLD]
-1996 ZJ 5.2 Laredo [SOLD]
-1994 ZJ 4.0 Laredo [SOLD]
-1993 XJ 2.5 [SOLD]
mailforjon is offline
5.9 crankshaft position sensor Texas ZJ1 ZJ Grand Cherokee Forum 8 05-09-2009 11:03 AM
New Crankshaft Position Sensor is bad Nocturnal ZJ Grand Cherokee Forum 0 09-20-2008 03:09 PM
crankshaft position sensor? petey156 ZJ Grand Cherokee Forum 4 02-16-2007 08:56 AM
Crankshaft position sensor & coolant temperature sensor getting replaced in my 95 GC Keith1975 ZJ Grand Cherokee Forum 3 12-14-2006 03:52 PM
Crankshaft Position Sensor(CPS) 97zjjeeper ZJ Grand Cherokee Forum 15 02-05-2006 12:20 PM
