P013A and P013C - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > P013A and P013C
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! 2 door JK Recruit Half hardtop Kits Now available!
Unread 07-21-2015, 06:09 PM   #1
SmallTownBird
P013A and P013C
I bought my 07 Wk Hemi limited in April and ever since I have had the codes listed above. I have changed the rear O2 sensors with NJK sensors and then sensors from Mopar and the code stays. When I clear them they come back once I hit the interstate. All of the exhaust before the O2s is tight but the mid pipe was replaced with a magnaflow one by the dealer and where it slip fits together and where it bolts to the muffler are loose. Would leaks after the 02s cause these codes? Should I just get both parts welded and see if that works? That is for the help!
SmallTownBird is offline   Reply With Quote Quick reply to this message
Unread 07-22-2015, 08:04 PM   #2
SmallTownBird
Bumpity
