P code after superchpsi tune - Page 3 - JeepForum.com
post #31 of 32 Old 06-01-2012, 05:00 PM
90grandoneer
90grandoneer's Avatar
2006 WK
Frenetic1, are the codes you're getting P1128 and P1129, or are they different ones? Yes, the cheap scanners don't read fast enough but, IMO, they still give a pretty good idea of what's happening with the sensor(s). You will get slightly different readings at idle, than when cruising. The upstreams will continue cycling, but maybe not as big swings, and the downstreams will intermittantly drop below .450 mv (lean) at idle. I've seen mine sit at .75 mv for some time, but as soon as I start driving it goes back up above .450 mv, where it should be. It sounds like your description is about normal. How does it read when cruising (above idle) at almost any speed...especially say, above 45-50 mph? Then you should be getting your rapid, deep swings like you're showing above. If your downstreams are indicating like above, at cruise there is definitely a problem as, at cruise, they should be fairly stable somewhere (not that critical) above .450 mv, and not have any crosscounts....switching above and below .450 mv. Yours up around .700 is about where mine run.
If you can read all screens when cold, your before start/immediately after start voltage (I call it "parked") should be ~1.270 v, and the fuel status should show, "open loop" as soon as started. Within ~40 seconds voltage should rapidly drop, the upstreams should start cycling, and the fuel status should change to "closed loop". Not switching to closed loop in the PCM's calculated (based on engine sensor readings) time will trip the 1128-29 codes. As said, other things can cause this, but my limited experience shows the O2 sensor heaters to be the most logical cause, especially in my case, with the use of the "slow to heat" Bosch sensors. As soon as I went with the upstream NTK's, (heated/operated in ~15-20 seconds), the problem went away. I still use the Bosches downstream, but if I were buying them again, they'd all be NTK's.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #32 of 32 Old 11-08-2012, 08:49 PM Thread Starter
twistedlizard72
2007 WK
Another update. I know it took a while for me to keep this going but I was out on business. Anyway, Jeep sat for 8 months with battery disconnected and fuel pump fuse pulled (fuse for anti-theft more than anything). When I returned everything started up and ran like a champ. The CEL did trigger and same P1128/1129 codes appeared, I left them there and they disappeared after a few days. Due to time constraints I took it to the dealer for an oil change and to get to the bottom of the problem hoping it would fall under warranty. Because the CEL wasn't reporting anything and the vehicle was in Open loop they couldn't track it and diagnose. Best thing was they didn't charge me for the troubleshooting time( which was $105!! My warranty expires in February of 2013 and I will be gone again for business here soon so I may just have to change the things myself. Questioning whether to continue the Warranty or not. I think I've only driven maybe 2000 miles this year.....if that.
Kevin K.
twistedlizard72 is offline
Best tune up for a 5.2 Kevin86me ZJ Grand Cherokee Forum 66 11-03-2011 09:00 PM
What does code check engine code 14 mean?? tawa1075 ZJ Grand Cherokee Forum 1 10-19-2010 02:54 PM
Wife's ZJ has had full tune-up / overhaul, still throws code 43 Crit ZJ Grand Cherokee Forum 6 08-31-2009 12:08 AM
tune up rmtomasin ZJ Grand Cherokee Forum 5 02-12-2009 10:23 AM
ZJ: Tune-Up Casper4x4 ZJ Grand Cherokee Forum 3 08-24-2007 01:55 PM
