P code after superchpsi tune - JeepForum.com
post #1 of 32 Old 12-01-2011, 12:02 PM Thread Starter
twistedlizard72
2007 WK
I installed the 87 tune from my superchips tuner last night (first time) and got a P code this morning. Code is P1129; closed loop fueling not achieved, bank 2. What does this mean and should I be concerned?
twistedlizard72 is offline
post #2 of 32 Old 12-01-2011, 12:08 PM
sk1er18
2007 XK Commander
When I had mine programmed with the superchips i was getting P1128 and P1129 codes consistently. I went through all of the troubleshooting steps and couldn't find a root cause. Since I'm still under warranty I put my stock tune back in so I could let the dealer have a shot at it..... the code hasn't been back since (knock on wood).
Now I Just use the programmer for tire size adjustments.... honestly didn't have a huge effect on performance anyways (I'm very subjective and not easily influenced by the butt dyno)
-Matt
sk1er18 is offline
post #3 of 32 Old 12-01-2011, 12:08 PM
06WKHEMI
2006 WK
I don't know from experience but try setting it back to stock clearing the code and starting over
2006 Black wk overland HEMI QDII. OME HD bilstein struts with 58643 monroe load levelers RRO uca, afe cold air intake,hella 500FF behind grille, RC 1.5 wheel spacers s4xc cb antenna mount with 5ft firestik and midland 1001wx CB,265/70-17 falken rockymountain ats, pinch weld mod, door lock mod, Rola basket with 2 Hella 500 FF`s.
06WKHEMI is offline
post #4 of 32 Old 12-01-2011, 12:47 PM
mrtosh
2005 WK
May want to post on the Superchips forum. I remember seeing this code popup there before i believe. Think it might actually say sonething about that code in the Flashpaq's owners manual
'05 WK Limited QDII, Superlift 6", Bilstein struts,315/70/17 Duratracs, Gibson CB, Volant CAI, JBA UCA's, JKS quick disco, adj. Rear trac bar, 4xguard armor, Diablosport Intune, Xenondepot 6000k HID's, Putco Jet yellow fogs.
mrtosh is offline
post #5 of 32 Old 12-01-2011, 01:22 PM
sk1er18
2007 XK Commander
Neither P1128 or P1129 was posted in any thread on the superchips forum when I searched. They're not listed in my user manual either.
-Matt
sk1er18 is offline
post #6 of 32 Old 12-01-2011, 01:51 PM
mrtosh
2005 WK
I would do like 06wkhemi said and reset it to stock and reload the tune. Also you can reset the pcm by grounding out the positive cable for 30 seconds. Have you switched fuels lately? There's a TSB for hose codes when you use fuel with 38-40% ethanol which with winter fuel can happen.
TSB for 2007 GC: http://www.wkjeeps.com/tsb/tsb_wk_1804007.pdf FLASH: MIL Illumination Due To DTC P1128, P1129 When Vehicle Is Operated With A 38% To 40% Ethanol Fuel Blend
As for the codes being talked about I'll check my manual tonight. I know they make mention of it somewhere.
mrtosh is offline
post #7 of 32 Old 12-01-2011, 01:53 PM
paroxysym
2007 WK
id clear the codes with the tuner and set her back to stock. then try reloading it.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #8 of 32 Old 12-01-2011, 01:59 PM
mrtosh
2005 WK
Just found my manual. On page 19 it mentions a P1000 code. My bad.
mrtosh is offline
post #9 of 32 Old 12-01-2011, 02:56 PM
90grandoneer
90grandoneer's Avatar
2006 WK
I agree that you should go back to stock, clear the codes, start it and see if the codes come back. If they do, you could be having issues with your 1/1 and 1/2 O2 sensors.
How many miles on your rig? Have the O2 sensors ever been changed? These codes mean that the fuel management system has failed to switch to closed loop (status 2) after initial startup. On initial startup the system is in open loop (status 1) and should transition to closed loop within ~40 seconds. If it doesn't, it triggers these codes and status 8, which means closed loop was not achieved in a timely manner. I can't imagine the tune causing this though. I've run that tune on my Hemi without issue, but then again, I have fairly new O2 sensors all the way around. You may want to read the thread I did on the O2 sensors after I got the same codes: http://www.jeepforum.com/forum/f67/o...rimer-1182446/
Let us know what you find.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #10 of 32 Old 12-01-2011, 03:28 PM Thread Starter
twistedlizard72
2007 WK
I got a 2007 with the 4.7L and nearing 98,000 miles. As far as I know the O2 sensors are stock. I have never had any code before with the vehicle and the reason why I am putting it on the tune. It did throw it after initial start up this morning. I cleared the code on my lunch break today, I will see what it does on the way home. I will also post on Superchips forum.
post #11 of 32 Old 12-01-2011, 03:31 PM
mrtosh
2005 WK
Keep us posted. Curious on the outcome.
mrtosh is offline
post #12 of 32 Old 12-01-2011, 03:37 PM
90grandoneer
2006 WK
Sensors should be changed no later than ~100K. They deteriorate over time (like spark plugs), and you may not notice a problem until they get real bad, or fail outright. What causes those codes is that the heaters in the sensors are not heating up quick enough to allow them to start sampling the mixture. Has your fuel economy, performance or idle quality deteriorated from ~20K ago, or so?
post #13 of 32 Old 12-02-2011, 10:08 AM Thread Starter
twistedlizard72
2007 WK
Its strange because my mileage has actually gotten better in the last 3k. I would average 16 mpg and change on my daily commute and recently have been averaging almost 18 mpg.
I cleared the code yesterday and filled up with 87 octane to allow the computer to learn me on a single tune. The CEL has not gone off again and its running good. Minimal gains, low and midrange RPM's feels like it has better power.
post #14 of 32 Old 12-02-2011, 10:42 AM
mrtosh
2005 WK
You should try running 89 on the 87 tune. I've seen the best results going this route.
mrtosh is offline
post #15 of 32 Old 12-02-2011, 11:09 AM
90grandoneer
2006 WK
Twisted is in Wrightwood, Ca, which is at a fair altitude. Don't know exactly what it is though. Twisted??? I am at ~3000 ft. elevation (DA's usually run 4500+) and I can easily run 87, without KR issue, using the DS 93 tune. The only time I put 91/93 in is when I go racing. When I am driving at higher altitudes (above ~6000 ft.) I'll even run 85 without a problem. Rule of thumb is, one octane point less required for each 1000 ft. increase in elevation. Hey Twisted, do you know Bart Inglese?
Best tune up for a 5.2 Kevin86me ZJ Grand Cherokee Forum 66 11-03-2011 09:00 PM
What does code check engine code 14 mean?? tawa1075 ZJ Grand Cherokee Forum 1 10-19-2010 02:54 PM
Wife's ZJ has had full tune-up / overhaul, still throws code 43 Crit ZJ Grand Cherokee Forum 6 08-31-2009 12:08 AM
tune up rmtomasin ZJ Grand Cherokee Forum 5 02-12-2009 10:23 AM
ZJ: Tune-Up Casper4x4 ZJ Grand Cherokee Forum 3 08-24-2007 01:55 PM
