Overheating - JeepForum.com
post #1 of 15 Old 09-16-2013, 09:07 AM Thread Starter
jjarvis0007
2005 WK
Overheating
Jeep started overheating this morning. Let it cool off for awhile and it sputters when trying to start. It finally started so I brought it to my Buddy's boat shop. It overheated just a tad on the way here less then a mile. Now its sputtering to start again. The water pump isn't leaking at all. Nothing in my oil either. Any ideas?
jjarvis0007 is offline
post #2 of 15 Old 09-16-2013, 10:28 AM Thread Starter
jjarvis0007
2005 WK
Just replaced the thermostat and that didnt seem to help. Guess next will be water pump and radiator
post #3 of 15 Old 09-16-2013, 11:00 AM
overland-wk
2006 WK
Did you bleed the coolant system after the thermostat instal ?
06 ROR lifted wk (mine)
07 RC lifted xk (wife's)
Youtube channel
Bumsmodified98xj
overland-wk is offline
post #4 of 15 Old 09-16-2013, 11:05 AM Thread Starter
jjarvis0007
2005 WK
I just poured more fluid in it. Motor starts knocking when temps gets up then is hard to start then dies. Where do you bleed it at?
post #5 of 15 Old 09-16-2013, 12:16 PM
overland-wk
2006 WK
What engine do you have?
Youtube channel
Bumsmodified98xj
post #6 of 15 Old 09-16-2013, 12:26 PM
LiftedWK
Had the same problem. It was a bad lifter.
LiftedWK is offline
post #7 of 15 Old 09-16-2013, 07:22 PM Thread Starter
jjarvis0007
2005 WK
Still doing it after a new tstat, water pump, and temp sending unit. Flushed the radiator earlier and it was fine. But I have 190 on one side and 90 on the other. Taking the radiator into the shop tomorrow to get tested.
post #8 of 15 Old 09-16-2013, 09:14 PM
overland-wk
2006 WK
If you have a 4.7/3.7 there is a bleeder screw at the end of the upper radiator hose closest to the engine. I have a 5.7 and i flushed the radiator on mine and didnt need to bleed it.
Youtube channel
Bumsmodified98xj
post #9 of 15 Old 09-16-2013, 10:17 PM Thread Starter
jjarvis0007
2005 WK
I've bleed it thru the Allen screw on the upper water pump housing.
post #10 of 15 Old 09-17-2013, 07:59 AM
WieSeL
Your radiator sounds like it is restricted for sure
WieSeL is offline
post #11 of 15 Old 09-17-2013, 08:15 AM Thread Starter
jjarvis0007
2005 WK
Darn radiator cap wouldn't hold but 6# and was supposed to hold 18#
post #12 of 15 Old 09-17-2013, 08:49 AM
Jeepforthewin
2010 JK Wrangler
Always the little things that get ya
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #13 of 15 Old 09-17-2013, 09:06 AM Thread Starter
jjarvis0007
2005 WK
I'm happily pissed
post #14 of 15 Old 09-18-2013, 10:52 PM
fast916
2009 WK
I had the same problem and it turned out to be the radiator cap. I now carry a couple of extra caps with me all the time.
fast916 is offline
post #15 of 15 Old 09-19-2013, 05:32 AM Thread Starter
jjarvis0007
2005 WK
Went ahead and put a new radiator in her. The flow test showed it to be 50% clogged. Now I've got a new cooling system except for the heater core. Which I bypassed until I'm ready to do it soon
