OTRATWW new site - JeepForum.com
post #1 of 13 Old 12-27-2013, 09:17 AM Thread Starter
Jeepforthewin
2010 JK Wrangler
OTRATWW new site
There current site is OTRATTW.com and the new site is under construction at OTRATTW.net. I am wanting to order some switches from them and found the ones I want on the new site however you can't order from the new site yet. I have searched all over the current site and can't find the same switches. Does anyone know when the new site willl be up and running?
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #2 of 13 Old 12-27-2013, 09:29 AM
jeepinhokie
It's been under construction for a while. I would call him, he's very easy going. Just explain what you want and he will let you know what s possible.
HOKIES UNITED!
jeepinhokie is offline
post #3 of 13 Old 12-27-2013, 09:34 AM Thread Starter
Jeepforthewin
2010 JK Wrangler
I sent them an email, if I don't hear back by the end of the day i'll give him a call. Thanks!
post #4 of 13 Old 12-27-2013, 09:37 AM
TJ_Tim
Interwebz Specialists
TJ_Tim's Avatar
They also have a Facebook page you could try sending a message and inserting the pics in there. I got quick responses both ways.
Sent from Teletran 1
1969 Mercury Cougar 351w
1998 Jeep Wrangler Sport 4.0
2009 Yamaha V Star 950
2006 Jeep Commander 4.7 Base
TJ_Tim is offline
post #5 of 13 Old 12-27-2013, 09:43 AM
sjones26573
You can have any switch custom built with whatever function and lettering/design you want. If its a certain style switch, you'd have to ask. I just had a bunch of custom Contura V's made by them not long ago.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #6 of 13 Old 12-27-2013, 09:49 AM Thread Starter
Jeepforthewin
2010 JK Wrangler
Thanks for the responses guys. It's not a custom switch it is one they carry. I just looked on FB and found the switch on their news feed so I posted a comment on it, thanks for the idea TJ_Tim.
post #7 of 13 Old 12-28-2013, 11:13 AM
TJ_Tim
TJ_Tim's Avatar
Glad to help and their customer service is top notch second to none.
TJ_Tim is offline
post #8 of 13 Old 12-28-2013, 11:26 AM Thread Starter
Jeepforthewin
2010 JK Wrangler
I recieved a reply back from them about an hour later and they said the new website is still being loaded and tested. He also stated another reason is because they are way behind on their workload as of now. Also i was told how to order the switch I want
post #9 of 13 Old 01-06-2014, 11:35 AM
ttusqrl
2005 WK
I'm half hijacking this thread, half not. I am trying to figure out what switches and components I need, but I could use a little help. Looking at the OTRATTW site, I found three switches I want for now -- CB, Winch Power, and Winch In/Out. So now for the questions:
1.) I assume all of these Carling V switches will work with the Saguaro / Aspen Creek / Steel Armadillo switch panel, correct?
2.) For the winch in/out -- do I want a SPDT or a DPDT? Both are double throw for the in/out function, but do I need a single or double pole?
3.) I would like to have the LEDs for the winch in/out be dependent on the winch power switch. Is this possible?
4.) Does putting a winch power switch mean that I now need to run a fused winch power cable? From my understanding, everyone suggests AGAINST using an inline fuse with your winch.
5.) Do the OTRATTW blank panels fit in the Saguaro / Aspen Creek / Steel Armadillo switch plates?
Thanks for the help guys!
2005 WK 5.7 ORT | Mod SL (OME struts & 990s) | JBA UCAs & Discos | Saguaro Front Bumper | Warn Zeon 10s | 285/70/17 BFG TA KO | AIRAID CAI | Gibson 3" Exhaust | DiabloSport Intune | JL Stealthbox
ttusqrl is offline
post #10 of 13 Old 01-06-2014, 11:47 AM
sjones26573
1. These switches use the same bases as the Carling II's, so if they fit, these fit. I personally know nothing about those panels
2. My Warn needed a DPDT, as well as most winches. The 2nd pole completes the ground (as a safety measure)
3. Yes. You just wire the LED input to the output from the other switch.
4. I wired it into my fuse block with a small fuse. This is just a signal wire, so very low draw.
Jeep-Owner.com
post #11 of 13 Old 01-06-2014, 11:50 AM
ttusqrl
2005 WK
Thanks Jones!!!!! What switch components did you end up using? Packard terminals? Sorry, I'm new to the electrical side of the house
ttusqrl is offline
post #12 of 13 Old 01-06-2014, 11:57 AM
sjones26573
Just plain old female spade terminals from the parts store.
Jeep-Owner.com
post #13 of 13 Old 01-06-2014, 01:27 PM
ttusqrl
2005 WK
Everything is ordered. Now to remind myself how to wire it up haha
ttusqrl is offline
