Options for jump starting without another vehicle - JeepForum.com
post #1 of 17 Old 02-16-2017, 05:10 PM Thread Starter
Mp5ben
2005 WK
Planning a 10 day trip out to the remote 4x4 trails in Big Bend and taking the WK out to "overland" it.
I started wondering about what I'd do to jumpstart a dead Jeep. Looking on amazon I see small jumpers from phone sized all the way up to large boombox sized jump starters. All varying CAA's which my Jeep requires (05 WK, 5.7) about 1000CCA, What is says on my battery. Then there was the solar panel option but that would take quite a long time to charge a dead 12v battery even out in the desert.
I've almost decided on just bringing the battery out of my CJ7 as a free precaution and keeping a very close eye on whats being used in the Jeep when its off as well as starting it up every 2 hours or so just to keep the battery topped off.
Just seeing what's worked for yall and if you had any reccomendations, reviews are all over the place on these jumpstarters. Some had a compressor too which would be cool but not necessary
05 WK Limited, HEMI 5.7, QD II, OME HD, 255/75/17 Mud terrains
Mp5ben is offline
post #2 of 17 Old 02-16-2017, 05:14 PM
Kman09JGC
I bought this on Amazon 70 bucks. I had one before this for 10 years before it lost it charge to fast.
09 laredo 28x 4.7 w/QD2 Superchip w/91 perf tune w/ trans app, jet 180 tstat,K&N CAI, bistein 5100 struts and shocks, srt8 front and rear swaybars, 255/65/17 General Grabber at2's.
Black WK Club #107
Kman09JGC is offline
post #3 of 17 Old 02-16-2017, 05:58 PM
Planetcat
2010 WK
I was going to suggest the spare battery. Its free and unlikely you will need to use it. Also makes for good aux power source for accessories.
Planetcat is offline
post #4 of 17 Old 02-16-2017, 07:11 PM
caddydaddy
2007 WK
This is always in the back of my Jeep!
http://www.cloreautomotive.com/sku.php?id=244
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
197,000+ miles!
caddydaddy is offline
post #5 of 17 Old 02-16-2017, 08:32 PM
azzkicker
2007 WK
I would bring the second battery, and unless the rig was just cranking slow, I wouldn't risk draining my only hope into a fully dead battery. I would unhook the dead one, start the rig with the good one, then jumper it to the dead one until everything was fat and happy. I had to give somebody a jump start after they tried to jumpstart another rig without theirs running. Both ended up dead. Oddly, most of the instructions I've seen for jumping begin with both vehicles turned off.
I wouldn't trust anything that wasn't about as heavy as a car battery. I saw the link above and it says it weighs about 25 pounds, so that sounds about right to me.
I would love to see some real tests of these jump starter kits, not the marketing setup carefully designed to make a turd look like a diamond. I want to see somebody leave the headlights on overnight, then hook these things up and start the rig.
I see these carefully worded ad numbers, like "peak amps" and "cranking amps" which are not cold cranking amps. Also, there's no doubt in my mind they quote those numbers from their best test taken 2 seconds after it comes off the charger, and not run for long enough to actually start a rig. Call me a skeptic, but I've worked with marketing people before.
Sounds like you have a fun trip planned! Enjoy.
07 WK 5.7 QD2, 4" lift, 33X10" tires, M8000s
ARB twin air,Dual AGM group 49, sliders and skids
azzkicker is offline
post #6 of 17 Old 02-16-2017, 09:13 PM
nvrdone1
2007 WK
I all ways have a jump box with me. so far ive only needed it once when my original battery decided to take a dump on me. but its suprising how many times ive used it to start other peoples vehicles.
for this trip I would take the extra battery, just make sure its fully charged before you leave & have fun
nvrdone1 is offline
post #7 of 17 Old 02-16-2017, 11:47 PM
azzkicker
2007 WK
What kind do you have? It sounds like you've tested it a number of times.
post #8 of 17 Old 02-17-2017, 03:04 AM
Hendrix9
2007 WK
I also vote for bringing a second battery. I'd disconnect yours and try starting it with that one before hand though just to be super positive it'll work. (I tried to use the battery from my jetta TDI to start my 4.7 once and it couldnt do it)
2007 CRD QDII
2010 Jetta Sportwagen TDI 6MT - hoping it gets bought back!
2004 QD 4.7 GC
2009 Rav4 v6
Hendrix9 is offline
post #9 of 17 Old 02-17-2017, 04:32 AM
DirectMatrix
If you're still entertaining jump starter packs, check out this guy. He has a...unique...approach to testing and recommending starter packs. Here's the link the the entire playlist of testing.
https://www.youtube.com/playlist?lis...1J4YanMKOt_I47
~DM
92 YJ, Delilah
DirectMatrix is offline
post #10 of 17 Old 02-17-2017, 10:59 AM
underscore
2007 WK
Won't that just make it worse? It takes a while to fully recharge a battery after starting a cold engine.
underscore is offline
post #11 of 17 Old 02-17-2017, 12:30 PM
RCS1300
2005 WK
Make sure whatever you purchase has the correct amount of cranking amps for your engine. That small glove box stuff will not have sufficient sustaining amps if you have a starting issue.
RCS1300 is online now
post #12 of 17 Old 02-17-2017, 02:10 PM
DuncsJeeps
DuncsJeeps's Avatar
2006 XK Commander
I carry one of these https://no.co/ works great.
I've only ever had to use it on other peoples vehicles, but it's worked every time.
2017 WK2 Trailhawk - 3.6L: Daily Driver
: OME HD, RRO UCA, T/A KO2, Rack w/LED, Custom storage drawers, Winch, Front and Rear Bumpers - In Progress
: Sold
- RRO Sliders, 27 MPG: Sold
DuncsJeeps is offline
post #13 of 17 Old 02-17-2017, 07:10 PM
acabtp
2005 WK
if not going full size spare battery i would bring a U1 size lawn and garden battery (~$20-30) in a battery box (~$10). a U1 battery that i keep on the tender is my go-to for jump starting stuff around here
plenty of power and reserve for multiple starts if required
no electronics to protect the unit and shut it down when you need it most
easy to use with the jumper cables you already carry
portable, smaller than a full sized spare, easy to carry with one hand
can power winch or other 12v accessories for long periods of time
'05 WK Limited 5.7 Hemi
acabtp is offline
post #14 of 17 Old 02-17-2017, 09:41 PM
stephens039
2005 WK
I bought a portable battery jumper from walmart its a mighty brand. It was only $60 and used it 8 times so far. Only had to charge it when i first bought it still says i have a full charge.
Khaki Club Member #85
stephens039 is offline
post #15 of 17 Old 02-18-2017, 10:36 AM
derpboss
https://www.amazon.com/Lightning-Res...ing+jump+start
I've used this one to start my 5.7, my 4.7 and my ex's 2.2 saturn. Neither of the V8s were super dead, just left the radio on or some lights on too long kind of deal, but it starts them no problem. The 2.2 was sitting for a month+ in winter.
I'd lean towards the smaller ones honestly. The lithium batteries hold the charge longer then the big jump packs older style batteries.
I originally bought this one for my motorcycle, got a bad habit of leaving the key in it and this was small enough to not take much room in the bags. Was pleasantly surprised when it started my hemi.
You need to let them sit on the battery for 2-3 minutes before you try cranking them over, otherwise you just drain em and waste the stored enerhy trying to crank over without enough juice to get it done.
With that being said, This is the one I intend to eventually buy for my jeep, since this one really wasn't intended for my jeep. https://www.amazon.com/Antigravity-B...i+gravity+xp10
derpboss is offline
