Omelet's LED Rock Lights - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Omelet's LED Rock Lights
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 07-24-2011, 05:22 PM   #1
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
This is for those of you who would like to do the same thing. Total cost was about $40.
First thing was to get some lights. I knew I wanted LEDs, so I started looking around. All the kits I found were $100-200 and were pods. I was ok with spending that amount, but then I found the LED strips and decided to give them a try. I bought mine off ebay for $35:
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
It was a 5 meter waterproof roll with 600 white LEDs.
My main concerns were 1. Were they going to be bright enough and 2. Was I going to be able to make 4 pieces out of the one. I knew I could cut the strip every three LEDs, but not sure I could connect wires after ever cut.
So first thing I did was cut 3 LEDs off the end (about 1"). Here you can see the lines where you can cut:
And here is the test subject:
I used a 9V battery to test each strand after they were finished.
Now that I knew they would work I made some measurements and began the build. After cutting I had to trim the waterproof seal to expose the leads.
Now I am not the most capable guy with a soldering iron, but I made it work.
Then I used some heat shrink and sealed the end.
And tested it with a 9V.
See How It Was Made
Omelet is offline   Reply With Quote Quick reply to this message
Unread 07-24-2011, 05:23 PM   #2
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
I decided to mount the front one on the 4xGuard skid. I don't see them getting hit in that crevice, and they are at a good angle to provide ample light to the front skids. It measures 27”
The rear was also mounted to a 4xGuard skid. This time the leading edge shooting the light in and down to illuminate the axle, suspension, and skid. It measures 30”
Because they are attached to removable skids I had to wire in disconnects so that I can still drop the skids when needed.
On the sides I found a wonderfully angled surface that ran the full length of the rocker. As nice as it would have been to mount the lights to the 4xGuard sliders or frame for max light dispersion, this spot was the best for protection. They measure 57”
All that was left now was the wiring. I ran all the wires up into the engine compartment with the rest of my wires to connect the relay and then to the fuse box.
See How It Was Made
Unread 07-24-2011, 05:23 PM   #3
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Luckily this took me long enough to do that I did not have to wait for night. I finished at about 2100 so it was nice and dark. I snapped a few pix of the light show before I parked it for the night.
Before:
After:
The Rear:
And looking up at the sides:
These suckers are a lot brighter than I was expecting (that's a good thing ). I plan to take more pix somewhere besides my driveway. So check back later!
All of the LED strips were just stuck on using the already applied tape. In the rear you can see I used zip-ties to better secure it to the skid because the holes were already there. I plan to do the same with the front after I drill a few small holes. The side will be a little different and will basically be screwed down with little brackets that I have not made yet. So more on that later. For now even after them sitting all night a going for a drive this morning they are holding strong, but I would rather not rely solely on the tape.
The last thing I plan to do but ran out of tie last night, is to tap into the interior lighting. I want to make it so that when I unlock the car or open a door the Rock Lights illuminate. It is really just one more wire with a diode, but as I said I ran out of time.
See How It Was Made
Unread 07-24-2011, 05:27 PM   #4
AJeepZJ
2006 WK
Thats really nice. those look really bright. I think the illuminated entry via unlock button is just sick.
All Gear, No Skill.
AJeepZJ is offline   Reply With Quote Quick reply to this message
Unread 07-24-2011, 05:28 PM   #5
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Now all Of my switches work except for the winch one. I was thinking of using the left over LEDs and mounting them inside of my grill to illuminate the winch...
See How It Was Made
Unread 07-24-2011, 05:29 PM   #6
smcginnis87
4X4WK
smcginnis87's Avatar
2007 WK
that looks really good!!
2015 WK2
--4x4WK--
smcginnis87 is offline   Reply With Quote Quick reply to this message
Unread 07-24-2011, 05:38 PM   #7
USN_BlackWK
FLY NAVY
USN_BlackWK's Avatar
Damn good job Omelet!
2001 Cherokee Anniversary 4.0L
1998 Cherokee Classic 4.0L Aug '15 COTM!
2014 Grand Cherokee SRT 6.4L
USN_BlackWK is offline   Reply With Quote Quick reply to this message
Unread 07-24-2011, 05:42 PM   #8
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Thanks a lot guy! I am very excited about them. They make me want to drive around at night with them on like a little ricer!
See How It Was Made
Unread 07-24-2011, 06:14 PM   #9
Budasac
2005 WK
Are they color changing?? Maybe you could set them up so they flash with the bass when you bump your tunes....
Seriously though, they're pretty bright. Nice job. As per the straps, it's hard to judge the size, but flat 1 hole straps for romex wire might work. You can get a box for a few bucks.
Budasac is offline   Reply With Quote Quick reply to this message
Unread 07-24-2011, 06:33 PM   #10
TurboDiesel
2008 WK
damn dude thats amazing!
i wish i had the skills to wire stuff up
good work as always
TurboDiesel is offline   Reply With Quote Quick reply to this message
Unread 07-24-2011, 06:43 PM   #11
Acidcold
2005 WK
That looks freaking cool! Now I am thinking of using that for the rear interior to light up my tools.
Acidcold is offline   Reply With Quote Quick reply to this message
Unread 07-24-2011, 07:43 PM   #12
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
No they are just white. I did think about getting multi-color ones and making a controller, but I would never use it. So I decided it would be a waist of time and money.
Ya I had that in mind too! The lighting in the rear sicks. The plan was to put a strip on the sealing where all those slots are.
See How It Was Made
Unread 07-24-2011, 07:50 PM   #13
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Well my plans this afternoon fell through. So I went out and drilled some holes for some zip-ties.
Front:
Sides:
See How It Was Made
Unread 07-24-2011, 07:51 PM   #14
TurboDiesel
2008 WK
isnt there 3m on the back of those?
Unread 07-24-2011, 07:52 PM   #15
bumzo1
2005 WK
Holy cow that is really cool, and very cost effective too!
Good Job!
'05 WK 3.7L | OME MD lift | 255/75/17 BFG M/Ts | 20" LED Light Bar
Khaki WK Club Member #1
bumzo1 is offline   Reply With Quote Quick reply to this message
