-   WK Grand Cherokee & XK Commander Forum (http://www.jeepforum.com/forum/f67/)
-   -   Omelet's LED Rock Lights (http://www.jeepforum.com/forum/f67/omelets-led-rock-lights-1243906/)
Omelet 07-24-2011 04:22 PM
This is for those of you who would like to do the same thing. Total cost was about $40.
First thing was to get some lights. I knew I wanted LEDs, so I started looking around. All the kits I found were $100-200 and were pods. I was ok with spending that amount, but then I found the LED strips and decided to give them a try. I bought mine off ebay for $35:
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
It was a 5 meter waterproof roll with 600 white LEDs.
http://i595.photobucket.com/albums/t...s/dcb4b1e7.jpg
My main concerns were 1. Were they going to be bright enough and 2. Was I going to be able to make 4 pieces out of the one. I knew I could cut the strip every three LEDs, but not sure I could connect wires after ever cut.
So first thing I did was cut 3 LEDs off the end (about 1"). Here you can see the lines where you can cut:
http://i595.photobucket.com/albums/t...s/0005fc1f.jpg
And here is the test subject:
http://i595.photobucket.com/albums/t...s/5eea127b.jpg
I used a 9V battery to test each strand after they were finished.
http://i595.photobucket.com/albums/t...s/29674db1.jpg
Now that I knew they would work I made some measurements and began the build. After cutting I had to trim the waterproof seal to expose the leads.
http://i595.photobucket.com/albums/t...s/074b48b3.jpg
Now I am not the most capable guy with a soldering iron, but I made it work.
http://i595.photobucket.com/albums/t...s/1528e409.jpg
Then I used some heat shrink and sealed the end.
http://i595.photobucket.com/albums/t...s/edd45300.jpg
And tested it with a 9V.
http://i595.photobucket.com/albums/t...s/7dc3e4cf.jpg
Omelet 07-24-2011 04:23 PM
I decided to mount the front one on the 4xGuard skid. I don't see them getting hit in that crevice, and they are at a good angle to provide ample light to the front skids. It measures 27”
http://i595.photobucket.com/albums/t...s/3c21e8b3.jpg
The rear was also mounted to a 4xGuard skid. This time the leading edge shooting the light in and down to illuminate the axle, suspension, and skid. It measures 30”
http://i595.photobucket.com/albums/t...s/f45c8c54.jpg
Because they are attached to removable skids I had to wire in disconnects so that I can still drop the skids when needed.
On the sides I found a wonderfully angled surface that ran the full length of the rocker. As nice as it would have been to mount the lights to the 4xGuard sliders or frame for max light dispersion, this spot was the best for protection. They measure 57”
http://i595.photobucket.com/albums/t...s/7d1c10e7.jpg
All that was left now was the wiring. I ran all the wires up into the engine compartment with the rest of my wires to connect the relay and then to the fuse box.
Luckily this took me long enough to do that I did not have to wait for night. I finished at about 2100 so it was nice and dark. I snapped a few pix of the light show before I parked it for the night.
Before:
http://i595.photobucket.com/albums/t...s/35d7b142.jpg
After:
http://i595.photobucket.com/albums/t...s/e3f520c6.jpg
The Rear:
http://i595.photobucket.com/albums/t...s/0a4a433c.jpg
And looking up at the sides:
http://i595.photobucket.com/albums/t...s/6099a782.jpg
These suckers are a lot brighter than I was expecting (that's a good thing :D). I plan to take more pix somewhere besides my driveway. So check back later!
All of the LED strips were just stuck on using the already applied tape. In the rear you can see I used zip-ties to better secure it to the skid because the holes were already there. I plan to do the same with the front after I drill a few small holes. The side will be a little different and will basically be screwed down with little brackets that I have not made yet. So more on that later. For now even after them sitting all night a going for a drive this morning they are holding strong, but I would rather not rely solely on the tape.
The last thing I plan to do but ran out of tie last night, is to tap into the interior lighting. I want to make it so that when I unlock the car or open a door the Rock Lights illuminate. It is really just one more wire with a diode, but as I said I ran out of time.
AJeepZJ 07-24-2011 04:27 PM
Thats really nice. those look really bright. I think the illuminated entry via unlock button is just sick.
Omelet 07-24-2011 04:28 PM
Now all Of my switches work except for the winch one. I was thinking of using the left over LEDs and mounting them inside of my grill to illuminate the winch...
http://i595.photobucket.com/albums/t...n/03f40499.jpg
smcginnis87 07-24-2011 04:29 PM
that looks really good!!
USN_BlackWK 07-24-2011 04:38 PM
Damn good job Omelet!
Omelet 07-24-2011 04:42 PM
Thanks a lot guy! I am very excited about them. They make me want to drive around at night with them on like a little ricer! :rofl:
Budasac 07-24-2011 05:14 PM
Are they color changing??:rofl: Maybe you could set them up so they flash with the bass when you bump your tunes....:cheers:
Seriously though, they're pretty bright. Nice job. As per the straps, it's hard to judge the size, but flat 1 hole straps for romex wire might work.:thumbsup: You can get a box for a few bucks.
TurboDiesel 07-24-2011 05:33 PM
damn dude thats amazing!
i wish i had the skills to wire stuff up
good work as always
Acidcold 07-24-2011 05:43 PM
That looks freaking cool! Now I am thinking of using that for the rear interior to light up my tools.
Omelet 07-24-2011 06:43 PM
No they are just white. I did think about getting multi-color ones and making a controller, but I would never use it. So I decided it would be a waist of time and money.
Ya I had that in mind too! The lighting in the rear sicks. The plan was to put a strip on the sealing where all those slots are.
Omelet 07-24-2011 06:50 PM
Well my plans this afternoon fell through. So I went out and drilled some holes for some zip-ties.
Front:
http://i595.photobucket.com/albums/t...s/0b566fd2.jpg
Sides:
http://i595.photobucket.com/albums/t...s/03f4592c.jpg
TurboDiesel 07-24-2011 06:51 PM
isnt there 3m on the back of those?
bumzo1 07-24-2011 06:52 PM
Holy cow that is really cool, and very cost effective too!
Good Job!
The time now is 01:10 AM.
