Omelet's Hidden Winch Build - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Omelet's Hidden Winch Build
Jeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinIntroducing MONSTALINERô UV Permanent DIY Roll On Bed LineIncome tax season is upon us. We got what u need
Unread 06-10-2011, 12:24 AM   #16
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
The controller plug I ran across the bumper with the temp sensor wires to the drivers side of the Matrix. I filed out the top large hole and pressed in the plug. Then ran the wires straight back under the grill.
In order to access the clutch lever I cut a hole in the top of the grill. Down side it that you have to pop the hood to get to it, but this way it looks clean with no visible holes. Plus let's face it, this is a Jeep with QD2! How often will I be stuck and have to access the clutch lever!
Looking straight down you can also see I had to trim one side of the lever for it to turn without hitting the grill. It still works perfectly fine this way. The lever is very easy to reach and manipulate.
See How It Was Made
Omelet is offline   Reply With Quote Quick reply to this message
Unread 06-10-2011, 12:25 AM   #17
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Last thing to do was instal the line. I did not want to use the heavy steel cable that the winch came with. So I acquired 100' of synthetic line. I bought 18' of VX Fire Sleeve and installed it on the end of the line. This sleeve will withstand up to 700 degrees. Even though I have heard that the EP9 works fine with synthetic and will not get hot enough to adversely affect it I wanted over kill. I also used 20' of 1" tube webbing for a chafe guard.
I secured the end of the line to the drum and prepared to spool it in. I needed to do this with weight applied so I decided to pull myself up my drive way using my Beast of an XJ as my anchor. The problem was that my drive way is only 50' long which meant that I needed to use a snatch block. I ran the line from the WK at the end of my driveway, up to the XJ through a snatch block, and back the the WK attached to the Matrix. It worked Beautifully!
Once the line was in and attached to the Matrix.
A shot of the winch nestled in place hiding safely behind the bumper.
See How It Was Made
Unread 06-10-2011, 12:26 AM   #18
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Lastly I decided to remove the Superwinch bubble sticker off the solenoid box and applied it to the bumper. It gives a hint of the Awesomeness lying in wait!
I hope this has been beneficial and knowledgable for those of you hoping to do the same.
See How It Was Made
Unread 06-10-2011, 05:55 AM   #19
CmmdrDan
Awesome man. You did a great job with it. We can all tell how happy you are with it! And you should be. As always we are waiting for the next project.
Sent from my thumbs.
CmmdrDan is offline   Reply With Quote Quick reply to this message
Unread 06-10-2011, 06:31 AM   #20
LJS8510
LJS8510's Avatar
2015 WK
Looks fantastic!
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline   Reply With Quote Quick reply to this message
Unread 06-10-2011, 06:59 AM   #21
cmdrjim
2006 XK Commander
Have you thought about offering a kit to sell?
06 Red Jeep Commander 3.7L V6 "Manual QT2", and many more upgrades
cmdrjim is offline   Reply With Quote Quick reply to this message
Unread 06-10-2011, 08:15 AM   #22
JSajczuk
2008 WK
nice nice nice!
2008 WK Limited: OEM Skid Plates/4xGuard Armor: Belly Pan, Front Guard, Diff Cover/Saguaro 4x: front recovery shackles/Lift: DayStar 2" BB/Wheels MB CHAOS 5 - 8.5x17 w/pos 25 offset/Tires: Hankook Dayna Pro ATm 265/70r17/ Front and Rear PinchWeld Mod./ Now a 'little LESS' Limited!
JSajczuk is offline   Reply With Quote Quick reply to this message
Unread 06-10-2011, 09:04 AM   #23
ogie
2005 WK
Seconded. I would love to do this.
'05 WK 4x4 QT2 4.7l v8 | Superchips | Saguaro 3/4" shackle mounts | 4xguard Front and Belly Guard
ogie is offline   Reply With Quote Quick reply to this message
Unread 06-10-2011, 09:43 AM   #24
djeep05
2005 WK
Awesome job Omelet. Great write up. I wish I was brave enough to cut into my WK.
[COLOR="Red"][B]HEMI Club Member #54[/B][/COLOR]
[COLOR="Silver"][B]Silver WK Club Member #8[/B][/COLOR]
djeep05 is offline   Reply With Quote Quick reply to this message
Unread 06-10-2011, 10:19 AM   #25
CraigWK
2005 WK
I just peed a little. That is great work!!
Sold...-=2005 WK Grand Cherokee 4.7L rocky mountain edition=-
OME HD lift | Saguaro front bumper | JK 17" wheels with 32" BFG KM Mud tires | 4xGuard skid plates (belly, rear) | D-rings | Husky Liners throughout | SuperChip mod | Warn M8000
CraigWK is offline   Reply With Quote Quick reply to this message
Unread 06-10-2011, 10:27 AM   #26
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Lol! Thanks Guys!
As of right now I am not planning on building another, which is why I have given you all the info and measurements, but I don't know what the future will bring.
See How It Was Made
Unread 06-10-2011, 10:44 AM   #27
criket
2005 WK
What name would you call it by omelet? I knida like "Western Omelet Industries" since you are in CA and your jf name.
2005 | WK | Khaki | 3.7 | QT1 | OME HD Front Struts | Rusty's 2" lift in Rear w/ Monroe load levelers (F150 version) | 265/70 Nitto Terra Grapplers | 17" Moabs | 1.5" wheel spacers | Pinch weld mod Rear fender trim mod | 4xG Matrix w/ reciever hitch | 4xG Belly guard | SOLID Diff cover | Cobra CB radio | 4xG antenna mount | Rola roof
criket is offline   Reply With Quote Quick reply to this message
Unread 06-10-2011, 10:53 AM   #28
Mainsail
2005 WK
Wow! Where has 4XGuard been? It doesn’t seem likely that any company will take it up and fab a kit now that the WK is obsolete, but you’ve already done the grunt work. Great work and really great write-up!
Poor grammar is something up with which I shall not put.
Mainsail is offline   Reply With Quote Quick reply to this message
Unread 06-10-2011, 11:06 AM   #29
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Criket - I like it! I am going to keep it in mind!
This is something 4xGuard will never make. Their solution was the Matrix with integrated hitch to accept a portable winch. It was just not what I wanted. This is something that would be difficult to sell as a kit. There are always slight differences in every vehicle. I made this thing fit perfectly inside the frame rails in place of the stock crossmember. One solution might be to have a place cut all the steel for you in the measurements I listed and then either do the welding yourself or have a shop do it for you.
Doing all the work yourself is quite beneficial. The steel was free for me so I paid for cutting discs, welding wire, and bolts. Cost to me including the winch was about $650.
See How It Was Made
Unread 06-10-2011, 11:14 AM   #30
hoaxci5
1995 XJ Cherokee
I think it needs to be Western Omelet Enterprises so it can be said out loud as WOAH!
Unknown - 1995 XJ - 4.5 RC lift, drop brackets, 33" MT's, SYE, Custom Bumpers/Rockrails
Rambo - 2007 XK Limited 5.7 - OME HD - Monroe Load Levelers (F150) - Flashpaq - RRO SuperSliders - 4XGuard all over - SOLD
hoaxci5 is offline   Reply With Quote Quick reply to this message
