Omelet's Headlamp Project! - Page 8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Omelet's Headlamp Project!
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 12-24-2011, 04:58 AM   #106
alwaysHI
2003 WJ
you make me wanna sell my WJ for WK hahah
Bronson = 21 yrs. old
BUILT, NOT BOUGHT - WORKED HARD FOR, NOT KISSED MOMMY/DADDYS A** FOR!
Build Thread - http://www.jeepforum.com/forum/f197/alwayshi-build-thread-1256466/ - SOLD
alwaysHI is offline   Reply With Quote Quick reply to this message
Unread 12-24-2011, 09:11 AM   #107
JeepMDHemi
2005 WK
Wow looks really good man. Great job!!
2005 WK HEMI LIMITED-CORSA PERFORMANCE EXHAUST-265/70/17 MICHELIN LTX AT2's-RRO 2.25" LIFT-JK RUBICON WHEELS-SUPERCHIPS-VOLANT CAI
JeepMDHemi is offline   Reply With Quote Quick reply to this message
Unread 12-24-2011, 05:01 PM   #108
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
I GOT THEM IN!!!
I will post up more pics later. Time to be with the fam!
See How It Was Made
Omelet is offline   Reply With Quote Quick reply to this message
Unread 12-24-2011, 10:15 PM   #109
Rak187INF
2009 WK
That looks awesome bro! The jeep sidemarkers are a really nice touch
Black WK Member #28
2009 WK- 2 Inch RC lift, 265/70/17 General Grabber AT2
Rak187INF is offline   Reply With Quote Quick reply to this message
Unread 12-24-2011, 11:27 PM   #110
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Thanks! That was one of my favorite things to add!
I have a lot more pics and details to post, but that will have to wait until Mon. I still don't even have the bumper on all the way. In that pic it is just resting in place. It will look much better bolted in!
See How It Was Made
Unread 12-24-2011, 11:31 PM   #111
cherrybomb05
2010 JK Wrangler
WOW! That thing looks way too nice to scratch up now! Looks awesome!
Sent from my Droid using JeepForum
07 WK
10 JKUR
11 JKR
cherrybomb05 is offline   Reply With Quote Quick reply to this message
Unread 12-24-2011, 11:52 PM   #112
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Haha! Never!
See How It Was Made
Unread 12-26-2011, 07:47 AM   #113
meep
2008 WK
Omelet, your imagination and motivation make me smile. Reminds me of when I was younger! Thank you!!!
meep is offline   Reply With Quote Quick reply to this message
Unread 12-26-2011, 12:12 PM   #114
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Thanks Meep!
See How It Was Made
Unread 12-26-2011, 01:40 PM   #115
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Ok now to finish this thing up! The passenger side headlamp normally has some control unit that bolts into the bottom of the housing. Since these are getting retrofitted into an 05 and not bolted and plugged into an 08+, this space was going to be unused. So I needed to plug the hole. My solution was to use plexiglass cut to the same dimensions as the hole (3.5"x3.75"), and then screwed into place the same way the control unit would be.
No for the my gap solution! Initially I had planned to just install the lamps and worry about the gaps later, but once I got going I decided that while I was at it I may as well fit the gaps. I started by making a piece out of card stock.
Once I got it just the way I liked it, I traced the design onto plexiglass and cut them out. After some trimming and sanding they were ready.
Then I put a couple of thumb tacks into cardboard, used a dab of hot glue, and stuck the spacers on. And continued to paint them the same as the lamps.
A quick test fit after paint.
See How It Was Made
Unread 12-26-2011, 01:41 PM   #116
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
The attachment plan was to used hot glue. I did the first one outside at night which turned out good...
...or so I thought until the next morning! With the sunlight I noticed that you could see the glue through the corner of the lens.
On the driver side I decided to paint the bottom black first and then glue the spacer on to see if it looked any better.
It looked much better!
So then I took the passenger side back off and painted it too.
To reinforce the spacer a little bit more I made a couple of gussets for each side and glued them in. And this is the finished product.
See How It Was Made
Unread 12-26-2011, 01:43 PM   #117
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
A comparison between the 05-07 OEM that I removed and the 08+ HID headlamps that went in.
See How It Was Made
Unread 12-26-2011, 01:44 PM   #118
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
And some random finished shots. (some of these were from before the bumper was bolted back in completely)
I still have to aim them in and finish up some loose ends, but they are now in and working. I will get some more shots up later!
See How It Was Made
Unread 12-26-2011, 04:04 PM   #119
Jeep_Country
You should start making these and selling them! I'd buy a set in an instant if you did
'08 JK Unlimited Rubicon
Jeep_Country is offline   Reply With Quote Quick reply to this message
Unread 12-26-2011, 05:02 PM   #120
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Thanks, but I don't know. That was a lot of hassle! I am not completely opposed to doing another set, I guess just not right now.
See How It Was Made
