Omelet's Build Thread (aka The Bison)! - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Omelet's Build Thread (aka The Bison)!
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 01-07-2012, 10:59 PM   #76
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
After adding all of the additional weight in the past year, especially the rails, I decided the MD coils just weren't going to cut it anymore. Before the Jeep felt very controlled on and off road, but lately it was feeling a bit floaty. Also in preparation for a near future project, it was time to upgrade to the Heavy Duty coils! So I place another order from Kolak.
While I had the struts apart I also installed some rubber bumpstops to the existing foam ones. These effectively keep the tires from smashing into the fenders on hard hits.
I used these and cut them in half so they were 0.5" thick.
And how it looked after!
See How It Was Made
Omelet is offline   Reply With Quote Quick reply to this message
Unread 01-07-2012, 11:05 PM   #77
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Originally Posted by zeds_dead View Post
How much did you spend on them? And any comments on them? I'm in the market for some. Any cons?
They are $60 a pair. I haven't had any issues with them. The only thing that could be a con is that with the 1" set they are only hub and lug centric, not wheel centric. I didn't see it as that big of a deal.
See How It Was Made
Unread 01-07-2012, 11:09 PM   #78
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
A few days later I got the heart of a project I had been planning for over a year. . .
I got it off Amazon for just over $500 with free shipping!
See How It Was Made
Unread 01-07-2012, 11:31 PM   #79
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
I was kind of in between mods and I needed to do something one weekend. So I knocked out some painting. I had been looking for that perfect graphite paint for some time and finally found what I was looking for at Pep Boys. First I painted up the Matrix then moved onto the 4xGuard front skid. I painted the center crossmember on the Matrix Khaki to match the Jeep and the rest graphite.
It took some convincing to paint the skid because I liked how it looked silver, but in the end I think I like it better this way.
See How It Was Made
Unread 01-07-2012, 11:46 PM   #80
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Went for a nice little scenic drive.
See How It Was Made
Unread 01-07-2012, 11:51 PM   #81
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
I gave her a good bath. She was dirty! Plus I had a new badge for her to wear
See How It Was Made
Unread 01-08-2012, 12:47 AM   #82
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
It was time for a little more suspension modification! In my hunt to continue pushing the OME lift I had a new batch of goodies for her. I installed the OME HD coils up front but not in the rear yet, so I did that here. I had done some measuring and found that with a little bit of work I could run longer rear shocks. So I ordered up some SuperLift SuperRide shocks from Kolak. I didn't like the white shock body and yellow boots so I painted the shocks graphite and had Kolak also send me black boots.
Comparison to the OME.
OME rear shocks (PN: N190) extend out to 26" where as the SL shocks (PN: 88200) extend out to 28". So I could get 2 more inches of down travel by running these.
However! Before you go swapping longer shocks in, I had to do a few things. First I had to extend my break lines. I could have bought the SL brackets, but I am cheap and I had some steel sitting around. So I made my own!
And in case you haven't done it already, notch the gas tank skid so the UCA can drop down as far as possible.
Lastly, check the wires doing down to the diff (QDII) and if need be extend them. (You can see it in the track bar pic below)
In the effort to maximize flex and articulation I chose to swap out the sway bar links to a set of JKS quicker disconnects (PN: 2001) These are not a direct bolt in. You have to drill out the top eye to match the frame end bolt. I like these links because they are adjustable, the ends are rubber ball joints that will flex with the suspension, and they are greasable. I adjusted them out to the same length as the Rusty's ones.
To keep the axle center I installed the Rusty's Adjustable Track Bar (PN: RC-TB732-WK) and adjusted it .5" longer than the stock one.
Last thing was bumpstops. I fixed the front, so now to fix the rear. I used a pair of 2" PVC couplings (chopped them down to 1.5" long) and got longer bolts. I painted the couplings so they weren't white and put them in. These fixed the rubbing issue in the rear for all but the extreme stuffs.
See How It Was Made
Unread 01-08-2012, 01:05 AM   #83
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Some rear drop shots!
For comparison. Yours truly standing at a modest 5'11" The tire is just about to lift off the ground here.
And one while killing some time at work trying not to roll into the Lexus next to me! Pay no attention to the random spectator
See How It Was Made
Unread 01-08-2012, 12:12 PM   #84
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
I wanted to start a light collection so I started looking around. I got into the LED off road lights, loving how much light output such a small unit could achieve. After some research I decided on the Rigid Industries Duallys. So I went and talked to a buddy at the local 4WheelParts. He told me that the D2s were just released and he could get me a killer deal on a set. After some convincing to spend a little bit more money I paced an order for a set of D2s in the amber combo pattern for $300. Unfortunately they did not have any yet, but where expecting the first shipment the following week. A week later I got the call and picked them up!
I was quite excited! These things were beautiful!
See How It Was Made
Unread 01-08-2012, 12:14 PM   #85
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
I decided to mount them to the Matrix for the time being. It wasn't the ideal place, but it worked for now until I could make other plans.
See How It Was Made
Unread 01-08-2012, 12:28 PM   #86
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Some quick night shots!
See How It Was Made
Unread 01-08-2012, 12:35 PM   #87
Jvenrick
Jvenrick's Avatar
2007 WK
WOW, its amayzing how much you have done. Your WK is awesome. Great job!! Cant wait to read more!
Jvenrick is offline   Reply With Quote Quick reply to this message
Unread 01-08-2012, 01:08 PM   #88
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Thanks Bud! It has been a very long and constant project
See How It Was Made
Unread 01-08-2012, 01:09 PM   #89
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
As I mentioned earlier I wasn't happy with the mounting placement. I had learned that living here in North Mexico meant nothing with exposed bolts was safe. All it took was for the guy parking next to you at Walmart to see the expensive lights sitting there and decide he wanted them more than you. So I had to devise a plan. I thought of tack welding the bottom of the bolt so the nut wouldn't come off, but that meant I couldn't take them off if I wanted to without cutting the bolt. Plus if you notice the allen bolts going in the sides, you pull those out and the light comes right off the mount. So my plan was to flush mount them into the grill. I wasn't too sure I would like the look, but I did it anyway! Worst case, I didn't like it and then I needed to replace the grill inserts (something I wanted to do anyway).
So I pulled the grill off, bent up a couple of brackets, welded them in place, drilled mounting holes, and mounted the lights!
Man look at all that space behind the bumper . . .
See How It Was Made
Unread 01-08-2012, 01:11 PM   #90
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
All that was left was to cut the gill openings and pop the grill back in place.
It didn't look too bad! Though it would look better with maybe three more in the center
See How It Was Made
295/70/17 , 35" tires , 4x4 , fox , jeep wk , lifted , ome , omelet , ort , superlift , wk
