Omelet's Build Thread (aka The Bison)! - Page 50 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Omelet's Build Thread (aka The Bison)!
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 04-01-2012, 05:34 PM   #736
Valpacer
2007 WK
Enough rest. BACK TO WORK!
heheh
looking good man!
Dave
2007 WH Grand Cherokee CRD (Yup, RHD Australia)- 3" Exhaust, GDE Flash Tune, CRDSTU/SL Hybrid Lift & bash Plates, 4xGuard Rock Rails, Saguaro F & R Bars, RCV's, Warn 9.5cti-s, AEV Saverge Rims, Nitto Mud Grapplers, Snorkel, Custom Rear Drawers, On Board Air, BullyDog Monitor, Dual Batteries - [URL="http://www.jeepforum.com/forum/f67/valpacers-wh-build-thread-war-machine-1376368/"]Build Thread[/URL] - [URL="http://www.youtube.com/user/valpacer?feature=mhee#p/a"][U]YouTube Vids[/U][/URL]
Valpacer is offline   Reply With Quote Quick reply to this message
Unread 04-01-2012, 06:10 PM   #737
JBert
2005 WK
Who need's porn when you have Omlet's truck?
-Justin-
1988 YJ, 2005 WK
JBert is offline   Reply With Quote Quick reply to this message
Unread 04-02-2012, 12:17 AM   #738
ngould1
Just browsed through all 50 pages! Awesome build, wish I could do this! Keep it going omelet
ngould1 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2012, 11:56 AM   #739
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Thanks Guys! I worked until 2300 last night, but the front is still not finished It is very close though. I wont get much done on it today, but I will be back at it tomorrow. I will get some pics up soon. It looks beast!!!
See How It Was Made
Omelet is offline   Reply With Quote Quick reply to this message
Unread 04-02-2012, 12:21 PM   #740
Mainsail
2005 WK
Being able to comfortably do your work outside is a great bonus!
That's about the only thing I miss about CA though.
Poor grammar is something up with which I shall not put.
Mainsail is offline   Reply With Quote Quick reply to this message
Unread 04-02-2012, 01:24 PM   #741
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Yes that is nice and about the only thing for you to miss
See How It Was Made
Unread 04-02-2012, 02:05 PM   #742
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Ok, because I LOVE my OME front suspension I wanted to try to use it with the SL. I had a couple options. First I could use the strut assembly as is and add a 2" BB spacer on top of it to achieve about a 25" hub-fender measurement. This would retain the ride quality and weight control I like and give the ride height of the SL system. The bad thing about that route is down travel would suffer since there would only be a 2" spacer on top instead of a 4" SL spacer. Since down travel is one of the big reasons of getting the SL, that option was not looking ideal to me. Second option was to cut one complete coil off the bottom of the coils so they wouldn't ride so high. Then put the assembly back together without installing the preload plate included in the SL kit, and bolt the 4" SL spacer on the top. This should retain the ride quality and weight control as before (in fact it should be a little stiffer) and give the desired ride height. It will probably ride a little higher that the normal SL but, it should be a good combination of travel and weight control. SO I decided to give the second option a try! I acquired a set of Hemi XK coils just in case it doesn't work out
I disassembled the strut and removed the HD coils. I used a paint pen and marked where I planned to cut.
Then I took my angle grinder with a cut off wheel and clipped one coil off.
I put the strut assembly back together leaving out the SL preload plate. Then bolted the SL spacer to the top. Once installed it looked like this.
Here is a comparison between the OEM aluminum spindle (left) and the SL steel spindle (right). The thing weighs a TON! I didn't weigh it but once the hud and rotor are bolted on it has to be around 100lbs.
I still have the jack stands under it holding most of the vehicle's weigh, but the tires are on the ground holding some weight to keep anyone from walking off with the front tires How it sits right now.
Right now it looks like I have gained 3" of down travel
See How It Was Made
Unread 04-02-2012, 02:11 PM   #743
BobG97
2005 WK
that looks awesome! i can't wait to see the completed project, its going to be a beast for sure!
BobG97 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2012, 03:07 PM   #744
AJeepZJ
2006 WK
There's no weight on the front end yet right? I'm looking at the CV angles o.O..
All Gear, No Skill.
AJeepZJ is offline   Reply With Quote Quick reply to this message
Unread 04-02-2012, 03:15 PM   #745
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
There is a little bit of weight, but the CVs are fine. I tested the downward limits before I but everything together and they could drop farther. The tie rods are a different story. If the front went down another inch from the where it maxes out at now, they would be at their limit.
See How It Was Made
Unread 04-02-2012, 03:50 PM   #746
USN_BlackWK
FLY NAVY
USN_BlackWK's Avatar
I'm really looking forward to seeing how this turns out as its exactly the plan I have for my front suspension after I get a winch. Keep up the good work!
2001 Cherokee Anniversary 4.0L
1998 Cherokee Classic 4.0L Aug '15 COTM!
2014 Grand Cherokee SRT 6.4L
USN_BlackWK is online now   Reply With Quote Quick reply to this message
Unread 04-02-2012, 09:13 PM   #747
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Thanks bud! I will make more progress and have updates tomorrow.
See How It Was Made
Unread 04-02-2012, 10:38 PM   #748
ryanlamb00
2005 WK
What paint did you use to paint those rims? They aren't the ones with truck bed liner are they?
ryanlamb00 is offline   Reply With Quote Quick reply to this message
Unread 04-02-2012, 11:24 PM   #749
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
No they aren't the ones with bedliner, they are the ones I did last year. I used a graphite paint from PepBoys and a high gloss finish. They are painted the same way though except I didn't use any blue.
See How It Was Made
Unread 04-04-2012, 01:29 AM   #750
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Well I am finished for the day! Another late night Everything is now installed! I just need to go out tomorrow and lighten up some bolts and check clearances. I'll post some pics tomorrow.
See How It Was Made
295/70/17 , 35" tires , 4x4 , fox , jeep wk , lifted , ome , omelet , ort , superlift , wk
