Omelet's Build Thread (aka The Bison)! - Page 36 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Omelet's Build Thread (aka The Bison)!
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 03-03-2012, 05:08 PM   #526
GraKee99
Rapist Wit
GraKee99's Avatar
How many champions did you get? I would ask 200 for that wheel in the condition it is in. Post it up on pirate4x4 and someone will want it. Those go for $350 new.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
Unread 03-03-2012, 05:10 PM   #527
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Originally Posted by sixfoot9psu View Post
So you're building a monster truck now?
Something like that
Just one so it might be difficult to sell unless someone wants/needs a spare in this specific size.
See How It Was Made
Omelet is offline   Reply With Quote Quick reply to this message
Unread 03-03-2012, 05:12 PM   #528
GraKee99
Rapist Wit
GraKee99's Avatar
I updated my post. Someone on pirate will bound to want a 5th wheel for a spare. That size and bolt pattern is pretty common.
Brian
WJ, WK, CJ5
Unread 03-03-2012, 05:15 PM   #529
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
I was curious and did some weighing!
Just the tire - 63lbs
Tire with aluminum wheel - 78lbs
Tire with beadlock/runflat - 103lbs
See How It Was Made
Unread 03-03-2012, 05:15 PM   #530
mrtosh
2005 WK
I knew it!! Haha! Congrats! Now get the SL on and mount up these bad boys! Haha!
'05 WK Limited QDII, Superlift 6", Bilstein struts,315/70/17 Duratracs, Gibson CB, Volant CAI, JBA UCA's, JKS quick disco, adj. Rear trac bar, 4xguard armor, Diablosport Intune, Xenondepot 6000k HID's, Putco Jet yellow fogs.
mrtosh is offline   Reply With Quote Quick reply to this message
Unread 03-03-2012, 05:16 PM   #531
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Ha! Just saw that. Thanks! Once I figure out how to get it off I will post it up somewhere. In the mean time, if you find someone who wants it send them my way
See How It Was Made
Unread 03-03-2012, 05:19 PM   #532
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Patience my friend! I haven't even received the SL yet. I talked to Nick yesterday and he told me one of the three boxes went missing so they are sending another one out. I should be able to go pick it up early next week!!!
See How It Was Made
Unread 03-03-2012, 05:25 PM   #533
GraKee99
Rapist Wit
GraKee99's Avatar
Might be able to get it off at home. Take the top ring off (looks like you already got that done). Then flip the tire over tire and use a hi lift on the tire to press the bead off. You can jack your jeep up on the slider with the base of the jack on the tire bead. Do that in 3 spots and that should pop that back bead free. Then, slide the tire over the front lip. Should be that easy.
I would want the wheels if you have 4.
Brian
WJ, WK, CJ5
Unread 03-03-2012, 05:27 PM   #534
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Ok thanks! I figured it was a process like that. I have to figure out the runflat too.
See How It Was Made
Unread 03-03-2012, 07:17 PM   #535
t3kmitch
2005 WK
Originally Posted by omelet
The guy lives 50 miles away so I had to refuel before leaving. This is really starting to hurt!
Don't mean to spark anything political, but saw this and thought of your post.
-Sold 3/13. Replaced by 2010 VW Jetta 2.5-
2005 WK 3.7L Laredo. RC 2", 265 70 17 Bridgestone Dueler Revo 2's. Class III OEM hitch added. Bilstein Struts. Monroe Load Levelers (58643).
Blue WK Club Member #32
t3kmitch is offline   Reply With Quote Quick reply to this message
Unread 03-03-2012, 07:22 PM   #536
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Nice! Thanks Obama!!!
See How It Was Made
Unread 03-03-2012, 08:12 PM   #537
w1pf
Who, me?
w1pf's Avatar
2007 WK
Yeah, we can probably go back as far as Nixon to thank/blame for this, probably even before. But I was in 5th grade when Nixon was elected, so I don't have much memory before that (though I DO remember all the cars that all my uncles, aunts and cousins owned..)
Anyway, back to your regularly-scheduled build thread.
2014 WK2 Overland 5.9L
2007 WK Limited 5.7L
And some past Durangos
Red WK #19, Hemi #68.. I think..
Durango Owners Club DOTY 2011
"Must have been that yesterday was the day that I was born"
w1pf is offline   Reply With Quote Quick reply to this message
Unread 03-03-2012, 10:03 PM   #538
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
So now for the unfinished project which is now completed. Today I FINALY finished plumping the tank into the compressor!!! I am not sure why it has taken me so long to complete it. Probably because the compressor has been working beautifully all this time and having the tank is just an added benefit. I went out and grabbed some needed parts.
This was most of it. I had a few other pieces already in the stash, so this would complete it.
I planned out the piping and built it just hand tight to make sure it would work. It would come out the side of the compressor tank, then have a ball valve (to secure the flow to the tank if need be), then a gauge, and then off to the tank in the rear.
Once I was confident with my plan it was all torn down, taped, and tightened.
From there the 1\4" hose drops down into the frame.
It passes through the frame and out the bottom. I wanted to run it back a ways and have it pop out in the rear, but the frame gets a little cluttered at the crossmember. So it just goes straight through. I wrapped the tube with some cool tape because it ran next to the exhaust for a short distance and I didn't want to take the chance of it melting.
I tucked the tube behind the heat shield and ran it all the way down the side until the shield ends. Then it was fastened to multiple points as it continued down the side.
I wrapped it again where it passed over the exhaust with a wire harness.
And finally it mates up with the hose off the tank with a quick disconnect.
See How It Was Made
Unread 03-03-2012, 10:58 PM   #539
jager00
2005 WK
And here i was thinking it was hooked up the whole time. You sneaky son of a gun you.
2007 JK Sahara- trying to figure this one out
2005 WK 9" lift on 37's with all the goodies- regretfully sold :(
jager00 is offline   Reply With Quote Quick reply to this message
Unread 03-03-2012, 11:28 PM   #540
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Haha!!! Nope! The compressor was there and the tank was there, but I never did attach the two. There was always something else going on! But now that is done and I can finished one of my other unfinished projects
See How It Was Made
295/70/17 , 35" tires , 4x4 , fox , jeep wk , lifted , ome , omelet , ort , superlift , wk
